查看: 2828|回复: 14
[已解决] 怎样实现精确定位?
发表于 2010-4-2 07:35:41 | 显示全部楼层 |阅读模式 来自: 中国湖南长沙
本帖最后由 唐昕晨 于 2010-5-19 22:50 编辑 * E9 F+ m) Y5 A7 f, [% U
. x: C  F( Y& @3 M
请问各位怎样在用Auto CAD绘图时实现精确定位 小弟刚刚入门 有很多不懂 希望各位多多指教 多谢
发表于 2010-4-2 08:15:30 | 显示全部楼层 来自: 中国台湾
OSMODE System Variable
# Q1 b3 x1 q7 c; P1 j4 y- v# K0 ^8 U8 f+ Z, \& s. q
Type: Integer$ ]) t" R1 K) x, t- _
Saved in: Registry% @  K/ V* c# V5 s- f  L
Initial value: 4133
1 S6 N  j5 M0 U; U: r" U( v" ~! R! a3 O& C" N
2 r0 }; ^; y* \6 ?, L6 Z$ B4 j
Sets running Object Snap modes using the following bitcodes:
9 S' Q9 u' C7 ~9 `: O6 L
% u7 n" v! r# i" m
* }+ O$ s- ?# ^; x0 K0 NONe " N/ z5 o& ^" j2 ]' p5 Q- G# L
% M6 d% O) E* s( b+ b1 ENDpoint 9 x3 V( O* S( z8 a) e
# `  i! r; z6 a+ A
2 MIDpoint
3 @  W; H# q/ k( }
+ ]2 ^3 M5 J: ^7 b4 CENter
6 J8 g2 ~0 ]0 N& Q5 ]: ]4 I8 O& L( M: V6 m1 L; x7 |& G
8 NODe ( {5 X- ?' v9 v
- X! N. r0 r3 Q) p( b; r
16 QUAdrant
2 T4 E8 |9 x1 n( o
0 ]' Q: M0 L5 |4 c32 INTersection 2 Q- P+ I3 i7 c7 _
! G  q, _$ \; p- k  u/ O64 INSertion
8 V: D; I" w( |8 {8 x: h3 B
4 ?7 Q& Z; i" m+ b: @% d7 s128 PERpendicular * S8 I4 v- {) {# f5 `
  z2 y! A3 _6 k( R256 TANgent
4 x( Q4 I1 v! y! a$ a
" `+ F! v: o0 S' o8 M512 NEArest
8 g9 d# d$ O3 ]# l! z
8 q1 v6 K+ l9 \- v7 F1024 QUIck 2 {7 M8 U+ V/ U1 f3 t( Q! s/ c& K
6 N4 e- G, x& t6 f* c, i* C. ~2048 APParent Intersection
. `1 p# H! [) f  k0 Z& R
) o+ `  b) |. w9 e1 l4096 EXTension 3 H$ K3 Y6 p' ?1 V& N( n
0 w9 k0 s; R4 Q- u3 z2 I/ \3 o8192 PARallel
- ~4 y0 h3 |$ K( E0 `2 \  P2 y: ?% y' A% ?+ l5 n7 J$ C+ W( x7 ]
& T- S0 _/ |( [; ITo specify more than one object snap, enter the sum of their values. * r, ~& a) ]& S1 P7 `+ i" d1 i
For example, entering 3 specifies the Endpoint (bitcode 1)
7 [4 j' c* s1 |( B% O  Dand Midpoint (bitcode 2) object snaps.
( O" h4 F  K6 G* Z. WEntering 16383 specifies all object snaps.
1 w3 N' ?! G. I, Z3 S0 J; ~* G- T8 H# M; S7 A$ T8 d9 o3 n# L% f$ M
1 ~8 ?5 D% d4 f. |9 XWhen object snaps are switched off using the Osnap button
% ]' A; \. V+ ~) t9 n& \" L0 xon the status bar, a bitcode of 16384 (0x4000) is returned,
6 Y. o' o) [& k. e# min addition to the normal value of OSMODE. With this additional value, 0 s: @. S) n9 p2 I9 n  f  r
developers can write applications for AutoCAD, * X/ u' x! [3 a* Q: p# @
and distinguish this mode from Object Snap modes
* m5 }* X! B7 ]that have been turned off from within the Drafting Settings dialog box.
' u$ T6 n6 C! g' t7 P: ]" @Setting this bit toggles running object snaps off.
9 H. M9 Q+ M1 r6 F* S% W( M1 KSetting OSMODE to a value with this bit off toggles running object snaps on.
发表于 2010-4-2 08:23:22 | 显示全部楼层 来自: 中国江苏常州
用捕捉功能,捕捉各种点,如:端点、中点等
2005llnn + 3 应助
发表于 2010-4-2 08:26:27 | 显示全部楼层 来自: 中国安徽淮南
1.直接输入坐标值;2 W+ I1 u) F$ J
2.格点捕捉;
. k9 S6 E) Z2 j3.对象捕捉;
wang2003 + 2 应助
发表于 2010-4-10 22:48:01 | 显示全部楼层 来自: 中国河南郑州
本论坛都有相关的教程,下载下来看看就明白了.
发表于 2010-4-10 23:34:39 | 显示全部楼层 来自: 中国上海
各种捕捉功能。。。
发表于 2010-4-25 13:18:08 | 显示全部楼层 来自: 中国陕西西安
例:画直线
! p5 V; F' o1 h" |激活直线绘制命令:在提示下输入坐标(格式:23,25)表示起点坐标(23,25),再在提示下输入坐标(50,50)表示直线终点坐标(50,50),这是绝对坐标。$ C" X  C+ G4 M# n
也可以用相对坐标。
发表于 2010-4-25 15:24:51 | 显示全部楼层 来自: 中国陕西西安
对象扑捉功能········
发表于 2010-4-25 23:22:16 | 显示全部楼层 来自: 中国江苏南通
可以用AutoCAD几何计算器用于快速定位,参考这个资料:
AutoCAD几何计算器用于快速定位的实例.pdf
69.83 KB, 下载次数: 14
2005llnn + 3 应助
发表于 2010-4-28 20:16:38 | 显示全部楼层 来自: 中国山东威海
直接用偏移命令,学要所少就偏移多少,绝对精确
发表于 2010-4-28 21:15:15 | 显示全部楼层 来自: 中国湖北武汉
打开捕捉,捕捉特殊点
发表于 2010-5-3 09:41:54 | 显示全部楼层 来自: 中国山西太原
一、坐标命令(精确)
% T2 H9 J, t; D0 k4 O8 k$ H1、直角坐标:绝对坐标(X,Y),或用相对坐标(@X,Y)
4 Z) ?% q* b1 A0 s2、柱面坐标:5 l6 C& V4 A5 t; g$ y# X/ c: \
3、球面坐标5 U- ^8 M4 W' M' h, j- S( V
4、极坐标% g9 v7 ^; F/ R* p. e9 A9 }
二、捕捉
  K- w+ N9 E0 X8 H1、直角坐标系捕捉
* J* D  A! j- a2 m1 a* u2、极坐标第捕捉
2005llnn + 3 应助
发表于 2010-5-19 21:49:33 | 显示全部楼层 来自: 中国吉林长春
2楼的兄弟,怎么回复的都是英文啊!
发表于 2010-5-20 08:04:16 | 显示全部楼层 来自: 中国山东临沂
相对坐标和绝对坐标
发表于 2010-5-20 13:45:59 | 显示全部楼层 来自: 中国上海
说法很多呵,研究下
