发表于 2009-12-7 22:04:19
来自: 中国安徽淮北
电液阀是这样用的:: }) _7 H! m; X
Switching time adjustment; m; X2 A: a# S: V
In order to influence the switching time of the main valve (1) a double; @! M- r- j2 N8 Z& i) R
throttle check valve (2) (type Z2FS 6 to catalogue sheet RE 27 506)
7 o7 N3 z7 g* v3 v- [' r, Yhas to be fitted.
# @6 K O# J: ], Q" @Conversion from meter-in (3) to meter-out control (4):
* G9 Z% L/ ^) h& f2 q8 e% kRemove the pilot valve (5) leave the seal ring support plate (6) in
* p! W! B W. }/ Hplace, rotate the throttle valve (2) about its longitudinal axis and3 A" G0 I* P/ e/ n9 M8 t5 h& f+ M
refit it, replace the pilot valve (5).
' H; \( f4 q" `Tightening torque of the screws (7) MA = 9 Nm.% C% E G" \- Y3 r2 c! S5 O
( H6 Q7 S: _% Q: z/ e
看最后一页 |
