Volume flow referred to 1 bar :V (m3/hr) 3 V& X, o! Y, t) q. f# e
operating pressure : Po (bar abs) 8 a5 u4 r" g! r% s/ w- S
Inlet temperature : T¡ (°C) # `* P/ _7 H. z2 M! U1 ?9 ] s
Pressure dewpoint: Pdp (°C) ! C: a6 B' g! [# F: j6 xVolume flow at the inlet of the adsorber has to be converted on the basis of reference values to obtain the effective volume flow (Ve) . 公式如下: Ve=V *(273.15+Ti)/(273.15+t) 上述这段是什么意思? - M! R8 Y. D6 u1 i j: D/ d" [- D% M9 ?8 L& Z/ L
还有具体的: . B A4 s5 `2 z3 a
effective volume flow(Ve)应该是什么状态下的流量??? 1 L* i+ m d6 F( I X+ [# L7 w
the reference values 是指什么状态下的值? 0 g6 a; @0 T' U上面的公式是不是有问题,会是等压变化吗?
