发表于 2009-10-24 07:48:52
来自: 中国
) T0 c% ?, G3 a0 \/ o) Y! U' ]0 F
就是这么复杂,呵呵+ ~9 X0 {$ e" u9 }1 ?1 ^
我这里用API可以做到1 I) ]7 ~4 n6 }. r" p4 U3 O
$ P2 g' N1 h4 v% }2 h) ~- Option Explicit( g w) ~1 [( H8 W5 v( o8 w
- 'Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long- G$ J7 d+ l( n3 }& V4 ^8 L
3 H7 t" n8 S6 |$ }4 M. b( @$ C- Private Declare Function CreateToolhelp32Snapshot Lib "kernel32" (ByVal dwFlags As Long, ByVal th32ProcessID As Long) As Long
, U. R1 l; Y! x1 E) g - Private Declare Function Process32First Lib "kernel32" (ByVal hSnapshot As Long, lppe As PROCESSENTRY32) As Long
* ?$ W) p+ ^5 E' v - Private Declare Function Process32Next Lib "kernel32" (ByVal hSnapshot As Long, lppe As PROCESSENTRY32) As Long: z4 ~; C6 |+ y* S: J: b
- Private Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long! F* j2 K2 E( u7 C p$ M
- Private Declare Function OpenProcess Lib "kernel32" (ByVal dwDesiredAccess As Long, ByVal blnheritHandle As Long, ByVal dwAppProcessId As Long) As Long
& \8 X) `! k$ o' U - Private Declare Function TerminateProcess Lib "kernel32" (ByVal ApphProcess As Long, ByVal uExitCode As Long) As Long- o% e; f# r) d5 y
- 3 e* N, |7 @ q8 o8 r
- Private Type PROCESSENTRY32
' h$ m$ i- h2 K6 R. S$ R - dwSize As Long! I" h/ V% A" v& ?, Z3 Z( g
- cntUsage As Long
3 t/ k5 ~" l! v, d. Q4 @ - th32ProcessID As Long0 b6 P' l& H J& q
- th32DefaultHeapID As Long0 w! {9 R3 y0 m' w; L6 z5 T/ h3 S
- th32ModuleID As Long
) e0 I" }8 s+ o, e& @5 a - cntThreads As Long
8 h, q! A+ Q4 f2 z4 x' w - th32ParentProcessID As Long4 v9 w8 d! x7 S$ b
- pcPriClassBase As Long
- X% w# H/ h3 x' c+ V% _2 { - dwFlags As Long
* V% W3 @, E8 k" P - szExeFile As String * 1024
9 c* Y; W( E, x6 a - End Type
1 A) K2 U: c, X$ z- {& L% \ - 4 \ `$ A$ f) j) `' t/ C
- Const TH32CS_SNAPHEAPLIST = &H1, ]: Z1 e8 t' x: u, \
- Const TH32CS_SNAPPROCESS = &H2: V% B4 {$ J+ M* K- F
- Const TH32CS_SNAPTHREAD = &H4, {3 w/ |) c8 q: v, n1 K
- Const TH32CS_SNAPMODULE = &H8
. Q0 Z: R3 F9 K - Const TH32CS_SNAPALL = (TH32CS_SNAPHEAPLIST Or TH32CS_SNAPPROCESS Or TH32CS_SNAPTHREAD Or TH32CS_SNAPMODULE)( |4 h' C& o: x: }1 V, v' F2 c
- Const TH32CS_INHERIT = &H80000000; [0 ^2 L& n: t# l! z5 n+ T0 k8 |
. s$ j. Q' k# y* ]5 X- Sub A()
( n! x, m9 Z' \4 J0 k' d - ' ShellExecute Me.hwnd, "Open","C:\Program Files\Support\mydrawings\xoec20091022100807.mdi" vbNullString, vbNullString, 1
; P" e2 v/ w! g1 ~ - Shell "C:\Program Files\Common Files\Microsoft Shared\MODI\11.0\MSPVIEW.EXE" & " " & Chr(34) & "C:\Program Files\Support\mydrawings\xoec20091022100807.mdi" & Chr(34)1 f* j' x5 S( T( M! b% W$ j
- End Sub F1 I. A; ~% x. e
# Z" F' F5 V& ~+ ?# R$ l - Sub B()# `) i. e/ c, E% g- r6 B- i
- Dim My As PROCESSENTRY32
; Y$ V4 p& y& L- [ s L! s; b9 ^. p - Dim Pid As Long! F9 J, x# o4 F7 R$ z
- Dim L As Long
' ?( w: k8 [* f6 G1 c3 Z6 f) G - Dim L1 As Long
: z. u) w' f' N8 k - Dim mName As String# D) I( @4 }/ s4 N2 q
- Dim I As Integer
) q2 @; T8 ]7 j, P0 K& z5 U# d2 u' Q - $ a$ i! B: n, _+ e, j7 f# S
- L = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0)
' T$ @8 g) t: ?% t" ?3 o - If L Then
# \* y* i; W- W% F. z2 Z! F - My.dwSize = 1060
: C- q2 _" u8 l1 ~1 X2 @ - If Process32First(L, My) Then '遍历每一个进程* \& n: l4 `) n% ~
- Do
1 B; r; C/ S0 a4 L( T - I = InStr(1, My.szExeFile, Chr(0))
8 i7 ~& j; @2 D( J - mName = LCase(Left(My.szExeFile, I - 1))9 Y% A( ~) W# V; s
- If Trim(mName) = "mspview.exe" Then '这里填你调用的程序进程名(小写)7 M# Q8 n' h$ P* h0 F1 M, f
- Pid = My.th32ProcessID
" M J* V, J/ ~% c8 P+ |/ ? - Dim mProcID As Long
+ B/ e7 o+ v- A0 a7 J6 j; ] - mProcID = OpenProcess(1&, -1&, Pid)
$ _. v0 t5 }8 w) N6 @- ]7 g+ p - TerminateProcess mProcID, 0&
$ Z s( W" D8 }8 Q) t% g3 ~ - Exit Sub
' `# A* ?% O3 K9 i8 F - End If
6 R, v- {" {, y - Loop Until Process32Next(L, My) < 1 '遍历所有进程直到返回值为False3 @- W, n, @8 s3 y( m, r9 J
- End If- D. `; o8 M' e) q
- L1 = CloseHandle(L): x: O. W5 Y4 J; B% p
- End If
7 {! j5 Z5 l: }/ u( S3 B - End Sub5 [) l1 R7 M( ]
复制代码
/ s1 I" P7 s6 E( h- D代码中过程A用来打开文档,过程B用来关闭“mspview.exe”程序。很复杂,但这是没办法的事,在代码中关闭“mspview.exe”恐怕只能用API。只是我没有用过网络版操作系统,从你前面的帖子看,可能由于系统的区别,这段代码不一定适合于你。不过网上关于用API结束进程的文章很多,应该有适合于你的。 |
