查看: 5354|回复: 14
[分享] 倒角标注
发表于 2005-11-24 21:34:00 | 显示全部楼层 |阅读模式 来自: 中国四川眉山
(DEFUN C:DIMCHAMFER () (SETVAR "CMDECHO" 0) (SETQ OLDOS (GETVAR "OSMODE")) (SETQ OLDZIN (GETVAR "DIMZIN")) (SETQ ORTHO (GETVAR "ORTHOMODE")) (SETQ OLDTAD (GETVAR "DIMTAD")) (SETVAR "DIMZIN" 8) (SETVAR "OSMODE" 0) (SETVAR "DIMTAD" 1) (SETQ DL (ENTGET (CAR (ENTSEL "\nPlease Select a Line 请选择一条直线 :")))) (WHILE (/= (CDR (ASSOC 0 DL)) "LINE")  (PRINC "\nError!")  (SETQ DL (ENTGET (CAR (ENTSEL "\nPlease Select a Line 请选择一条直线 :")))) ) (SETQ P1 (CDR (ASSOC 10 DL))       P2 (CDR (ASSOC 11 DL))       X (ABS (- (CAR P1) (CAR P2)))       Y (ABS (- (CADR P1) (CADR P2)))) (IF (EQUAL X Y 1E-4)  (SETQ TT (STRCAT (RTOS X 2 3) "x45%%d")) (PROGN  (SETQ CT (/ (DISTANCE P1 P2) (SQRT 2.0)))  (PRINC "\nDistance of Chamfer 倒角尺寸<") (PRINC (RTOS CT 2 3))  (SETQ TT (GETSTRING "> :")        TT (STRCAT (IF (= TT "") (RTOS CT 2 3) TT) "x45%%d")) )) (IF (/= TT "") (PROGN  (SETQ OLDASZ (GETVAR "DIMASZ")        P4 (POLAR P1 (ANGLE P1 P2) (* (DISTANCE P1 P2) 0.5)))  (SETVAR "DIMASZ" 0)  (SETVAR "SNAPANG" (ANGLE P1 P2))  (SETVAR "ORTHOMODE" 1)  (IF (SETQ P3 (GETPOINT P4 "\nText Point 文字点? ")) (PROGN   (SETQ P4 (IF (> (DISTANCE P3 P1) (DISTANCE P3 P2)) P2 P1)         P5 (POLAR P3 (/ PI 2) (* (GETVAR "DIMGAP") 1)))   (COMMAND "LEADER" P4 P5 "" TT "")  ))  (SETVAR "SNAPANG" 0)  (SETVAR "ORTHOMODE" ORTHO)  (SETVAR "DIMASZ" OLDASZ) )) (SETVAR "DIMZIN" OLDZIN) (SETVAR "OSMODE" OLDOS) (SETVAR "CMDECHO" 1) (PRINC))
% y: A1 C% J+ _5 H8 F( g  h3 J: O5 B; j1 [  ?8 ^5 }
[ 本帖最后由 bbsjava 于 2006-7-1 10:41 编辑 ]
发表于 2006-1-1 13:20:00 | 显示全部楼层 来自: 中国江苏苏州
太深奥 了看不懂
发表于 2006-1-1 13:31:00 | 显示全部楼层 来自: 中国浙江金华
能弄点大家能懂的上来不
发表于 2006-1-1 22:57:00 | 显示全部楼层 来自: 中国四川成都
This is a CAD AutoLISP developing sample. save it as "chamdim.lsp" in folder "c:programe files\autocad 2000\support\" ,on autocad toolbar do rightclicking,select "custom",add a button ,define it with command "^C^C(load "chamdim"dimchamfer".then click this button,you will dimchamfer as you want....
发表于 2006-1-2 01:54:00 | 显示全部楼层 来自: 中国浙江台州
看上去还不错!是楼主自己开发的吗?我先试试了!!!!楼主继续努力!!CAD二次开发很实用的!!!
发表于 2006-1-2 10:29:00 | 显示全部楼层 来自: 中国浙江温州
This is a CAD AutoLISP developing sample. save it as "chamdim.lsp" in folder "c:programe files\autocad 2000\support\" ,on autocad toolbar do rightclicking,select "custom",add a button ,define it with command "^C^C(load "chamdim")dimchamfer".then click this button,you will dimchamfer as you want这是一个CAD AutoLISP开发样板,在文件夹"c:programe files\autocad 2000\support\"另存为"chamdim.lsp" ,在工具栏上右键,选择自定义,添加一个按纽,用命令行"^C^C(load "chamdim")dimchamfer"定义它,之后你再点击它时,你用可以随心所俗欲的标注倒角
; }6 Y& k  ~  n9 f: r0 e
* N8 Y1 J" K7 g2 j3 N[ 本帖最后由 bbsjava 于 2006-7-1 10:42 编辑 ]
发表于 2006-1-2 10:49:00 | 显示全部楼层 来自: 中国广东深圳
谢谢6楼大哥的解释!
发表于 2006-1-2 11:57:00 | 显示全部楼层 来自: 中国吉林长春
一点都不赞成,成形的软件要保持他原有的整结才好,少加其他内容
发表于 2006-1-2 12:42:00 | 显示全部楼层 来自: 中国广东深圳
谢谢楼主,好好用.楼主,你能不能多写几个象这样的程序传上来.我是用CAD做五金模具.其它的我不会只有在CAD上做图还需要很多工具.你能发上来吗?     再次谢谢你.
发表于 2006-1-2 20:46:00 | 显示全部楼层 来自: 中国河南新乡
唉!看不懂
发表于 2006-5-15 13:27:46 | 显示全部楼层 来自: 中国湖北武汉
讲解一下好像可以理解了
发表于 2006-7-3 22:27:40 | 显示全部楼层 来自: 中国河北石家庄
,希望我会用.
发表于 2006-7-5 13:00:19 | 显示全部楼层 来自: 中国陕西汉中
每人软件都有它自己的长处!不过我觉的CAD 应该改进了!那么多的命令学的人烦教的人烦啊·!
发表于 2006-7-20 19:57:38 | 显示全部楼层 来自: 中国北京
感觉好难,看不懂。。。。。。。。
发表于 2007-11-29 21:26:15 | 显示全部楼层 来自: 中国山东烟台
哪位高手能不能说的更明白一点,最好用中文!
