发表于 2011-5-24 12:49:28
来自: 中国江苏南京
本帖最后由 ok22ko 于 2011-5-24 13:08 编辑 A4 G+ l, b) V, T( t, ?
9 D/ b* W- G) g) J% J' |把这个工具修改了一下,更好用了。" X1 g1 s- v: l; Y0 R
7 U7 N4 C8 E& V
1,建立图层
3 n4 {% `9 H9 o7 x. o
' e. I4 {# v8 O! z* a) l$ c如下图所示:
, O. d5 `* f/ b
1 q) J/ n8 i# s6 X
8 \9 h# \( {4 c$ z8 {" k
+ o& P. |9 o" t% @2,把LSP加载到启动组里。
: G' d5 j# ]/ l/ G. y5 U ' m$ f& u0 P0 I7 }
3,使用方法,先选中对象,按 1 ,则将该对象变换到“1轮廓实线层”;按 2 ,则变换到“2细线层”,……8 C# }0 ^- I; f' m4 k8 r
& W% N& Z5 e( I# ?8 k) D* F# _- d
4,把这个代码贴出来,给大家看看2 h2 e+ c9 o% I, i4 J& x" k
5 v5 l4 E) d( y9 A8 ~6 i: Q+ }
(defun YH_chlayer (YH_layer / YH_S)
9 M8 P' R( P3 r e* R6 g- b- X (if (null (tblsearch "LAYER" YH_layer))5 y$ D& j q& r u' `
(entmake (list2 L5 h6 i& L8 n2 }2 p( W3 b# a) J
'(0 . "LAYER")
' a4 O: U- L1 `* a1 [- b% ?2 k '(100 . "AcDbSymbolTableRecord")
4 R+ T% w7 K: S) z '(100 . "AcDbLayerTableRecord")" t" u& k- a4 D4 b& \/ ]0 k
(cons 2 YH_layer) ;图层名称
D4 K1 q3 L" D& L* ^7 U '(70 . 0) ;图层状态; n! y% C, O" \& G
'(62 . "bylayer") ;图层颜色
- x0 ^$ @5 t; i5 z R6 J. k( K '(6 . "bylayer") ;图层线型
" Y; X- G2 W0 n )
i9 j7 E* m6 Z3 K )
+ a) N( R0 \% W+ a: e1 W )
- U) Y$ O$ V, D/ S6 S$ t (setq YH_S (cadr (ssgetfirst))), o) V9 L- n$ L0 y
(if YH_S! ]9 z% A# }2 W" l4 \
(command "CHPROP" YH_S "" "la" YH_layer "c" "bylayer" "")
% K2 a* t* `$ K/ o+ l- }; L# p (setvar "clayer" YH_layer)+ ?! a# B+ ?1 F' u
)9 Q1 S5 U7 q# O1 w+ [
(princ)$ W( c+ C0 \; m* [) Q
) l7 m- M2 f5 {(defun c:0 ()8 ` ~. M1 a9 P
(YH_chlayer "0")
2 ^" c* v; b' g- i6 q# } )8 t/ R1 F3 X# S! u, Q" Z( E. V2 }
(defun c:1 ()) y- E) A& v% v
(YH_chlayer "1轮廓实线层")
! s+ {# k7 {0 l5 {# H- w )3 {5 c6 n; L) K+ z4 n" t
(defun c:2 ()
) ` }9 ~" H( g. A0 v (YH_chlayer "2细线层")* c8 Q- k$ T- k4 Q
" c" U% e, Z: I W+ R(defun c:3 ()
- f# J6 @. `0 B# |7 ~ (YH_chlayer "3中心线层")
9 ~) z2 F5 G J0 `# m )+ } c1 W$ q! j- }3 j
(defun c:4 ()- v: H& l" W- X* w* W
(YH_chlayer "4虚线层")6 |1 m. Q f8 a3 s+ f4 @8 o) G
9 ?% Q3 G6 ]3 X+ O3 d7 m: M4 M(defun c:5 ()
_1 N+ E" |" V5 \: y2 k9 z, R (YH_chlayer "5剖面线层")6 l! F B" _& u4 C" g1 g0 I# @
)6 r* O% _/ U" ~" a+ l! q/ U
(defun c:6 (). x, b' [9 ?! C9 {
(YH_chlayer "6文字层")
j4 G5 ^* ?* `4 R& d% U )
2 K7 ]8 g# ]+ e* w(defun c:7 ()0 F# E; Y! y$ `6 b
(YH_chlayer "7标注层"), h8 k$ f- W* n' M4 a2 o
)+ k/ i# B( H7 M/ O R/ H2 \6 a8 a
(defun c:8 ()* C" \# }- Z6 a% C
(YH_chlayer "8符号标注层")
- L# R9 n3 U# Z4 p8 }" Q+ Y )
. H4 }- S% E; G% e( n0 }6 r( ](defun c:9 ()) s* I$ ]$ m# i! x
(YH_chlayer "9双点划线层")9 C1 m! u2 k7 c# L# [$ B4 `
)& v# d& I/ _5 Z7 N5 b* f6 L: x
4 |( m7 [: H8 S* A; r* c0 q, ?- c/ B4 _7 C' `9 q& z* c) p5 i
可根据自己的需要,可删减或修改红色代码部分,其他的别动!
- v: _8 _& s7 E& ], C$ S" z 2 ~- ~5 M/ r M; ~3 ^; }+ H
如果你想把快捷键2改成 中心线层,那你就把那段代码改成
1 B$ w5 k& d. \# F
: M0 _7 M: j2 l4 [4 n/ x2 j(defun c:2 ()
$ A6 A% I; M: F3 z6 _( p9 | (YH_chlayer "2中心线层")
$ X* e8 _6 k5 k" B )3 ]+ Y5 W0 w, w4 f- q0 ^
$ S: ~0 ]: W& u" V2 Z
然后把图层做相应修改,确保有“2中心线层”这个图层对应起来。. J# k3 _: b8 u2 \
* G# n- M, w. I1 l$ |# Z. L# \
- T/ N2 ~; x4 t0 D4 v6 F* E4 P) v
LSP文件如下,
. X0 J- _& q" F h F6 Q ?+ M, A* v
YH_chalayer.rar
(512 Bytes, 下载次数: 222)
