发表于 2010-1-22 23:34:56
来自: 德国
偶这里只有英文资料,所以凑合下吧...& W9 f) ?' Z1 }1 ]6 `
FT:' Q! j0 t2 p% M& v" B
Flocculants, or flocculating agents, are chemicals that promote flocculation by causing colloids and other suspended particles in liquids to aggregate, forming a floc. Flocculants are used in water treatment processes to improve the sedimentation or filterability of small particles. For example, a flocculant may be used in swimming pool or drinking water filtration to aid removal of microscopic particles which would otherwise cause the water to be turbid (cloudy) and which would be difficult or impossible to remove by filtration alone.
# Z, t, k3 e7 L# y% ?
2 a3 Q& l t% qMany flocculants are multivalent cations such as aluminium, iron, calcium or magnesium. These positively charged molecules interact with negatively charged particles and molecules to reduce the barriers to aggregation. In addition, many of these chemicals, under appropriate pH and other conditions such as temperature and salinity, react with water to form insoluble hydroxides which, upon precipitating, link together to form long chains or meshes, physically trapping small particles into the larger floc. |
