楼主 |
发表于 2009-11-24 23:35:47
来自: 中国广东东莞
FORM BLOCK' l/ J @3 k7 t! w' X( O" w0 v
DELETE BLOCK
& f* i- D* K4 f1 r- x+ z2 F( \EDIT BLOCK ALL UNLOCK
$ S, R/ e% i0 U l% e/ K, G0 qEDIT BLOCK RESETLIMIT "8"
; x- Q, {9 @+ K* H; y5 n6 z& QEDIT BLOCK RESET2 Z: O* I* I- G% ~3 y
EDIT BLOCK ZMIN LOCK
+ C% S" u# k* U; A; \" j" EEDIT BLOCK ZMAX "31.0"" t% X4 c- g/ V$ N( O
EDIT BLOCK RESETLIMIT "8.0"
! j) w* e9 o' v E; W* qEDIT BLOCK ZMAX LOCK
1 f0 T9 c m! }3 I; K* ^7 tEDIT BLOCK RESETLIMIT "30"
/ q* |# h' Q6 A. r# Y* M0 l/ iEDIT BLOCK RESET
% |# U% H: y' O1 B% q9 A0 u$ HEDIT BLOCK DRAWMODE 0! Y, ~4 ^) K' d1 V% I0 D v3 F
UNDRAW BLOCK$ ~) u, Y6 ~1 w" A. P6 }4 X
BLOCK ACCEPT4 l' h; }% J+ v& j. E" N- M2 r
EXPLORER SELECT Tool "Tool\R刀\R3" NEW' |$ m, t1 {% ~! |/ D
ACTIVATE Tool " R3"
2 g& h( E/ m& T( gCREATE BOUNDARY ; SELECTED FORM BOUNDARY9 y' Z7 u0 E3 q; ]5 k8 Q0 h
EDIT BOUNDARY "1" SELVERTICAL UP9 v; S6 x8 {/ I4 t) M% c% R4 d, g
EDIT BOUNDARY "1" TOLERANCE "0.01 "/ K2 K& N% N4 P
EDIT BOUNDARY "1" THICKNESS 0
# R7 k; Q! \$ w6 |1 O# P9 GEDIT BOUNDARY "1" THICKNESS -0.07+ l n6 h" x3 w3 y: r! }% M
EDIT BOUNDARY "1" CALCULATE
( S/ c$ W' u& mEDIT BOUNDARY "1" SURFACES ACCEPT BOUNDARY ACCEPT
" Y5 a' T$ y2 N; ^EXPLORER SELECT Boundary "Boundary\1" NEW+ w. Z/ ]$ U! }- v: q, k2 r
RENAME Boundary "1" "a"
- ]- w( r% W+ }: t9 f- h( jEXPLORER SELECT Boundary "Boundary\a" NEW; g! l( R0 D6 b, C) l K
EDIT BOUNDARY "a" 3DOFFSET4 S* X2 \- u2 ?6 ?3 A. r2 r( b
0.5
: D) Q+ `' C- x8 D$ Z- z! h1 N: qIMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI! n: S/ f# S6 s5 ^7 w
"Finishing\Raster-Finishing.ptf"- X8 n* B$ a" E2 i7 u# U
EDIT FTOLERANCE "0.01 "; w5 G9 y |3 _# a7 [2 Z
FORM FILTER
+ F2 _" o4 \, i4 a5 y* D8 d `EDIT FILTER TYPE REDISTRIBUTE
L2 U! g' q- \" `EDIT FILTER FACTOR "0.1"
7 s( i# R4 B' ]( t7 p; B$ hEDIT MESH TOLFACTOR "0.1"
! B# H, Z+ [- b" v1 I" vFILTER ACCEPT
4 U7 C7 T& i( g6 E9 F+ n* [EDIT FTHICKNESS AXIAL_RADIAL ON
* |4 L1 y6 t8 V0 c; ~ q; z5 u$ FEDIT FTHICKNESS AXIAL_RADIAL OFF
( j$ E$ n' O; |' [% zEDIT FTHICKNESS "-0.07 "
3 L, x: T1 m) ]( f$ z& P; }EDIT FINRASTER STEPOVER " 0.11"
0 Y5 Y& a/ w7 X) _5 ~FORM LEADLINK# }" q- n$ q( B k- ?" s2 L( b
EDIT TOOLPATH LEADS INCREMENT_FROM_STOCK N
) M( n/ P4 h3 \3 Z* A8 lEDIT TOOLPATH LEADS PLUNGEDIST "1"( \3 G* h* H, Z! L9 [
EDIT TOOLPATH LEADS PAGE FIRSTLEADIN
. T6 w; H8 v% W# UEDIT TOOLPATH LEADS PAGE LEADIN' @. ^) G& q2 C
EDIT TOOLPATH LEADS PAGE LINK
- Y4 j0 d# `( ?) a( ^! |EDIT TOOLPATH LEADS LINK SURFACE- {- O! L' M: z* a4 w6 D' U! [
EDIT TOOLPATH LEADS LONGLINK SKIM3 E: c% P4 Q: o) J2 V2 G
PROCESS TPLEADS
g% A( p/ E; Q" {& tLEADS ACCEPT
3 P5 l9 d4 p# O* o: s6 S: aEDIT FINRASTER ANGLE " 45 "
% `/ L/ P* ?+ w, ]; [+ @EDIT FINRASTER STYLE TWOWAY
0 G' h3 v6 Y4 n" hEDIT TOOLPATH "1" CALCULATE. D% O' R& |7 y T
FINISHING CANCEL
- t. e" d: m. qFORM TOOLZHEIGHTS3 S8 J; @3 D: b; H& l
EDIT TOOLPATH SAFEAREA RESET; t* g$ ~0 a# f& U4 B7 o: s
RESET TOOLPATH RAPID" o! E. L5 ]8 n/ @
TOOLZHEIGHTS ACCEPT
/ L2 F8 H2 D5 j& Z8 C6 [: w0 cFORM FEEDRATE# S# ]* M! H1 R9 g8 U4 X3 V. s' ?
EDIT RPM "18000"
; j% J* A3 x2 b- Q- @4 {EDIT FRATE "2000"
! L, W" M5 k2 Z; |( f9 k7 k9 T: BEDIT PRATE "2000"
6 t0 o, Q, R( `! g4 IEDIT RSPEED "5000"& ]9 j* S1 z8 w) O( r
RESET TOOLPATH FEEDRATE
- ^2 R' U7 l# XFEEDRATE ACCEPT
$ ], `. S/ E+ M5 bEXPLORER SELECT Toolpath "Toolpath\1" NEW
K9 I9 h3 ]" k8 N1 YRENAME Toolpath "1" "曲面平行加工": e( ?" J* q2 R* K a% A
EXPLORER SELECT Boundary "Boundary\a" NEW) ^4 Y% R& w8 M* G
DEACTIVATE Boundary3 e) e4 t6 B; P( K2 ^% [
6 m+ i" b9 d/ G) U9 J2 h
6 G/ N" r; b, F8 F8 N. a$ ~, s
$ c! ?+ @9 J/ j( d- \& k* I/ F9 U4 X% ?: x红色字为变量,我希望可做到,运行到变量时,手动输入,值!麻烦你了,版主好人! |
