查看: 1686|回复: 2
[求助] 请高手解答EN10025
发表于 2010-3-8 15:58:14 | 显示全部楼层 |阅读模式 来自: 中国江苏常州
请高手解答EN10025
" L, n2 X% C: S8 e* k7 G8 z) \
如题
, F5 [3 b1 p/ |. t请材料高手解答
  c& y4 i+ E$ O6 c' K& D6 kEN10025-2 8 T+ e' J8 m, `( Q6 [' y+ ?
EN10025-3
$ M6 |* c9 \0 [. d8 ]EN10025-4
1 M1 p  ?7 ^8 @3 R) O  CEN10025-5
/ S6 E: U# p4 e( e! G2 h) V) N3 d的区别。0 \* r8 c. O2 p/ W' X) e
EN 10025-2:2004, Hot rolled products of structural steels - Part 2: Technical delivery conditions for non-alloy% {& L. t3 x* d
structural steels.
: t3 _4 H6 r7 @/ A+ n( zEN 10025-3:2004, Hot rolled products of structural steels - Part 3: Technical delivery conditions for
0 o/ q' B8 w: M' Dnormalized/normalized rolled weldable fine grain structural steels.
- |8 @4 K2 v5 x9 ^+ h. ?EN 10025-4:2004, Hot rolled products of structural steels - Part 4: Technical delivery conditions for6 g/ @* \# S) V3 R8 m$ Y
thermomechanical rolled weldable fine grain structural steels.
% J/ x: E& _4 A1 `. g( Z* Q3 x9 H  ^EN 10025-5:2004, Hot rolled products of structural steels - Part 5: Technical delivery conditions for structural
9 t6 g. E8 K# r, \! Q& ^- J6 csteels with improved atmospheric corrosion resistance., r, E% \3 Q' `8 i: }% O  N
* N( v2 D$ n/ c: M2 B
本人只看出化学成分的细微差别,无非是从2到5 杂质PS 等的控制严格了& x" r6 L* ~* o+ M0 Z
请从交货状态,检验方法等方面区别给与支持.$ K0 j# ~+ |' Q3 f: g2 W
谢谢各位大虾了!!!!
发表于 2010-3-9 10:54:26 | 显示全部楼层 来自: 中国江苏南京
我手头没有你要的那个标准。一般来说,EN10025的正文是说材料的基本情况,说的是材料的交付条件和材料的规格。-1,-2,-3。。。。。则是一些附件说明了其中的一些细则。8 w( N8 ^' [* [+ y) o6 t
根据你给出的附件名称,可以判断出这个标准是关于热轧钢产品的,并且你可以了解到这个附件的具体内容:
% ]# K* }. I' s2 c/ ~# WEN 10025-2:2004, Hot rolled products of structural steels :热轧结构钢产品! \5 d# r* v: o) u  B; o: t
- Part 2: Technical delivery conditions for non-alloystructural steels.非合金结构钢的交付技术条件;" o4 H% U) M2 Z. X
- Part 3: Technical delivery conditions for normalized/normalized rolled weldable fine grain structural steels.无正火或正火态的可焊的细晶粒钢的交付技术条件;/ M! U( b: U" T5 j
- Part 4: Technical delivery conditions for thermomechanical rolled weldable fine grain structural steels.已经过热机械处理的可焊的细晶粒钢的交付技术条件;
* m/ h" ]' u3 i1 M- Part 5: Technical delivery conditions for structural steels with improved atmospheric corrosion resistance.增强耐大气腐蚀性能的结构钢的交付技术条件。. i4 y/ l% M% l4 c/ T0 n2 ^9 `' C
业内人士在选用钢材时会根据使用条件和加工条件选择不同的附件中钢种,这当然需要了解其不同的技术条件。当然钢厂在生产时也会根据不同的使用条件对钢中的成分有所侧重。你在标准附件中见到有成分的差异也就不奇怪了。
发表于 2010-3-10 21:46:25 | 显示全部楼层 来自: 中国山东济南
-2:非合金结构钢的交付技术条件 相当于国内热轧状态交货的碳素结构钢或低合金结构钢3 m+ b" A3 q8 F9 L
-3:正火状态或正火轧制交货的可焊节细晶粒钢;1 U# I" O. c$ \0 [2 C+ D4 V) d. c
-4:热机械轧制(具体定义标准内有解释)状态交货的细晶粒钢;
: w# y& y% z9 H: T/ i/ g9 h4 z# D-5:增强耐大气腐蚀性能的结构钢
' u5 r" j6 N- u交货状态从标准名上直接可以看出来,没有明确的一般以热轧交货。检验要求根据每个标准规定的性能指标确定。-5比较好区分,-2、-3、-4主要是交货状态及可焊型。
