8天前
查看: 8121|回复: 3
[已解决] 错误: 参数类型错误: stringp nil求助
发表于 2009-10-6 22:27:49 | 显示全部楼层 |阅读模式 来自: 中国北京
LSP程序% k# m8 g% M. U6 I
(defun c:dia5b()
4 T( L  N; }- @9 w) C. v# t(setvar"cmdecho"0)
+ U  R' s9 n) ~! C  I( P' T(dcl_dia5b)
$ R& W0 E; a  p4 f) X7 M8 I(prinl)7 h; v+ |) ^3 g7 c7 V
)2 @) _4 a9 |; V5 n/ X1 {5 [
(defun dcl_dia5b()& f! v$ M: B" C/ B& }& Q
(setq dcl_id(load_dialog"dia5b"))
* ]) s( n9 g2 F6 J% \(new_dialog "dia5b" dcl_id)
, K0 w  A4 ~" U# w* x(set_tile"kww" "50")
% A1 U* }( t  G# N2 L, W0 X(set_tile"khh" "50")
4 f& p  j. U( i(action_tile"bb1" "(get_ww_hh)(done_dialog 1)")' b9 {! ?4 @' C5 @% g! F* V' P
(action_tile"bb2" "(get_ww_hh)(done_dialog 2)")% O0 j! x6 i" P7 G
(action_tile"bb3" "(get_ww_hh)(done_dialog 3)")
+ B- ?0 x& t9 Q5 U5 U3 X9 z: k8 J* a(setq dd(start_dialog))
# H8 M5 \" W- N; Y. V  @1 S+ k(cond((= dd 1) (c:dia5b1))) Y% o# @" B3 w: o& k
((= dd 2) (c:dia5b2))0 g+ b5 @* T6 n7 L6 B
((= dd 3) (c:dia5b3)), w8 G* \: ~+ {/ N  K( l
(t (alert"未完成任何动作!!!"))$ R  Z* o& U/ z
3 ], o5 R: G$ Q) n1 R5 @/ M, E' u' a)+ G) I6 D+ j, x- C# d: o! C( n
(defun get_ww_hh()$ _7 h1 U8 V; L, [) K* R
(setq ww(atof(get_tile "kww"))); r! q% c, x5 \( E/ J
(setq hh(atof(get_tile "khh")))
$ V' X4 \0 \5 \+ M) ) P5 ~" J5 J7 [0 R6 a2 m8 d
(defun c:dia5b1()
+ O: J$ I- Q% X1 L(setvar"cmdecho"0)
6 ^  j: x: u, l! x(get_input_data)
' K, g8 P  J; U% c2 a0 Z$ v* g2 s8 X(command"pline"p1 p2 p3 pm34 pm pm14"c")0 n1 g( b: l9 S4 n, u- X
(prinl)
' z8 C, ~4 r" `)
: g6 A- \9 B: g& ~(defun c:dia5b2()
/ e% y$ Z- w8 q, n) N9 J& Z(setvar"cmdecho"0)4 U  ?4 Y7 L( T7 U  q" q' z
(get_input_data)
3 ?5 e* B; M& o6 D4 D& D(command"pline"p1 p2 p3 p4"c")0 \# g* J# Z% X  Z1 P- S6 r7 H
(command"line"p1 p3 "")
2 y3 o1 l/ P* u8 [(command"line"p2 p4 "")
0 @# ~7 \, ]5 U- J(prinl)
1 v2 X3 ]1 Z9 i)
" \" F* [& ]2 {# R, o  H* s; a5 S(defun c:dia5b3()
' ^( z- G; w1 q+ L3 `(setvar"cmdecho"0)! h# G5 S1 J% n% L. ^( ]& G% F6 S
(get_input_data)3 @  a: J5 Y; p: F. D
(command"pline"p1 p2 p4 p3"c")
2 Z" @# r  M/ n% V& J  Z(prinl)5 W6 `5 v5 h! R1 C0 u2 q
)  n/ A2 ?/ E4 e/ m
(defun get_input_data()
* w1 V7 _/ n+ M# [;;;(setq ww(getreal"宽度WW:"))
" Q6 E4 t( {+ L# [+ I+ R;;;(setq hh(getreal"\n 高度HH:"))+ e$ v. y* |  q# R3 h4 N; M3 `
(setq p1(getpoint"\n 插入点:"))
- D% t& J7 X  Y/ T; g(setq p2(polar p1 0 ww))0 b( G+ H1 m7 [* S# A+ c6 M% e
(setq p3(polar p2 (* pi 0.5) hh))
7 P8 V4 {, o( `(setq p4(polar p3 pi ww))
6 H) V! w9 L! u(setq pm(inters p1 p3 p2 p4))
5 z! m) o5 Q/ m) ](setq pm12(polar p1 0 (* ww 0.5)))
: G8 _3 s3 y% G) ?+ M(setq pm34(polar p3 pi(* ww 0.5)))
9 ?: i; k" D: a% p(setq pm23(polar p2 (* pi 0.5) (* hh 0.5)))
! O& Y! U0 U) l3 ?( L(setq pm14(polar p1 (* pi 0.5) (* hh 0.5)))+ n1 r, Q; l, I6 \/ b7 c: ]
" ]  `/ r" W% Y( R! QDCL程序
! Y' x. w' Z1 {; t- O3 y% jdia5b:dialog{
$ d" j8 f2 ]( L* h9 slabel="按钮测试范例";
2 a, |% B# _; i: M& g4 F7 M$ Z:boxed_row{
6 j. h2 h5 V% S1 n* Llabel="图形尺寸";$ o- M) p$ N; w/ O" |; \+ j
:edit_box{label="宽度WW";key="KWW";edit_width=8;}/ [; Y2 v  b8 o* P
:edit_box{label="高度HH";key="KHH";edit_width=8;}8 Q# j8 M2 Q7 S6 q9 S# ^
8 R. r2 x: t5 F6 @& i; z4 j:button{label="绘制DIA5B1-L型";key="bb1";}, X& i( D$ E6 |' u  M
:button{label="绘制DIA5B2-X型";key="bb2";}7 S% s# j0 h# e1 H
:button{label="绘制DIA5B3-8型";key="bb3";}$ O7 s& p* }+ s2 k$ F! t% U
spacer_1;4 C! b/ {" y  k1 l2 l
cancel_button;3 u( Y* |/ y3 y+ G& o
- B8 R" y3 z" S) L7 t4 R
5 B6 W4 V7 ^6 d6 V$ H! H# O7 r( \# a! U# p( r7 X( p
为什么加载LSP后在控制框里填上参数老显示错误: 参数类型错误: stringp nil 我都要崩溃了。谁帮忙看看啊
1 n! q( Z$ I# |( l
发表于 2009-10-7 10:34:12 | 显示全部楼层 来自: 中国浙江宁波
发表于 2009-10-7 10:40:09 | 显示全部楼层 来自: 中国浙江宁波
 楼主| 发表于 2009-10-7 11:36:30 | 显示全部楼层 来自: 中国北京
我弄好了 是DCL定义里的KWW KHH弄成小写就OK了 谢谢大家
