发表于 2009-12-11 21:17:15
来自: 中国
VBA代码,供参考- : x; w% c7 [7 N0 _( ^
- Sub A()
) u$ [# V! j7 T - Dim E As AcadEntity
! A( Z/ W) n; k/ \$ N2 Z - ThisDrawing.Layers.Add "AA", ~+ a, L# q D% x; C3 T
- LoadLineType "HIDDEN"
4 j! d9 ^% m% y+ v# O& H - LoadLineType "CENTER"$ j# V+ _5 N+ T3 `- Q5 F: ~ t
- For Each E In ThisDrawing.ModelSpace- g% g% c1 F, W3 S2 r( K
- Select Case E.Layer
( ]! O) I( k( s" b! j- M V" B% E - Case "可见(ISO)"9 ^( t8 q0 Q. \+ X2 [
- E.color = 79 G0 q/ ] Q2 `3 Z+ a
- E.Linetype = "Continuous"
5 c+ W& P2 Z/ E; z3 {% t - Case "窄部可见(ISO)"
9 B, w! F! B, c. Q - E.color = 5
! \9 _- t: D1 O) ?" D6 J S - E.Linetype = "Continuous"# p9 n& {1 E" s2 P4 R/ b5 M
- Case "隐藏(ISO)"
: }! r* I3 j0 {! r! c - E.color = 4
" q- j6 V% w) [' E' J. ] - E.Linetype = "HIDDEN"
5 @3 N; D; f0 K! b - Case "中心线(ISO)", "中心标记(ISO)"1 E& t1 Q r* s$ U8 v
- E.color = 1' s7 `) x) i% N: }4 v( ?& R
- E.Linetype = "CENTER"3 ^; L( K- [5 ]8 v9 F" C4 z
- End Select
" q( S% X7 t" u0 g - E.Layer = "AA"2 s0 \% E- z0 G) V
- Next" w0 L6 m$ I) n
- End Sub
4 ?& h7 g) F# P. r! \$ r; a - 5 |$ F! X& \; s$ ^: P8 B
- Private Sub LoadLineType(S As String)5 m+ ?3 B g: B0 @
- Dim T As AcadLineType, B As Boolean
0 \ f2 m# T7 p1 `! R& a+ Y' o - For Each T In ThisDrawing.Linetypes
4 U+ [/ F8 d# I" x6 _0 |/ [# U - If T.Name = S Then
9 H0 z2 g( @6 e+ s' S - B = True, b- {1 u1 M ^! i. |- `1 I D3 B" {
- Exit For
) w! ?. ?% e' \0 c& D - End If
' A8 i, K0 K' V - Next
' z* P4 }4 C& Y+ i - If Not B Then ThisDrawing.Linetypes.Load S, "acadiso.lin"* v7 u# R, j ~
- End Sub c* a6 A3 a# i% v$ R( C9 w( Q. N
复制代码 |
