发表于 2006-7-18 21:55:29
来自: 中国广东佛山
Issue
( e1 P! D# [; x- o# HYou want to know how to create a PDF file from a DWG file.
! ?; E0 a' O. _( K8 }' ] o V3 c====================================================================! |( g; `* A# V" {/ h
Solution 1
- z D' O6 z* Y& X! l3 \* {6 z; hThe following method usually produces satisfactory results, but some lineweights may be incorrect:
2 Z9 i2 g9 {9 i9 D# ^) B/ f2 a+ T ^; @# R
From the AutoCAD® or AutoCAD LT® software, configure the Adobe PostScript® plotter driver and plot the drawing to a PostScript (EPS) file. 4 J) x' h1 F, M1 p2 G' ]1 D
Open the EPS file in an Adobe application, such as Photoshop or Illustrator, and then save the file as a PDF file.$ E! l2 K5 x& O# B; P' N/ }
) g# z, y0 |- H+ p8 A
Note: If you need an alternate method, you might want to search the Internet for a third-party solution to convert DWG files to PDF format.
) U4 q" ^8 x8 c6 R) w* N====================================================================6 T; d( O, y3 o9 v0 B/ b: u0 i
$ \* g4 {: t! j" k6 y* s DSolution 2
, n S4 T$ q2 } L
2 K$ m! [' {- y! h& c0 tAcrobat PDFWriter. This Windows-based system driver directly creates PDF files and will give the best results with most drawings. 6 |- X/ u4 N& I" t' K6 c3 D1 ?8 O
* w8 T( J2 c/ w9 U2 C( z' Z
Note: The Acrobat PDFWriter driver is not installed with a typical installation of Adobe Acrobat. To install the Acrobat PDFWriter system driver during the installation of Adobe Acrobat, choose a custom installation and select the Adobe PDFWriter check box.5 g' ^2 F: S- M
$ j" W, W- \7 G; ^; n" xSolution 3
/ Z+ g' w9 n7 X( e5 g1 @
4 x& Z6 Z& S0 ~2 O2 P: Z: QAcrobat Distiller. This Windows-based system driver can be configured to create either PostScript (EPS) files or PDF files. If EPS files are created, Acrobat Distiller can be configured to automatically convert the EPS files into PDF files. This driver should be used only with simple drawings. For most AutoCAD drawings, better output is achieved with Acrobat PDFWriter. |
