in the event of sudden closure of Emergency stop valve, the steam in the HP cylinder continue to expand and a small portion will get churned for duration of the difference in the time of opening of HP bypass valve and closure of the turbine emergency stop valve. The possible temperature rise due to the above will not exceed the permissible limit of temperature excursion permitted. : Z, U$ h( v* J- _9 r3 a7 F4 Z) t0 n5 r4 T7 m( m4 R/ p: ?8 W2 W
上面的意思是说在阀门紧急关闭的时候,高压内缸的蒸汽继续膨胀,有一小部分在高压旁路阀门开启和汽轮机紧急阀门关闭之间的会搅动,造成温度升高。% u$ Z* \" y- D3 s1 H! j. T
有谁知道为什么温度会升高,我对汽轮机不是很了解。
