查看: 19563|回复: 71
TraceParts DVD 2010(2.6.1)全球著名制造商2D 3D CAD零部件库 +样本手册[SolidWorks]
发表于 2010-4-30 12:05:29 | 显示全部楼层 |阅读模式 来自: 中国广东佛山
本帖最后由 hifi 于 2010-4-30 14:29 编辑 5 T( G6 N- i2 Q7 d
9 u6 O0 H, M1 `
TraceParts DVD 2010 (2.6.1)7 e5 ~& ?& y: K6 x! a5 q1 H3 u
+ i( \6 Y- l& j1 e+ J; u1 M" R+ `+ v
您可以从下面的网址下载为期 10 天的 TraceParts DVD 试用许可证 (3.41Gb): , e7 F) u) I! q* s9 j  n2 p
http://dl2.traceparts.com/dl/traceparts/tpdvd/updates/TP-v261.exe+ {8 |+ ]; e8 P
/ N# ?! l/ H  N& _$ b程序用 Concept Software Protection Plus 加密可以免费使用10天.
6 [$ F" w7 c( F& q
* @8 Y/ _3 `4 ]! f4 t5 N( Y
, ]5 {7 ]6 |4 z" M3 Y5 }7 |7 yhttp://www.traceparts.com/users/img/bannerparts.gif
! K* M3 V# d& Q! o3 h/ ~( b# q* r, F, M
全球著名制造商的 2D 3D CAD 模型和样本手册合集
1 j% n8 d: q# Q  o6 t1 Q6 p
, \6 P' }: y5 P2 H. t6 thttp://www.traceparts.com/users/img/partfinder.gifhttp://www.traceparts.com/fr/users/img/TPv235.gif4 m4 \9 T. ]  M7 ~& F, a* k
2 b$ ]# x) g$ D8 ?
3 I+ Q4 [; k8 Y
$ [2 H9 N4 x% w6 B- A支持的 CAD 软件和版本(直接生成含特征的原始格式)
1 V4 S5 Y% |$ g$ LAutoCAD# H) G! x; y7 T6 i- j
New: Support of AutoCAD 2010
+ N% V* r% e5 D) A3 T% G  x& U4 Q) R5 c( C
AutoCAD Mechanical
; @5 L( g8 ]# C( L" x) C: DNew: Support of AutoCAD Mechanical 2010
: ~4 r; j! d- _
6 }; w) V( e5 I4 Y2 i9 ?CATIA V5
" f0 g: H" z' J" ^# ?1 aNew features :
# k% b) V% v# i» Support of CATIA V5R19 in 32 and 64 bits4 b6 Q4 F5 Z, k+ n: E4 m
» It is now possible to prevent the modification of the BoM attributes for parts instantiated by TraceParts DVD (advanced use).- j+ y  x( a% H( C8 o2 g
change: Improved "Add your own parts" feature.
% u6 r& e5 r4 m0 H8 [# C  N) e, n, C
Inventor 1 U) S! K; t/ G; P( G1 H
New features :; C4 W) C$ K9 P; X+ _7 `
» Support of Inventor 2010 in 32 and 64 bits/ L9 Y1 t5 X& _4 d
» Add your own parts" feature: users can now add their own native Inventor parts or assemblies (IPT and IAM) to TraceParts DVD. This new feature requires Inventor 11 at minimum.0 [, J$ r5 R/ W4 p+ |
* T5 L7 w; T8 m% q% p' _0 D
Pro/ENGINEER
  ?4 \5 @0 T4 r% G, qNew: Support of non standard installations of Pro/ENGINEER Wildfire. 8 ~, A, I! E, P; V0 C, D" Q
change: The minimum version to be used with TraceParts DVD is Pro/ENGINEER Wildfire 1.0 (Pro/ENGINEER 2001 is no more supported).
' d) o' m" }; Z! f2 o
  ?/ D5 K9 ?. @- dSolid Edge
! B8 k$ c) d: y5 j5 O) @# A" Gnew: Support of Solid Edge ST 1.0 and Solid Edge v20, in 32 and 64 bits.- d" ]+ A/ D2 T" U1 q6 D. @; Q% W
change: Improved driver for Solid Edge with a better robustness.) r. l) n4 x% G
. {0 @( U- [0 G& \8 V5 F' F* {* n! _
SolidWorks9 f, P" }3 o# r8 e
New: Support of SolidWorks 2009 and 2010 8 L8 F3 K* b; X1 U6 M4 |
7 \* k5 P, r/ e+ x  p$ j+ L3 ?thinkdesign . L4 G" P5 `1 r) X5 O
New: Support of ThinkDesign 2009.1/ w! P1 @7 ~! x+ N% F/ F
3 \. U- `$ i  M& d7 STopSolid
( b% B9 m- f) ]: n7 CNew: Support of TopSolid 2009 (6.10) in 32 and 64 bits.7 @  R, V7 `! {. {* w6 H. v+ @& M
* Q1 n6 L, c5 s! Y2 M. x1 P: gTurboCAD New + w# Y; c+ j" i# ~
New: Support of TurboCAD v15.* y# y; R# x7 S( E. ?
$ s& o1 k8 f% p
4 M0 V4 ]8 G' t1 Q' P- M2 L0 @! W1 `; X/ @4 a7 O- n$ m5 r
TraceParts contains more than 100 million CAD drawings from all the leading Parts Manufacturers, including:
. @# N6 B0 I6 Q$ a/ w  o  i9 J9 _& gAdvantech, Aerotécnica, Alex, Ameca, Asco Numatics, Assfalg, Atlanta, Atlas Copco, AVIT, AVO, Béné Inox, Binder, Blickle, Bosch Rexroth, Boutet, Burster, C2G Soudage Innovation, Carr Lane, CCB, Cepex, CGI, Chambrelan, Clippard, La Clusienne/Clufix, Codipro, Corderie d'or, Contrinex, Coval, CSR, Decril, Dinel, Dirak, Drumag, Elan, Elitec, Emile Maurin, Enerpac, Enomax, Epidor, Euchner, Expert, Facom, Fibox, Finder, Finsterle, FIP, France Linéaire Industrie, Ganter, Genustech, GGB, GHV, Girard Transmissions, GMT, Halder, HEB, Hervieu, Himel, HP Systems, Hydropa, IFM, Igus, INA/FAG, Inocon, Item, ITV, Jakob, Joyner, Kabelschlepp, Kinetic, Kremp, KV, La Clusienne, Legrand, Legris, L'Etoile, LMC, McMaster-Carr, Mädler, Mayr, Mecabor, Mecalectro, Michaud Chailly, Misumi, Nadella, Nilos Ring, Norelem, Normydro, Nozag, Pinet, Poggi, Progressus, Qama, Quiri, Rabourdin, Richco, Ritz, Rodriguez, Rohde, Römheld, Rotarex, Rötelmann, Rud, Sapelem, Sarel, Schmalz, Schmersal, Schneider Electric, Schweizer, Sermax, SFA, Sherex, Siam-Ringspann, Sick, SIT, Smac, SNR, Socafluid, Somex, Stauffenberg, Ströter, Stüwe, Suhner, Sumer, TAT, TEA, Techné, Tecmeca Pacquet, Tecnodin, Telemecanique, Thoptec, TME, Trelleborg, Vishay, Vogel, Wasi, Wefapress, Winkel, Zimm, ...! t4 ?, ]  k* E: f1 `
3 T1 }3 k# e0 o1 n7 q' {5 S! K" B6 H
Native CAD format
* _0 ?( U* }0 r$ ?( T+ R0 ZUnlimited compatibility8 S( j2 n, e& M" m' V  [1 N
Data created using TraceParts provide multi-CAD compatible models that can be integrated into most of the CAD systems available in the world. For more than 10 years, TraceParts has been partnering directly with all the leading CAD vendors. This ensures compatibility with the relevant latest versions and closer relationships with their R&D and marketing departments.
/ D2 [$ W# O6 G. I4 Y3 s' C  y3 b5 v7 ~" i1 x
TraceParts is for instance the first and still only CATIA CAA V5 Software Partner of Dassault Systèmes in the field of Parts Libraries. More information about this partnership can be found on Dassault Systèmes' Web site http://www.3ds.com/ H4 C+ V% z& \9 v
" ]2 V* R: m. u( _# t* g, _http://dl2.traceparts.com/wtp/en/partners/img/caav5.gif
2 ?) @+ a) `+ ?  F$ s: z' S
( P, F" q* D( Q. ?5 a5 X+ K8 I6 D' L) ITraceParts has direct and long term partnerships with all the leading CAD & PLM vendors:
http://www.traceparts.com/partners/img/ascon.gif
http://www.traceparts.com/partners/img/alibre.gifhttp://www.traceparts.com/partners/img/autodesk.gif
http://www.traceparts.com/partners/img/ds.gifhttp://www.traceparts.com/partners/img/granite.gif
http://www.traceparts.com/partners/img/Solution-partner-siemens-plm.jpghttp://www.traceparts.com/partners/img/sw.jpg
http://www.traceparts.com/partners/img/spaceclaim.gifhttp://www.traceparts.com/partners/img/spatial.gif
http://www.traceparts.com/partners/img/think3.jpghttp://www.traceparts.com/partners/img/TopSolid.jpg
8 H6 ]" v* L1 J" U0 t9 \4 x
+ h# W2 N0 B; V) U1 l0 I1 W% Q  }7 k2 `- _7 Y5 I
. E# q/ X8 l( ?- i6 t: Y! w- Whttp://www.traceparts.com/help/en/img/Tp25x_Install_catalogues_03.JPG
3 a" f* {' g9 w/ A9 n" Chttp://www.traceparts.com/help/en/img/tp25x_install_14b.JPG
 楼主| 发表于 2010-4-30 14:25:38 | 显示全部楼层 来自: 中国广东佛山
Flyer-TPDVD-professional-SolidWorks-web-en_Page_1.jpg Flyer-TPDVD-professional-SolidWorks-web-en_Page_2.jpg
发表于 2010-4-30 18:42:14 | 显示全部楼层 来自: 中国山东东营
看起来像好东西,不过有破解版吗
发表于 2010-4-30 19:54:55 | 显示全部楼层 来自: 中国山东烟台
同求破解版
发表于 2010-4-30 20:55:21 | 显示全部楼层 来自: 中国广西桂林
好资料,感谢楼主分享!
发表于 2010-4-30 23:06:51 | 显示全部楼层 来自: 中国河北石家庄
有完全免费版么?
发表于 2010-4-30 23:27:12 | 显示全部楼层 来自: 中国江苏无锡
英语水平有限,最好有中文破解的。
发表于 2010-5-1 08:14:00 | 显示全部楼层 来自: 中国江苏南京
“只能试用10天”最好有中文破解的。
发表于 2010-5-1 08:58:08 | 显示全部楼层 来自: 中国浙江宁波
2# hifi 好资料,感谢楼主分享
发表于 2010-5-2 16:52:58 | 显示全部楼层 来自: 中国江苏苏州
只能用10天就算了
发表于 2010-5-2 20:10:44 | 显示全部楼层 来自: 中国福建福州
只有10天?10年都觉得太少哇。
发表于 2010-5-2 20:13:50 | 显示全部楼层 来自: 中国辽宁沈阳
不错的东西,可惜只有10天,纠结啊
发表于 2010-5-3 10:49:21 | 显示全部楼层 来自: 中国江苏苏州
还是下来安装了,完全安装耗时两个多小时,快要崩溃!最后还是删除了。但确实是好东西,可惜只能用10天,不过可以每10天装1次。
发表于 2010-5-3 11:05:42 | 显示全部楼层 来自: 中国福建福州
如果有长时间使用的版本,对个人用户来说,应该是允许的。这也是一种推广呀。
发表于 2010-5-3 11:08:18 | 显示全部楼层 来自: 中国北京
solid-user大侠能否帮助破解?期待大侠能帮助破解!
发表于 2010-5-3 11:54:52 | 显示全部楼层 来自: 中国黑龙江哈尔滨
好东西,下来试试!
发表于 2010-5-3 13:39:34 | 显示全部楼层 来自: 中国江苏泰州
solid-user大侠能否帮助破解?期待大侠能帮助破解!  U% B0 X# P3 Z
wcmjmw0 发表于 2010-5-3 11:08 http://www.3dportal.cn/discuz/images/common/back.gif
  _! ?9 u0 n9 {+ R2 M4 k
6 J9 o+ c! v2 K: csolid-user大侠?!可能吗?# r  u  d' M+ M9 q, ~
8 \! d, C% x1 K
要能破解早破解了
发表于 2010-5-3 16:58:42 | 显示全部楼层 来自: 中国浙江绍兴
每10天装一次,软件的使用技术没怎么练好,安装的技术可是练到家了!  G' O/ k: p/ y+ r: X' X3 A
还是支持楼主的做法!让我们多长见识!
发表于 2010-5-3 18:15:41 | 显示全部楼层 来自: 中国浙江杭州
太好了,好东西啊,很有用的
发表于 2010-5-3 20:06:31 | 显示全部楼层 来自: 中国江苏常州
期待早日能有人提供 Crack.
发表于 2010-5-3 20:40:41 | 显示全部楼层 来自: 中国福建福州
10天太短了。
发表于 2010-5-5 07:59:36 | 显示全部楼层 来自: 中国河北沧州
期待早日能有人提供 Crack.
发表于 2010-5-5 09:34:26 | 显示全部楼层 来自: 中国江苏无锡
这里面的提供的标准有国标吗?
 楼主| 发表于 2010-5-6 10:26:28 | 显示全部楼层 来自: 中国广东佛山
本帖最后由 hifi 于 2010-5-7 17:15 编辑 - l1 {# z; q: U2 v7 v# Z
% Z, j/ G* {' p' d* r% n/ u送上30天的 Licenses8 T* A8 Y' t8 v3 y1 U
  @8 f: _: ^0 l
# T  c1 X. C3 j9 l0 j
在不能联网的机子上效果好
Crack.zip
914 Bytes, 下载次数: 234
发表于 2010-5-6 10:51:30 | 显示全部楼层 来自: 中国辽宁朝阳
相信一定会有破解的!
