查看: 1444|回复: 0
[求助] 为什么mastercam的pst文件里的问题是从38开始的?
发表于 2009-12-9 20:42:12 | 显示全部楼层 |阅读模式 来自: 中国广东揭阳
就是这样,38前面的问题没有啊,还有下面为什么说是version 8 我用的是 9啊   i( W' C: g- i! @% |* v' h
9 ~6 m: {6 Y$ t6 s4 h0 F! i, F
7 E2 [$ G" [  N/ ^1 U5 C9 t/ k  V
+ G$ F2 x* G, [# v3 n# Numbered questions for Mastercam Version 8# --------------------------------------------------------------------------38. Rapid feedrate? 300.0#76. Configuration file name? 76. Name of associated cfg file? T80. Communications port number for receive and transmit (1 or 2) ? 281. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 1200 82. Parity (E/O/N)? E83. Data bits (7 or 8)? 784. Stop bits (1 or 2)? 285. Strip line feeds? N86. Delay after end of line (seconds)? 087. Ascii, Eia, or Binary (A/E/B)? A88. Echo keyboard to screen in terminal emulation? n89. Strip carriage returns? N90. Drive and subdirectory for
