查看: 1843|回复: 8
[求助] 硬度换算
发表于 2010-3-14 17:38:24 | 显示全部楼层 |阅读模式 来自: 中国陕西西安
硬度换算在国际上有没有什么统一的标准?
发表于 2010-3-14 19:34:48 | 显示全部楼层 来自: 中国江苏淮安
基本一致,可以在论坛下载手册或相关标准看看。
发表于 2010-3-14 22:07:53 | 显示全部楼层 来自: 中国湖北十堰
不同硬度值之间是可以换算的,只能作为参考值而不能做为准确值,如果要以某种硬度值作为评判标准还要打相应的硬度才对!
发表于 2010-3-14 23:15:47 | 显示全部楼层 来自: 中国江西九江
[tr][/tr][tr][/tr]
硬 度 换 算 表
(HRC)硬度(HV)硬度硬度(HB)10mm荷重3000kgt硬度(HS)硬度抗拉强度
标准球 (HRB)荷重60kgt(HRB)荷重100kgt/1.6mm(HRD)荷重100kgtMpa(kgt/mm2)
68940--85.6-76.997-
67900--85-76.195-
66865--84.5-75.492-
65832-73983.9-74.591-
64800-72283.4-73.888-
63772-70582.8-7387-
62746-68882.3-72.285-
61720-67081.8-71.583-
60697-65481.2-70.781-
59674-63480.7-69.980-
58653-61580.1-69.278-
57633-59579.6-68.576-
56613-57779-67.775-
55595-56078.5-66.9742075(199)
54577-54378-66.1722015(205)
53560-52577.4-65.4711950(199)
5254450051276.8-64.6691880(192)
5152848749676.3-63.8681760(179)
5051347548175.9-63.1671695(173)
4949846446975.2-62.1661635(199)
4848445145574.7-61.4641580(192)
4747144244374.1-60.8631530(186)
4645843243273.6-60621480(179)
4544642142173.1-59.2601435(173)
4443440940972.5-58.5581385(141)
4342340040072-57.7571340(136)
4241239039071.5-56.9561295(132)
4140238138170.9-56.2551250(127)
4039237137170.4-55.4541215(124)
3938236236269.9-54.6521180(120)
3837235335369.4-53.8511160(118)
3736334434468.9-53.1501115(114)
3635433633668.410952.3491080(110)
3534532732767.9108.551.5481055(108)
3433631931967.410850.8471025(105)
3332731131166.8107.550461000(102)
3231830130166.310749.244980(100)
3131029429465.810648.443950(97)
3030228628665.3105.547.742930(95)
2929427927964.7104.54741910(93)
2828627127164.310446.141880(90)
2727926426463.810345.240860(88)
2627225825863.3102.544.638860(86)
2526625325362.8101.543.838840(86)
2426024724762.410143.137825(84)
---243-9942.135-
2325424323761.59941.635785(80)
212432312316198.540.935770(79)
2023822622660.597.840.134760(77)
18230219219 96.7 33730(75)
16222212212 95.5 32705(72)
14213203203 93.9 31675(69)
12204194194 92.3 29650(66)
10196187187 90.7 28620(63)
8188179179 89.5 27600(61)
6180171171 87.1 26580(59)
4173165165 85.5 25550(560
2166158158 83.5 24530(54_
0160152152 81.7 24)
发表于 2010-3-15 08:30:49 | 显示全部楼层 来自: 中国台湾
4 t7 w: \) A+ o  o! {3 W" [. t3 d  U+ i% |8 d3 w
ASTM E140-2007.pdf (155.46 KB, 下载次数: 28)
ajhtiger + 3 应助
发表于 2010-3-16 22:21:56 | 显示全部楼层 来自: 中国广东韶关
不是所有硬度之间都能换算,而且换算值只能做参考。
发表于 2010-3-16 23:03:55 | 显示全部楼层 来自: 中国上海
好像只有经验值作为参考吧
发表于 2010-3-17 12:24:10 | 显示全部楼层 来自: 中国上海
什么材料用?需要此换算。
发表于 2010-8-6 09:39:41 | 显示全部楼层 来自: 中国山东威海
有美国标准asme 140.7
