发表于 2009-9-6 22:27:15
来自: 中国四川成都
The comaprison is an electrohydraulic servo vs electhydraulic proportional valve?
F6 H( ~/ g1 W# `6 T" X5 D) v% [# ]8 r- x* w9 E5 v
The main difference is the overlap of the spool when in it's nuetral position. The servo valve has a slightly negative overlap, the proportional has a positive overlap which creates a dead-band. It is this dead-band that effects the response time of a proportional valve, even the ones that do have position feed-back.
+ ]# `3 P. B1 x8 j9 [+ X6 r- e. U4 c7 W/ f% h. T
There is usually another difference in the amplifier card that drives the proportional valve. They will often have dead-band compensation circuitry to get a more linear response from the valve with regards to it's input signal. This can make the proportinal valve seem stepless with regards to it's deadband however there still is a response time issue as it takes a given amount of time for the spool to travel past the overlap." N) Z, q# F+ A4 h+ W T5 k
+ I/ N0 `1 W4 g0 \To make matters more confusing, an electro hydraulic servo valve is a proportional valve and is sometimes referred to as a proportinal valve. I like to stick with the term proportional servo. |
