怎麼安裝COSMOSDesignSTAR 4.5:
# @$ ]; `( I/ b* S以下是安裝說明,但不明白。
9 ?2 b& u% y# I" Z. i+ t! o$ SInstall Notes:, ?' e- o9 ^7 }* W* U: w& p' y9 p
Run 'dssetup.exe' to install the program.1 p9 o) S. w0 `1 A' ~3 V: a
After installation unzip 'unzip_me.zip' to any directory, open LICENSE.DAT in Notepad or a similar text editor and replace "deadbeef" with your HD serial number the HD serial number must be in alphanumeric format with no special characters or spaces (so if your HD serial reads A123-4567, you would replace "deadbeef" with "A1234567"). Save the changes to LICENSE.DAT, then run SRACGEN and modify the license from the command prompt with syntax "sracgen license.dat" (both the gen and the license file must be in the same directory). Finally, copy LICENSE.DAT to the /LICENSE directory of COSMOS DesignSTAR. |
