2天前
查看: 1910|回复: 3
[求助] EN 10088-3 X8CrNiSl8-9是stainless steel吗?
发表于 2010-3-4 16:07:58 | 显示全部楼层 |阅读模式 来自: 中国台湾
发表于 2010-3-4 16:55:21 | 显示全部楼层 来自: 中国山东青岛
本帖最后由 tdragonfu 于 2010-3-6 15:00 编辑 / C/ T8 K; b% S2 m* n5 B
1 W5 ]# a& h" K' N7 w* v
是的,相当于GB Y1Crl8Ni9,JIS SUS303
: P  q3 o' U+ b* z
* r& R4 `9 z+ F1 H) C; @属于易切削结构钢。
tdragonfu + 2 技术讨论
发表于 2010-3-5 17:39:33 | 显示全部楼层 来自: 中国江苏常州
Grade X8CrNiS18-9 an austenitic free cutting steel, is comparable to X 10 CrNiS 18 9 acc. to DIN 17440. It is used for the production of rust-resistant turning parts in food and dairy industry, in photo, color, oil, soap, paper and textile industry. Machinability is due to the sulphur content considerably increased compared to the usual CrNi-steels. Corrosion resistance is significantly reduced. No resistance to intercrystalline corrosion also in delivery condition.
发表于 2010-3-6 14:27:24 | 显示全部楼层 来自: 中国上海
本帖最后由 lhf999 于 2010-3-6 14:30 编辑 . ?0 |6 e3 ]: t
. {9 G  `) s6 W7 `! z$ s7 QEN 10088-3 X8CrNiSl8-9是stainless steel吗?4 l1 J2 }+ E, ?+ N
* H9 [# `( O. p3 [/ Q( g) hEN 10088-3 标准名称就是:: y8 C' {  L$ B/ _% ?5 X- G
“stainless steel ——Part 3: Technical delivery conditions for semi-finished products, bars, rods, wire, sections and bright products of corrosion resisting steels for general purposes”," g; `' b! K& Y& b; F) u
$ a4 H. D% C5 f4 X. s7 R9 H
如果可以望文生义的话,X8CrNiSl8-9(好像应该是X8CrNiS18-9)就是stainless steel。
