查看: 2828|回复: 2
[讨论] 2010sp1都更新了什么
发表于 2009-12-9 12:18:25 | 显示全部楼层 |阅读模式 来自: 中国山东威海
2010sp1都更新了什么 知道的出来说说
发表于 2009-12-9 12:23:08 | 显示全部楼层 来自: 中国广西防城港
发表于 2009-12-9 12:25:38 | 显示全部楼层 来自: 中国广西防城港
https://www.solidworks.com/sw/su ... intenanceNotes.html
7 x/ X; V( v/ M* F) H0 v# M0 J* Y: q' j' V
154392 Default properties listed in custom file properties is not the same in SolidWorks and in SolidWorks explorer. Workgroup PDM  ' g4 g1 u" c2 F9 X3 l: r
219745 The BSI and ISO pipe thread tap drill diameters are incorrect. Do not follow zeus guide. Diam too small for thread tap. SolidWorks  ! q) o/ r* `6 f& |2 l( x
283413 Design Table does not update with correct Configuration specific property values. SolidWorks
3 |; X  M/ K" v* O- G292029 RMB delete menu of the 'Hide/Show components' does not work. SolidWorks
3 W/ k/ D. t- f4 {. L% z, E/ b. f300304 Temporary axes which overlap hidden ref axes are not visible SolidWorks  5 o  x" ]1 z( N6 t) d
382029 Unable to create library feature with selected references on this customer feature SolidWorks  5 L& z1 k% n" s' _( [$ B' d
388293 When a cut feature is added after Lofted Bends feature, bend lines are not displayed. SolidWorks
) o5 w" O5 ~# s0 M! W4 d399516 Ability to install XchangeWorks with AutoCAD 2008 and AutoCAD 2009. SolidWorks
( y$ g0 G& c1 Z0 `: U% N  h5 `404671 Task Scheduler does not export Multi-sheet SolidWorks Drawing with different sheet scales to 1:1 scale. SolidWorks  " D, V" S# H6 }
428373 Transformed sketches are not included when saving/exporting sheet metal flat pattern to DXF/DWG SolidWorks  * E  U5 C: h# o5 y% l4 ]6 T, V
429993 Changing stress result plot display typefrom solid and shells to beam then saving and reopening reverts back to solid/shell type stress plot CosmosWorks  1 _) Y2 w' S' D6 }
435687 Right now ONLY default sheet1 was allowed to link to list box, while usually xls file have 3 sheets. SolidWorks  " ~! x" _6 J, y3 j, j
442124 Online help and system requirements webpage should mention that the Word 2003 and below is not supported by COSMOSWorks CosmosWorks
0 I- u) M, x( a4 D% \5 g! r442894 Detailed (BOM) weldment cut list template ('standardbomweldment.sldbomtbt' / 'bom-weldment cut list.sldbomtbt') does not install SolidWorks  ( q6 j6 I' D0 S5 f% P, x; P
447829 Part returns to default color after editing Configuration Properties SolidWorks
; p$ _% z3 s" [1 k! ?1 F& g9 x. P448633 Unable to set GT horizontal. SolidWorks  & N, N1 \6 x+ I
453829 Creating a drawing using a template with multi sheets, the logo of the inactive sheets gets lost SolidWorks
# Z3 c1 O2 m0 r2 @455821 Get/SetMaterialPropertyValues2 should work for the specification of configurations SolidWorks API  , J- S' f: I( K
458156 Blend color option for textures is no longer available in SolidWorks 2009 SolidWorks
7 P+ @7 K, e6 L/ X: D+ B468060 Editing sheet format and adding sketch entities to it, then reloading sheet format from Properties dialog does not reload until CTRL + Q SolidWorks
8 |2 U- G0 J% ^# I469928 Drawing view loses its color when the file is opened with 'No preview during open (faster)' option selected SolidWorks
/ p( Q3 b& U, L% L' Q7 n476709 Textured Appearance disappears when turning off Real View or selecting ok while applying it when Real view is already Off. SolidWorks  1 J% y; ~, s! M+ k* ?) a$ k' C7 Z
478243 It is not possible to resize simulation windows CosmosWorks
0 p# B! V0 P& _4 G1 Q485388 Setting tolerance font size in hole callout properties does not work SolidWorks
5 ]' s. |5 O7 `' n0 R) G  k# z. j  g" e503416 Different user interface dialogs and menus are not translated (Italian Lang) PhotoView 360
# n  t" `# p" p& b" Z' y( J" D$ o504067 Cannot assign material directly to shells defined by selected faces => Avoidance Exists CosmosWorks
3 B' p  `, _' _3 _/ C3 R% P504428 Font height of sub-categories in Document Properties, Annotations is not retained after changing other properties or saving drafting standard SolidWorks  5 G( M& S" k( k% C8 G6 J
508548 eDrawings crashing after previewing several files in EPDM preview eDrawings  ; s! I3 F7 v* Q: n6 |3 P6 H) c; ~. C
514150 German: SustainabilityXpress truncated text for 'Material festlegen' and 'Kohlenstoff' SolidWorks Office
& D) W! q3 B. C$ `, M# p514752 View::GetVisibleEntities returns wrong number of faces for specific components SolidWorks API
: e7 E. ]: S4 Y# W515135 Old sketch segments remain when editing this flattened route Routing  ! \  r/ L& _1 Y) i
521904 Application lockup when defining Edge weld estimated size CosmosWorks
- r3 Z) v7 l7 o: m6 z9 r522919 "Exception caught" error on startup of SolidWorks 2010 on Vista; activation fails to start SolidWorks  1 e# \1 b) K$ u6 o. x
523069 Export to DXF / DWG exports the part to the wrong scale SolidWorks
