Date: 29 September 2009 # G+ X6 [! C0 H" o! X) `
% F1 `6 S9 l4 y6 ^2 mSubject: Maintenance Pack 1 for NX 7.0.0 , P$ Y' J' n& S+ v9 r4 d% D+ p! j
5 P% r. v q) Y7 c9 r To: All users of NX 7.0.0 . u/ @" @! v. K, T1 B# @2 Z! g3 T6 B
. ~# F6 b: }* _9 U. k# n2 A# k) a0 B! V1 o
7 N! i3 ?% d* q7 C# [, \, s& L5 R$ H1 U" B4 s& f) ^4 B7 ^
We are pleased to inform you that fixes are available for the problems listed below. A maintenance pack (MP1), built for installation on top of Windows XP32 and Windows XP64 images of NX 7.0.0, can now be downloaded from the Siemens FTP server. This maintenance pack fixes an accumulation of problems listed in the tables below.
% D( d8 S Z4 j: L+ Y& E; x. C2 a- ^7 ^4 N2 d 0 B# |9 h" W5 X4 L, D
4 q6 F3 Y% O! B: ~* T! q
* @$ u4 [( ]2 { m3 n7 k* |Release
) T1 j0 f, a4 Z* g$ U. Z O9 _& N) V* _ | PR Number
/ D7 a# n8 @( Y) }% m! E | Problem Description
! E2 m; G+ r4 C | MP1
( h5 [7 ?2 H) ^8 Y' O | 2127947 2128621 2129923 2129275 | The problem in Teamcenter Integration for NX if "Check-out Policy" was set to "Manual" assemblies failed to save is fixed. The problem in Teamcenter Integration for NX where the "Save Assembly Hidden Line Part" command did not save the Part Name and the Part Description attributes is fixed.7 v6 _6 Y5 w% i" {) n
$ U! E& f( J& a2 D% p | MP1
# \" Q N( B' b& P) c2 n9 {* j | 6189561 | The problem in Shape Studio where the X-Form dialog selection was not showing the text for options is fixed.1 t- N/ q9 Q* e( ~6 y* s& X& s1 } q1 A4 n ]4 v
| MP1
9 f! ~) z1 g9 ?' B | 6192252 | The problem in Section Analysis where the selection options "Rectangular Select" or "Select All" did not work when the poles were displayed is fixed.! L- O% V( m& v5 M( O5 k
( o# g4 `5 J7 c5 n6 V | . _2 N- ^ @% P; m& `2 _1 z ]
: C. S1 H( P: @1 y2 U0 N" t" Q. D) B
: T! a6 j) V; f( Z8 N& e
( d! O/ [9 f& B, {) O/ JWindows update instructions # a' e; I+ W+ E0 C+ K# j7 k2 m8 t" n
* z( b/ s+ g( { k0 v1 s+ [% E2 Q: k- P The files contained in nx-7.0.0.9.mp01.zip are provided as replacements for previously installed NX 7 products. / w0 P- [/ q! X" Q: d- A
+ w, p8 H: o( ]1 W, m- _( {4 f$ k
$ ^. b n0 O( ~5 A! S, A0 o For the Windows XP32 platform, you should have at least 930 MB of free space to unzip this file.
$ x# r k; ?3 t, L" y8 D3 V! {8 k/ A. d" R$ ?. a6 x3 t K2 \' o3 |# b# d
8 @, m `. O" y; \ For the Windows XP64 platform, you should have at least 1.11 GB of free space to unzip this file. 5 F" k0 T' d' W! l4 E5 R1 u9 x/ s/ v
" p& W( y( q& d7 {- H* g7 j
/ Y' H$ T& |; @ U2 A( E6 o% ^3 A7 aVersion NX 7.0.0.9. must be installed before updating to version NX 7.0.0.9.mp01. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.
+ O+ \, A. R! h0 W T L: S0 C; a! x 9 `4 N8 A; T% X1 H3 x4 z/ C( Y6 F/ i
B6 Q J8 i, r6 t5 [% U% T- c To use this update, change to the directory where you unzipped the nx-7.0.0.9.mp01.zip file, make sure the entire set of new MP files have execute access.
! `, d$ t& J+ Z% P, r8 F4 ?8 p0 c' X7 Q2 t% v. s/ p( X # X- x7 k' Y Z |, M
; N: T ~' j2 J" }# D8 Y) K 4 l/ N) L( g( Y+ w) r0 \, N( y# p5 {" j0 W
Then do either one of the following: $ L7 \; O B( c8 y/ L/ P& o. B3 s" S+ f1 ]
1. Run 'run_ugsupdate.exe' " X6 o' \7 p1 F
3 T, x/ I: Q7 i This will read the %UGII_BASE_DIR% from the Registry and apply the update to the NX 7 folder. : i3 g( `( _" ^ x8 [7 P3 x5 Y8 ^& s* f
) s; j1 q% B0 T; b
2. OR, you may follow the instructions below to run ugs_update.bat directly. , b: O5 o+ b6 u4 ?, Z! ]. Q& c# e( |( K% a6 `* \+ _
Before running the script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 7 release or set to the appropriate installed directory on your system. Then execute the 'ugs_update.bat' script. : Y% b2 d9 p d" U. ~
: {/ X0 V0 q' ?$ F) k0 P+ F3 y; G1 v. O: o2 a
0 d' h C0 n; F" G* s4 Z1 kFor example:
( P" C# ~. X' W1 _4 j5 J' s! I2 J! P+ D5 m6 F" Q) z5 u & T9 r* X2 q) r2 e3 \1 N, E6 E: ]" K1 D+ I9 O. z
set UGII_BASE_DIR="C:\Program Files\UGS\NX 7.0" 9 n5 a; O1 @+ u) }3 n7 m
. `+ |. w, d6 j, q+ \% |6 X5 U+ @
3 [. C+ w. c `8 ?, V3 s! \' W3 h& |cd NX70_mp01
* T5 Q- T' b( z" ^0 M6 W/ `; v X$ t( E5 _ ugs_update.bat /v
5 W! X7 g9 i+ z" T5 r. \ T5 Z; K% p7 g8 J9 \ s, \6 A G/ k% H' J
: B4 A0 ^8 B7 e' S) w, L: WThe script supports a "/v" switch to turn on verbose messages while doing the file updates. The default operation of the script is non-verbose.
1 l' j, D ]* A7 g8 D* s2 B! f' \, u& }1 H3 p* X1 `6 v/ ? _" ~) S5 H; \8 z8 G, y/ M
& d5 I, Q0 |$ R" k8 YThe script supports a "/d" switch. This will turn off the script , K7 \) {9 c, ~0 C
% {: S2 O/ _' M2 B! Wconfirmation prompts. Useful for running the update in a batch job.7 @" X6 V# |' p7 P. ^$ L
: X9 Z2 {' @# |' J1 |7 Q. x# ?- m0 e" a5 U) U3 D
2 J! o* {9 N% m+ c' `3 {The script also supports a "/p" switch. This will turn off the initial 4 ]: M( u& P) e" H7 B& o) M6 f& {& j, Z. Z5 D) d
confirmation prompt but it will display the final 'done' prompt. This is useful for running the update in a batch job where a final prompt is desired. ) N9 n2 V' |) x6 ~5 n @7 o0 E/ {# X
! p2 l( i# | M9 D# U
7 r6 `5 r( @8 s$ e$ Y% ?& K) z E6 _* N1 }$ z9 g+ P6 `9 M
- E6 o y5 [! X [7 l m1 a
/ o- c% @ T. k% l* C% K$ X6 M) I( w/ `
, A& t: O9 f! \8 @; s3 \5 O1 B) U* Y$ l; U- c) i. T' D
7 v' B' L4 ?4 B6 G/ A0 F, q6 I m0 J4 ~& D. @3 Q# e- X, g& Y$ V& \- m, t& c7 B/ O
4 A3 [; L7 N, p, d) ^: d, N9 ~4 f j' N ^" k' f
, u* B& c. r, e! ]" t5 Q2 N n1 r. n
7 P2 @* ?* c% |. f% W6 d5 Q+ h' g2 y) Y9 ~" J; j, @! I# T( D) E3 r) d4 |. |
0 L+ E9 C+ M) u$ {6 O) T9 }3 j+ S ~( p After the MP update has run successfully, the following identifying text will be written into the system log of every NX session:
& Q% c0 Y# E. A1 ?# B7 W, G1 |% [$ e+ P2 D* k: T4 P 8 R w) p( I# @+ V
% v: D1 ]- B; p6 A " G8 W4 f3 V3 a; q3 Z# t$ z+ ~( ~ A$ y
"NX 7.0.0.9 MP1, 29Sep09. See Maintenance Pack letter for detailed list of fixes."
/ _- {4 w* k/ u7 _+ c$ n* i% Z. x3 a, A0 L# q; `4 H4 }
; r4 p6 a; l) Q. \. |8 a; \6 W2 j' y* k If you have any issues with the installation or support of these fixes, please contact your local GTAC support group. , }# a- y4 ~. M
( Z [- P, |9 q. _6 q . ~1 v! W9 L% @; L
7 b5 J* v! Q, f9 o ) l2 [0 \9 K/ u( Y# i, `$ I
5 K; W4 H$ E4 ~; E6 n& s! D( J- tSincerely, " K! \6 Y3 Q" b: t M7 i9 _+ i6 N1 ?+ E5 b9 R$ S! {' u' _
7 c1 a8 _( u( ]3 i: S7 U8 O
( q5 M! I$ V% F* P, F" X, h5 _ The Siemens NX Team |
