. A' W) T }2 l/ `: O; B) Z& o4 r8 Z- u# |, y
RT
: G) n) B8 F) k) `6 H. [1.安装时怎么输入序列号啊?+ s7 t& C. i E4 O2 ~' F/ X
2.要不要禁用网络(内部网)
( b* i' M! V* x: G8 ]3.安装完成,启动提示一个类似:无法找到使用许可文件?记不清了!!
" n6 o% y+ X$ D! Y* u3 V4 J1 Y- H1 u哪位可出一个此版的安装教程啊?感激不尽!
% [2 E f0 K! D8 _
6 Z% C! \; a( G 6 B% i/ @% _4 r g+ E. d6 _# O
1. Install relevant sw2010 update and other updates as needed.
# q) t3 B% U: K( X9 ]5 i$ Q8 QNOTE: If you installed our SP1/2.1 releases, the upgrade patcher may fail - restore original sldappu (bundled) and try patcher again.3 G- D( \, k4 f6 p- v4 P
2. Copy ibfs32.dll to windows\system32\
" t" j: L' s3 Y6 k4 t: S9 H6 r3. Import lz0-sw2010.reg to registry.6 E( W. P M, j
4. Copy sw2010.lic and lz-solidworksx32.exe to C:\Program Files\Solidworks\$ L" u) [6 s7 |5 Q9 r
5. Run lz-solidworksx32.exe (Run as admin required on Vista/win7)
" L# U) u# j/ l @5 K2 X' R6. If installed, copy and run if applicable any addon patchers/patched files to appropriate dirs (eDrawings common files\edrawings2010, photoview, swexplorer)
0 `$ C0 z: Q/ ?* C( @7. Enjoy!
5 ?" `- q8 |9 q" i2 h2 C, cNotes:& J! T, g" A' S( u
1. SW2010-x.x-3.0 update might give an error regarding security framework. Click OK and ignore.
" i5 p1 U2 m$ f2. when installing COSMOSM, skip license setup - it will work with the reg/lic above
- T3 C# o! Y; f6 y' p. v3. If SW shows x days to activation, reinstall using SNL serial number: 9916 5719 6888 1432 57K7 Q892 # [9 Z2 c4 d7 U" Z% ^* S+ f( O
我的步骤:
3 R' u* b5 @8 \. ?- j. d' a. A$ A1.点setup.exe单机安装(网络禁用)7 C; t# S4 a( l4 W$ ~ d! P4 a
2.输入SW序列号:9916 5719 6888 1432 57K7 Q892
( f, m' K; f9 i: J9 T3.其他产品序列号未输入
; [8 p Z! [# A; D* y. h3 S+ B8 Z4.提示指定“网络端口”未输入
% v3 P+ z; j, M5.安装完成后按以上的“2,3,4,5”破解
, D# B( D8 n5 z- l) q6.启动SW提示“无法找到使用许可文件”! u, n) h, b8 T- T! j/ A* ~
恳请协助! |
