2天前
查看: 5384|回复: 15
[公告] SW2010 SP3.0已经发布。。
发表于 2010-4-28 17:45:37 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
有图有真相。。
9 S  _: k2 V' h8 l5 W+ I1 ?
: _, \3 _# m7 z9 _: m7 V 1.jpg 7 L# j, [* m% ~
  K/ D: H  p# Q9 k7 O- R4 U
4 b! R- }3 a+ W* |$ U下面是下载的地址:5 k# V4 h* Z+ f, ~+ o1 @6 d$ ]; v
发表于 2010-4-28 17:55:00 | 显示全部楼层 来自: 中国安徽蚌埠
什么时候能下载啊??????
 楼主| 发表于 2010-4-28 18:06:49 | 显示全部楼层 来自: 中国江苏苏州
正版用户可以在线更新了,,,呵呵。。可惜我不会打包,,哎。。等别人来弄吧
发表于 2010-4-28 19:10:41 | 显示全部楼层 来自: 中国广西桂林
sw一年有几个版本啊?
发表于 2010-4-28 19:11:43 | 显示全部楼层 来自: 中国北京
不知道更新了什么,有谁知道的说一下
发表于 2010-4-28 19:37:27 | 显示全部楼层 来自: 中国天津
期待正式版本!
$ J" T3 r1 T: @" L4 T" G
发表于 2010-4-28 19:56:43 | 显示全部楼层 来自: 中国福建福州
更新的忒快啊。
发表于 2010-4-28 20:20:39 | 显示全部楼层 来自: 中国湖北黄冈
 楼主| 发表于 2010-4-29 08:34:29 | 显示全部楼层 来自: 中国江苏苏州
下面是官方的更新日志,不过是英文的。。6 d, Z6 J; T) z8 ?
* x  R9 B9 Z. ^! Q, h* F( k2010 SP 3.0
. r5 k' q0 c- Q
SPR #DescriptionProduct
138090Attempting triad SNL install, only first machine allows NIC address, not an option for servers 2 and 3SolidWorks
248786Helix curve does not honour 'this configuration only' setting when setting number of revolutionsSolidWorks
281031Dimension of a hole thread changes position when adding new holes to a hole wizard feature.SolidWorks
288312Drawing saved as dwg with fraction inch units when opened in DWGeditor, dim dragged, change to decimalSolidWorks
291216Acrylic (Medium-high impact) tensile strength is incorrect in SolidWorks material databaseSolidWorks
300709It is not possible to edit the offset distance in a extrude feature on double clicking the extruded feature.SolidWorks
307811Annotation items, Note, Balloon, Stacked Balloon, Revision Symbol, are not inserted into expected layer.SolidWorks
315526Edit Dimension Access needs to be removed from RMB menu for SolidWorks Parts in Feature Manager.SolidWorks
333619Recording the insertion of a sketch block onto a drawing results in an extra argument in the recorded macroSolidWorks API
337135Not able to save animations using the XviD codec.SolidWorks
347963swPerformanceVerifyOnRebuild is not applied even though UI looks it is turned on.SolidWorks API
370613VISTA ONLY: RX will not capture customer settings if UAC is on unless Run as AdministratorSolidWorks
372524Block with attribute on inactive sheet when saved is correct; re-opening in view only / quick view shows it incorrectlySolidWorks
391679DWGEditor.PlotManager settings don't effect plotting, printing, or previewSolidWorks
393710Can't reorder a component pattern in assembly, even though it has no parent-child relations with other features.SolidWorks
397013Enumerater 'swUnitsAngularDecimalPlaces' is not updating the dimension decimal places correctly.SolidWorks API
407775FaultEntity::ErrorCode returns unknown error codesSolidWorks API
420050Beam max stress annotation for mixed mesh static studies are wrongly locatedCosmosWorks
421138No example animation present in restraint property manager in 64 bit versionCosmosWorks
439302shift select multiple rows in BOM table followed by RMB > Hide selected will only hide the top and bottom rowsSolidWorks
452089On diameter dimension and Hole callout leaders, changing the bent length unable the text to flip as you move the whole dimensionSolidWorks
 楼主| 发表于 2010-4-29 08:35:29 | 显示全部楼层 来自: 中国江苏苏州
继续,,,SP3好像是个大的更新。。。。
1 f) `# |8 k; O( x6 q
, s1 g$ a5 }8 z
455563Auxillary view arrow does not move along with the drawing view while dragging needs force rebuild to appearSolidWorks
460475Printing SpeedPak Drawing with option 'Black and White' displays edges in gray rather than as black.SolidWorks
465063Working with dual monitors, the position of some windows is not rememberedSolidWorks
477056SW2009 doesn’t list out all view orientations created in the part. There appears to be limit on number of views displayed in View palette.SolidWorks
480270Meshing fails when result folder includes a lot of 2-byte charactersCosmosWorks
484012Sensors give a value of '0' for simulation data when they are defined using 'selected enties' on a selected bodyCosmosWorks
490799Cosmetic thread applied to outer edge of chamfer / countersink created by a cut revolve does not remain on outer edge - moves to inner edgeSolidWorks
491957When modifying a hole callout for a slot and adding the symbol to the callout getting error 'An invalid argument was encountered'SolidWorks
492747Can no longer unsuppress all components listed in the FeatureManager design tree with Edit ->Unsuppress with DependentsSolidWorks
492950Design table feature suppression state does not update assembly feature that is propagated to part/componentsSolidWorks
497946Need force rebuild (CTRL_Q) to create the cut list properties in the cut list folders of mirrored partSolidWorks
498605Crash on opening attached assembly in “large assembly mode”SolidWorks
500153Select BOM in this assembly and save as Excel format, get error message: The row height setting is too large for exportSolidWorks
502339ISldWorks and IModelDoc2::GetToolbarVisibility swContextToolbar always returns falseSolidWorks API
515139Update help to mention Pro/E Wildfire 4 is supportedSolidWorks
516640Units changes to 0 in fractions field when going back to check it twice.SolidWorks
517673When exporting to DWG a drawing with HLV views and the option 'Scale output 1:1" enable, the lines are displayed as Solid in AutoCADSolidWorks
518520Development investigation of PDMWorks ClientWorkgroup PDM
518899Rotating Region does not support cases where the fluid entering the rotating region is not parallel to the rotation axisCOSMOSFlow
519394Material displays in drawing's weldment cut list as 'LENGTH@@@@Default....'SolidWorks
520633Templates held in Enterprise Vault not found. User must manually manage their local cache.SolidWorks
521120Arrows for reaction force, stress, strain and displacement in a vector plot have the wrong directionCosmosWorks
525129Regression: in transient thermal analysis with more than 10 time steps, the new solver window stops updating information after time step 9CosmosWorks
527165Enabling 'force user login' does not pop up the Workgroup PDM login window on X64 SolidWorks.Workgroup PDM
527994Weldment cut list properties do not get copied in mirrored part, custom (file) properties get copied in the cut listSolidWorks
529289Measure dialog disappears after moving it to a secondary monitor/screenSolidWorks
529516Custom property of inserted part triggers new cut list property (not evaluated) in weldment partSolidWorks
529935Changing the per unit volume as a custom setting does not update the volume units in the mass properties dialog.SolidWorks
530231Thread pitch is added to dimension text again, after deleting it and CTRL-QSolidWorks
530249Save as pdf does not produce PDFSolidWorks
530761After selecting License order on client machine, SNL license is no longer accessible to client machines and "Flow Simulation Authorization Failed" message appears.SolidWorks
 楼主| 发表于 2010-4-29 08:36:13 | 显示全部楼层 来自: 中国江苏苏州
更新内容真的很多哦,,最后一贴# S+ _3 d  R) A* ~/ m" c; s
+ L3 r2 o$ a2 M
531096Unit is dispalyed incorrectly in the Design StudyCosmosWorks
531955Unable to open Inventor part.SolidWorks
532077Inserting block into part or drawing prompts for sheet formatSolidWorks
532195Crash when selecting reference geometry for orthotropic materialsCosmosWorks
532269Convert entities with no external references crashes SolidWorks 2010.SolidWorks
532617Error when adding a cosmetic thread 'Thread diameter is not valid. Please enter a value between...'SolidWorks
532764Perform system check to prevent installation on non-supported operating systems / processorsSolidWorks
533302Cosmetic thread User Interface does not list the thread sizes bigger than the hole size. User needs to edit the feature for this.SolidWorks
533434One or more load/fixture/contact associated entities may not be valid' even when invalid entities are suppressedCosmosWorks
533896False message 'You must first save virtual components.....before using them in a drawing...' while creating drawing for these components.SolidWorks
533900Cannot delete or override diameter symbol from dimension text.SolidWorks
534235Contact pressure is not displayed in2010 SP02. Only chart is there. Regression from SP01.CosmosWorks
534262Crash when creating sketch with converted entities, if 'Name feature on creation' is enabledSolidWorks
534349Installing from SolidWorks 2010 SP0 DVD generates "The source folder is not versioned properly: ..."SolidWorks
534586Mass properties of this multi body part are incorrect at assembly level - materials applied at body levelSolidWorks
535135‘Failed to save document’ warning saving virtual component with 'Open referenced documents with read-only access' option enabledSolidWorks
535259When balloon tool is active ‘Select Other’ does not workSolidWorks
535617XP x64: Since upgrading to SolidWorks 2010 SP2, nothing happens when trying to create a design table, insert bend tables, or insert excel BOMsSolidWorks
535687Can not update an administrative image from manual download packages.SolidWorks
536279Performance regression editing and modifying weldment sketchesSolidWorks
536468Changing length units in mass properties settings produces wrong results.SolidWorks
537407Center text dimension for diameter is not available anymore (PM and RMB)SolidWorks
537469Get an error 'An instance of a design table is already being edited in its own window...' when opening the design table the second time.SolidWorks
537666SolidWorks crashes frequently when trying to open assembly files.SolidWorks
537952Unexpected error opening assemblySolidWorks
538028SolidWorks terminates when you try to use the "Compare Results" option.CosmosWorks
538390The API function ISldWorks.GetConfigurationNames(FileName) works only, if model is opened,SolidWorks API
538547Vector plot is not displayed for Contact pressureCosmosWorks
538772adding a mate on an assembly that contains mirrored components creates a Crash.SolidWorks
538827Design study force units are incorrect, leading to incorrect results, 64 bit machineCosmosWorks
539844Cannot save as Adobe Illustrator format when the part or the assembly is displayed as HLR.SolidWorks
542266Crash: SolidWorks encountered an error opening the document, when open drawing in lightweightSolidWorks
545174Material property defined in config does not get filled in drawing cut listSolidWorks
发表于 2010-4-29 08:36:47 | 显示全部楼层 来自: 中国广东深圳
等待中,等待下载
发表于 2010-5-1 14:32:25 | 显示全部楼层 来自: 中国上海
正在下载中,不知使用起来怎么样
发表于 2010-5-1 17:46:21 | 显示全部楼层 来自: 中国陕西西安
等待 SolidWorks 2011 版本……
发表于 2010-5-2 23:37:39 | 显示全部楼层 来自: 中国广西桂林
好资料,感谢楼主分享,及时通知
发表于 2010-5-3 22:19:36 | 显示全部楼层 来自: 中国福建三明
希望早点能找到下载
