我刚下了一个cimatrone9.0 official 版但里面的 cimatron. LIC 似乎不好用。请装好E9.0 official版的朋友帮忙看看这个lic文件 讲一下怎样安装 如图:- B5 k4 K! p( U
server localhost ANY 7788
0 J2 i; h7 |, ]PACKAGE PKG_COMPLETE_SYSTEM cima-d 9 COMPONENTS="2X-MILL 3X-MILL \6 q" R( S6 s. Y1 E
3X_SIMULATOR 4X-CONT 5X-CONT 5X_SIMULATOR 5X_TRIM CAD_MODE \: q) X) d& F- X- y: f; A# J
CADENAS CATALOGTOOL CATIAR3D CATIAW3D CORE_STANDARD CORE \
$ ~2 U7 b( ?9 e3 o, o DIE_QUOTE_GENERATOR DRAFT DWG DXF EDM_SETUP_WIZARD \
( x" O/ w" {/ G* D1 b EDM_WIZ_AGIE EDM_WIZ_CHARMILLE EDM_WIZ_DPC EDM_WIZ_INGERSOL \0 f7 v6 }' F) y' c3 p* R" v
EDM_WIZ_MAKINO EDM_WIZ_MITSUBISHI GPP IGES LATHE_2X \
( P) f$ s1 h& L. Z# B+ L8 E LATHE_PP_COMPILER LOCAL_3X MACHINE_SIM MOLDDESIGN MWSIM_3X \
, | E5 O1 }2 c: _* G4 t1 [ MWSIM_5X NC-LINK PARASOLID_SAT QCOMPARE QELECTROD QSPLIT \, \2 Q/ q. O3 `
QUICKDRILL R_CATIA5_PMI R_CATIA5 R_CATIA_SAT R_IGES \
i. t" Y6 R5 ?: z2 | R_PARASOLID R_PROE_PMI R_PROE R_SOLIDWORKS R_STEP R_UG_PMI \( w! B+ a/ V( v4 k. X
R_UG R_VDA RD-PTC SAT SOLID-ASSEMBLY SOLID STL UGR3D W_CATIA5 \$ ?1 f# Y8 H U$ G J) ]
W_CATIA_SAT W_IGES W_PARASOLID W_STEP W_VDA W_VRML WIRE_2X \2 ^3 r# z5 ~4 I1 f
WIRE_4X WIRE_STANDALONE DIE_TRANSFER " ISSUER=CAXiSO TS_OK \
& y8 r, {( v0 s8 \ SIGN=3E05261E778C, V5 w( c; c$ c+ [+ E; G6 z" S7 X
FEATURE PKG_COMPLETE_SYSTEM cima-d 9 27-nov-2009 uncounted HOSTID=ANY \
. i9 g+ X( y8 \4 X j ISSUER=CAXiSO TS_OK SIGN=268E76E4117A) h' |9 r8 c. O5 M
PACKAGE PKG_COMPLETE_SYSTEM2 cima-d 9 COMPONENTS="5X_AEROSPACE \7 C+ s/ E0 g2 _0 }* C
API_IT_DIMA2DIMA API_IT_EFUSION API_IT_EHEEL API_IT_ESHOES \1 X+ _8 b) ]; ?0 m
API_IT_REENGE AUTOMATED_DRILL CATALOG_CABE CATALOG_CN_FUTABA \7 v' G; j/ I0 n" b( | w3 D
CATALOG_DANLY_INCH CATALOG_DANLY_MM CATALOG_DAYTON_INCH \+ b) I+ e& |- H# x! V, J
CATALOG_DAYTON_MM CATALOG_DE_MEUSBURGER CATALOG_DME_INCH \
% J$ w' o% @" _ CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO CATALOG_FUTABA \- w; `* C! S8 |$ {
CATALOG_HASCO_INCH CATALOG_HASCO_MM CATALOG_IT_PEDROTTI \5 V% v) Q! _$ X
CATALOG_IT_SIDECO CATALOG_IT_SKF CATALOG_IT_STAMPI \4 a8 \& {4 |* t/ {1 [
CATALOG_IT_SYSTEM3R CATALOG_IT_TVMP CATALOG_IT_UNI \
A/ y' c2 h1 a5 _9 D) B8 x3 h1 V CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \/ T% h2 U) ]8 f1 B4 ? I
CATALOG_OKSET CATALOG_PCS CATALOG_PEDROTTI CATALOG_POLIMOLD \" `- K0 C* Z9 a+ B
CATALOG_PROGRESSIVE CATALOG_RABOURDIN CATALOG_SIDECO \
& z9 p( H$ W7 A6 x! e CATALOG_SKF CATALOG_STAMPI CATALOG_STRACK_NL CATALOG_STRACK \3 k, x# w& w% I- p! \
CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP CATALOG_UNI \
. z- D8 n8 T( w CATALOG_VAP CONCURRENT_DESIGN DIE_BLANK DIE_FLANGE DIE_FORM \
7 p/ `" h$ ~2 f, v DIE_LABEL DIE_PLOT_SAFETY DIE_PLOT_THICK DIE_SET DIE_STRIP \
4 H. Q0 R, o: n& F( y DIE_TOOLS GPP2_3X GPP2_5X GPP2_DEV_DF2 GPP2_DEV_EX2 GUN_DRILL \
, n# j% {8 Y% P/ h. t5 J MICRO_3X MICRO_5X NC_UNDERCUT R_INVENTOR " ISSUER=CAXiSO TS_OK \7 X5 `& B1 m3 f! S* n
SIGN=ACBE473839AE
" _% x& T) K2 j+ e# n- x# {FEATURE PKG_COMPLETE_SYSTEM2 cima-d 9 27-nov-2009 uncounted \
/ N; |1 V- f+ p& @/ e, y2 O HOSTID=ANY ISSUER=CAXiSO TS_OK SIGN=059C7A5059DE) o% [/ r0 ?7 v# p, n! \
FEATURE CHINESE_TRANSLATION cima-d 9 27-nov-2009 uncounted HOSTID=ANY \. E1 l: A& [5 b7 _
ISSUER=CAXiSO TS_OK SIGN=D93BECA02C44
5 T- k' c3 ]/ D3 |! M! @$ V2 cFEATURE $ABCDEFG123456++= cima-d 9 27-nov-2009 uncounted HOSTID=ANY \& ^# |* [! ]/ C
ISSUER=CAXiSO TS_OK SIGN=5C3D4974CDF0 |
