转载自:http://www.eng-tips.com/faqs.cfm?fid=507
6 A) X7 E" f9 H原文: Y* `& B% k! U* L5 r
1) Close SW(关闭solidworks)- h8 d0 J" H. t5 C6 W7 X# O5 a
2) Click Start\Run and type
% \& ?: R. @; i0 V3) Go to HKEY_CURRENT_USER\Software\Solidworks4 ~& o( v5 M4 i' }7 ]4 w
# e% U: \4 X* J- @4) RMB the Solidworks directory and click rename.
% n' r+ L* z' H6 v9 p- O5) Rename it with your Initials or something.
; G4 M) j% S8 H; g# T( L9 k6) Restart SW, you will have to accept the license agreement and reset your toolbars and tools options. Before you do that, see if that fixes any problems you are encountering.# R! T1 \: m* J
7) If so, Close SW, then go back to your Registry and delete the Solidworks directory you renamed. (if you push f5 (refresh) you will see a new Solidworks directory appear)./ c" w: O) H) t" I* b+ J4 R
8) If not and you want to keep your old settings. Then Close SW, (push f5) delete the newly created (别删错文件夹!!!!保留设置的是原来你改名的那个文件夹.我删错了 :L )
+ n2 E9 {5 _9 G4 n& ~5 |( GSolidworks directory, and rename the other directory (that has your initials in it) back to Solidworks.
! a6 F9 G/ s# N
- L" F: M7 g+ t/ fIf this doesn't work, your last alternative maybe to Reinstall SW.
) Z: q6 b& P: K6 Z3 r
6 m+ b; `2 c2 T$ \; C* ], D- a- [6 P* H' F* J' r. }1 S1 E
注: |
