发表于 2009-12-1 14:04:33
来自: 中国山东威海
英制与国际单位制的换算2009年09月15日 星期二 上午 07:401、长度单位
- R7 ^' F8 L5 o. Y: F4 O1 in = 25.4 mm 1 ft = 0.3048 m; |9 Y" f+ n& b1 Y! C
1 mile = 1609.3 m 1 micron =10-6 m
6 p6 {9 P9 z* ^2、质量单位
! R8 P4 x. V0 @+ g1 lb = 453.6 1 cwt = 50.8 Kg 1 ton(imp) = 1016 Kg
: ~% W. ^6 D( `% h+ Z1 top(up) = 907.2 Kg 1 tonne = 1000 Kg 1 r" y/ v0 S2 d6 y$ T' k
3、力矩单位 ' y) ], R4 x. S; I9 G% M. i# X( Z
1 inlb = 0.113 Nm 1 ftlb = 1.356 Nm& v8 J, H0 V9 x+ s, d# S
1 kgm = 9.807 Nm 1 ft poundal = 0.0421 Nm
# Y0 d, h! N) n" ~4 {4、温度单位 3 q% W8 M/ g# k9 r$ v
(? F- 32) x 5/9 = ? C K-273.15 = ? C
; ^8 A# R/ m8 R6 W( {8 @2 o5、功及能量单位
8 L/ b. s9 l4 y3 i, V/ y; b0 K& U1 lbft = 1.356 J 1 Nm = 1 J$ }6 V( I- k( x) W2 {0 A+ P/ a: ^
1 kgm = 9.807 J 1 kW/hr = 3.6 MJ) |+ Y7 w! n7 K4 x4 P- x
6、面积单位 - t* T4 Z5 T6 ?/ Y: i: ]8 |9 M, {+ |
1 in2 = 6.45 cm2 1 ft2 = 0.093 m2& V* f% O& _# p1 g* P K
7、压力单位 ) N4 T! Y4 C- u) i- O7 I
1 psi = 6.89 kPa 1 kgf/cm2 = 98.07 kPa
( `7 \$ e4 w O; `- r7 ~) l9 b! k1 bar = 100 kPa 1 bar = 14.5 psi
4 H# @3 m: z' i% E; r1 atmosphere = 98.1 kPa 1"(STANDARD) = 101.33 kPa
* Y9 h: `3 R3 P5 |1 cm water = 97.89Pa 1 in water = 248.64 Pa
! H L# x. W! g' k: ]1 mm mercury = 133.3 Pa 1 in mercury = 3.39 kPa
/ N \$ P2 r, }8 E1 Torr = 133.3 Pa 1 ft water = 0.0298 bar g6 @5 Z) k) K5 t+ d! ]
1 bar = 33.33 ft water 9 J( h) Z A5 n D' n; n& s9 M/ P
8、体积单位
" a$ s! J& z: _6 P7 X/ t" B4 H1litre = 0.001 m3 1 cu.ft. = 0.0283 m33 {8 M u) ]9 d6 X) A
1 cu.in.= 16.39 cm3 1 gal(imp) = 4.546 L
# F* D1 Y4 B( j$ v+ Q) |( t( [1 gal(us) = 3.79 L 1 fluid oz.(imp) = 28.41 mL; ?! H1 X; x9 {0 e: d0 x- n
1 fluid oz.(us) = 29.57 mL # l3 i" b% D# ?; f
9、力单位, V1 i2 Q+ r! w1 _, f: W7 U
1 lbf = 4.45 N 1kgf = 9.81 N 1 kp(kilopond) = 9.81 N
: F6 C& ~9 k$ c9 \0 \1 poundal = 138.3 mN 1 ton force = 9.964 kM
, z' A( t3 y* a# s2 |5 P10、功率单位(功/时间) 5 d0 H9 g5 z2 @" [9 [
1 lbft/sec = 1.356 W 1 kgm/sec = 9.807 W 1Nm/sec = 1 W5 k/ }1 }9 s3 j9 D; S, @$ J+ T _; H0 D
1 Nm/sec = 1 W 1 Joule/sec = 1 W 1 H.P.(imp) = 745.7 W
' F9 k e: j, [" S- X% p11、流量单位) O% P* s) C: L4 r8 L+ O! J7 Y
Cv值:水流量(US gal/min)于60? F下,流经差压为1psi之阀门而所得出之流量定值。( Cv X 1000=l/min ). B) ]$ E1 \; R/ Y% Z: t
kv值:水流量 (L/ min)于20? F下,流经差压为1kgf/cm2之阀门而所得出之流量定值。
N! x' B% G1 m2 _6 [" eKV值: 水流量 (m3/ min)于20? F下,流经差压为1kgf/cm2之阀门而所得出之流量定值。2 o7 h. s. X, |) r1 @' ?' c
S值:气动元件有效截面积(mm2)( q, \2 b- R) v# K& e3 T
流量系数之间的转换:
2 E k5 t9 Z0 N) ACV = 1.17 KV S = 18.45 CV0 s2 o2 {1 X1 F+ R
S.T.P = 标准温度及压力 (0 ? C 及101.3 kPa绝对压力)4 s! k. W1 Q! B
N.T.P = 正常温度及压力 (20 ? C 及101.3 kPa绝对压力)1 C. j( B4 D' D4 R( A
M.S.C = 公制标准情况 (15 ? C 及101.3 kPa绝对压力)" G9 a. @# A# _- O5 M
ANR = 温度 :20 °C及相对湿度:65%5 Q8 f' [9 l1 M P& X
12、等值换算
( P* _. I: p, m+ r! A1 psi = 6.895 kPa =0.07 kg/cm2 = 0.06895 bar = 0.0703 atm
$ V" O9 Q4 k) O+ P8 `1 standard atmosphere = 14.7 psi = 101.3 kPa = 1.01325 bar& \; i" i6 B# w2 t* L
1 kg/cm2 = 98.07 kPa = 14.22 psi = 28.96 ins mercury 1 ~5 I$ o" O3 M5 U+ n8 a& |
1 ft lb = 0.13826 kgm = 1.356 Nm
5 J$ [$ K) v' C% S$ R1 L = 1000 cm3 = 1.7598 pint = 106 mm3
/ z3 Z" Y! K" ?8 W4 |2 ?7 {: i1 tonne = 1000 kg = 0.984 ton = 2205 lb# N6 ?: R; p) i( m, g, a a. D! d
1 m3 = 106 cm37 C2 M. f6 u) P: L( R) d
1 cu ft/min = 0.0283 m3/min = 28.3 l/min" t3 ]& i3 P. {! p
1 Pa = 1 N/m20 c% H! `# J7 b' K* u; S
13、单位缩写 ; D+ m9 ~) R( B5 ]0 s& X
单 位 缩 写 单 位 缩 写
. K7 ]2 i: N) D( DPascal Pa Newton N2 A" [/ q, Q0 _! s; J
metre m litre L' d! O' V3 J( Z5 M1 h0 I* p
Watt W Newton metre Nm; Z+ ]6 A( {- I! W" T9 w6 w$ ~
Joule J Megajoule MJ* Q, e( r M& [, V# v. M
° Kelvin K 4 S# w! w ?! R7 e7 C( D
, V8 A% E) O! M, t+ ? w$ m; w8 X: p0 y7 d/ A# i _
单位换算关系
/ E- g) i' j4 k% j长度单位:1 毫 米=0.0394 英 寸 $ F, f2 O$ a. k5 @# U% ~+ a9 k
1 厘 米 =10 毫 米 =0.3937 英 寸
' C& I% L/ _0 D2 D0 o& t# x0 [$ j) c$ o& G 1 米 =1000 毫 米 =1.0936 码
) @0 I& _# E( s 1 千 米 =1000 米 =0.6214 英 里 5 ~$ s& Z( z$ A8 ^
面积单位:1 平 方 厘 米 =100 平 方 毫 米 =0.1550 平 方 英 寸
/ Y; D2 |/ A8 v* G) w6 @ z 1 平 方 米 =10000 平 方 厘 米 =1.1960 平 方 码
" f6 e5 B3 D# h' v 1 公 倾 =10000 平 方 米 =2.4711 英 亩 H+ \, P( C: j; x
1 平 方 公 里 =100 公 顷 =0.3861 平 方 英 里
0 Z, p# [" w$ ~5 M6 \4 Z8 c容积单位:1 立 方 厘 米 =1000 立 方 厘 米 =0.0610 立 方 英 寸
' }1 Y3 R( y$ { Q: x5 R' j 1 立 方 分 米 =1000 立 方 分 米 =0.353 立 方 英 尺
2 }+ J$ H$ [$ @( e v 1 立 方 米 =1 立 方 分 米=1.3079 立 方 码 $ P/ y6 a; }8 r6 _
1 公 升 =0.2642 美 加 仑 $ N+ x; A" }2 X) E( g+ v
1 公 升=0.2200 英 加 仑 , u9 p; x8 |5 p
1 百 升=2.8378 美 蒲 式 耳
& O. F4 I7 J* u5 s( k, S4 b 1 百 升 =100 公 升 =2.7497 英 蒲 式 耳
. B' E& _' `, Q2 }重量单位:1 毫 克=0.0154 谷
8 ]( ]( N; d) {& ~: N V5 K3 `( ~ 1 克 =1000 毫 克 =0.0353 盎 司 $ Z* g* W; y7 F L7 _) b
1 千 克 =1000 克 =2.2046 磅 2 Z/ j/ W1 D( @. b
1 公 吨 =1000 千 克 =1.1023 美 吨( 短 吨)
5 n# | |, J4 b5 u0 S: A1 k! B5 V 1 公 吨=0.9842 英 吨( 长 吨) $ b2 v% u, D* p$ I- s- H
英制单位换算
$ ~, c& C/ O5 R0 r- ^; E# z/ ~) d长度单位:1 英 寸=2.5400 厘 米
( u9 j1 o2 C# g% O5 r3 A 1 英 尺 =12 英 寸 =0.3048 米
4 J' G' r7 j' g# X7 d 1 码 =3 英 尺 =0.9144 米 ; h+ ^$ ]/ o! x
1 英 里 =1760 码 =1.6093 千 米/ q( M! i4 W4 a* F
面积单位:1 平 方 英 寸 =6.4516 平 方 厘 米
# \7 Y+ F/ n" C9 g 1 平 方 码 =9 平 方 英 尺 =0.8361 平 方 米 7 b0 G# ?! t1 @0 ~' N- `
1 英 亩 =4840 平 方 码 =4046.86 平 方 米
# y6 W+ f, T# W% g$ h 1 平 方 英 里 =640 英 亩 =259.0 公 顷6 M8 C& W6 D0 J8 L
体积单位:1 立 方 英 寸=16.387 立 方 厘 米
; ~& T3 l: U# ]* r$ s2 j/ w5 I 1 立 方 码 =27 立 方 英 尺 =0.7646 立 方 米 美 制 干 量 7 s6 V. [4 a; t. ^" j+ Y- H
1 品 脱 =0.9689英 制 品 脱 =0.5506 公 升 ( W9 ?' O" }, ?. \" Y
1 蒲 式 耳 =64 品 脱 =35.238 公 升 美 制 液 量
) a. X" X9 ~8 U5 O! g 1 品 脱 =0.8327 英 制 品 脱 =0.4732 公 升 9 f3 \0 f! k0 }* }! Q
1 加 伦 =8 品 脱 =3.7853 公 升 英 制 单 位
+ _" {4 u4 o) A 1 品 脱 =1.0321 美 制 品 脱 =0.5683 公 升
* h) ?3 b& ~7 ~ 1 加 伦 =8 品 脱 =4.5461 公 升 + E& z4 Z H; X3 l1 |7 r
1 蒲 式 耳 =8 加 伦 =36.369 公 升1 z1 Q' G. y: t/ {- C1 u
重量单位:1 盎 司 =437.5 谷 =28.350 克
. B9 q4 }) j8 C3 o5 l) u: r9 i) e 1 磅 =16 盎 司 =0.4536 千 克
i4 v* F- I3 ~. G 1 美 担 =100 磅 =45.359 千 克
W. N- ~+ n8 y* s+ ~: T; ] 1 英 担 =112 磅 =50.802 千 克 ! n) j: Q) q4 X
1 美 吨 =2000 磅 =0.9072 公 吨
& p) t& c+ T* h5 e, L4 J 1 英 吨 =2240 磅 =1.0161 公 吨
4 V2 `; y+ s7 r常用计量单位换算
$ Z4 |- n {* b, P码(yard)=3ft 0.9144m (米)
7 q/ y4 Y! K o$ L+ M3 F3 s/ T, `吨 tonne,metric ton(t) 1000公斤 (kg) & {7 T6 p5 d: E' q9 Y3 q* b
英尺foot=12in 0.3048m 3 F. V: [5 w1 F% m0 l3 D" Q2 l
克拉,米制克拉metric carat 0.2克 (g)
& {) C5 A; R% _; _' ~英寸inch 0.0254m
_$ c0 \5 Z) i% V: x$ H磅 pound(lb) 0.453 592 37kg
6 m( G1 ~: J. J8 c, t2 }4 Q( l9 X英里mile,statute mile 1609.344m 9 o+ G$ ~$ ^# g
盎司 ounce 0.0283495kg
7 @3 S* j2 p) b: F8 e3 l' F9 T光年light year 9460530000000km ! Z) ` ?3 d0 v6 n$ H3 N" X
英担 hundredweight(cwt) 50.8023kg 0 q: b {; c! `5 O! v! t9 y
链chain(chn)=22yd 20.1163m ) v& j. G5 h* W" c' M
英吨 ton(ton)=2240lb 1016.05kg
# c' h7 g& o' X z# t: ?浪furlong 201.168m
% z) Y5 F, W8 q' @斯拉格 slug=32.1740lb 14.5939kg
, q2 K' J3 \3 O8 hpoint=(1/72)in(近似) 0.35146cm
3 ^7 }! C2 R' N1 r8 `1 R短吨 short ton(sh ton) 907.185kg 7 N c$ V) I1 d5 k n
iron=(1/48)in 0.529167cm ( e- A, r. v s
line=(1/40)in 0.635cm
2 E+ k# z- @7 B$ E% }+ Z1 c长吨 long ton 1016.05kg
, U t, {( U8 n5 G3 {/ Z+ P2 R6 q手 hand=4in 0.1016m
[ m1 J: m- |( p3 }药衡(打兰 UK) 3.887 93g
6 P, O3 M- A0 O6 }/ U. Z1 Q令link=(1/100)chain 0.201168m - U( k5 ?3 E4 A: D M
药衡(打兰 US) 3.887 93g . f+ f2 \& l4 X; p0 k
英寻fathom(fa)=6ft 1.8288m
( c. H' J" G0 e* A7 q药衡盎司(oz apoth) 31.1035g 4 G" @1 D% \0 d; A: Y0 o8 {
杆rod,pole,perch 5.0292m * Y& c2 m( }/ U
金衡盎司 pound troy 0.373 242g
' }, G7 S! L# H2 m0 s工程链engineers chain 30.48m
2 [, p3 F( G l% d m国际谷物蒲式耳 27.2155kg
, c9 U6 s) R. G英海里 UK nautical mile 1853.184m
z$ Y$ y X; c+ b/ ?& dpoint 2毫克 (mg) % X1 Y0 ?3 i8 {/ T2 h
分 (min) 60秒 (s) 6 k5 d* o9 H& i) w9 L
达因 dyne 0.000 01 牛顿(N) : e2 u; W9 S* b) j7 ^" v
小时 hour (h) 3600s
" w' C! Z6 Z. ~2 n0 [千克力(kgf) 9.806 65N * w4 H2 _6 E5 q4 ~! g" W" R R
日 day 86 400s 6 U5 J% `/ J2 r2 ^! w: D, z6 R- v
磅力 (lbf) 4.448 22N " m& u" w- B9 f" T d4 c$ g9 c
周 week 604 800s 3 X5 i, I% |$ b( |# B! Y
pond (克力) 0.009 806 65N 0 I; H v/ J* Y( R d$ |6 H3 s: n9 ~
月(30日) 2 592 000s
7 W( r+ x1 j- U4 [- E0 S# F闰年 leap year 31 622 400s , e8 q: x: Q! G4 |& X: V9 S
回归年 tropical year 31 556 900s
- {9 T( F2 T( H$ Z巴 bar 1000000帕斯卡 (Pa) / J; V1 r5 I% T" |( M1 j
恒星年 31 558 200s # C q5 J3 k6 K- ]- O9 B
千克力每平方米 9.806 65Pa
7 S6 d i8 k0 Q3 j5 a: G$ e: B, S1 fshake 0.000 000 01s 5 K. u8 M0 n6 h0 t ^- U# i
毫米水柱 9.806 65Pa
( B( H6 t5 ^1 K9 M+ ~毫米汞柱 133.322Pa
$ q# _: G( r$ R( o3 e5 h5 e0 `! s标准大气压 101 325Pa
, h5 O3 j3 q" X/ U9 `; j1 m' K工程大气压 98 066.5Pa ; [- H& a( A) W u0 F! i! K0 Z; T
华氏度(F) 5/9K 3 x2 y/ B& |4 I+ e! ?% y& V+ B) ?
托 torr (Torr) 133.322Pa
9 M+ Q2 |0 o; A6 Y8 Y2 n' {1 D马力 735.499瓦特(W)
2 h: \0 P6 e b0 ?+ x3 y8 L电工马力 746W
: }6 n4 B6 N5 N- C! `卡每秒 4.1868W
# d9 b" K5 q- `# f; Q+ w千卡每小时 1.163W
9 g0 e- @! @; A6 j热化学卡每秒 4.184W 0 j$ R* L* g# G! U! |7 o1 L) I
伏安 1W |
