! m& q% H/ S6 V' `
2 r0 U" w s' x1 ?' T/ m求助:有偿设计两维曲线变成3维图形(13701297901王先生)
5 N) O2 O Z$ J* g) |+ }" F7 l2 m+ E/ R3 t6 q9 a
两维:距离(或者叫厚度、高,每个都是固定的:0.18Cm);同心圆横截面积(可提供几个特定距离点或者每一个点的横截面积组数据)。
7 s/ E- i/ c# ]! V! a- G9 P+ F# n5 U4 g) T
(以下是每个同心圆的横截面积值,高都为0.18cm)! P# Y x! t q
0 j8 M. s2 }# b/ n- 0.0547384313 ! i7 b% `- t w+ y E
- 0.9758905991
, e4 n) j z" V: m+ N - 0.9087750625
9 a& _; u$ \2 Q - 0.8833772966 # H+ y9 \. o5 ?& h- o% x0 O
- 0.8945792372
; \/ L: | J9 y; \$ E2 u k G4 @ - 0.9253024879 % f# f t2 i6 V C
- 0.9285757433
2 a8 F9 a6 H( X/ @' ~+ P - 0.8722903768
4 ~3 d6 Z: `0 r, i R - 0.7643903324 h* P) g# O; Q6 t. O4 `- r1 t
- 0.6426339493 + c+ E3 P5 r1 E1 T* L: R/ K) ^
- 0.5522512299
7 i. P- @4 L* I - 0.1071543023 2 h* z y# I+ u6 O6 R% |
- 0.5152965651 2 J4 B5 X" J5 u* t9 V
- 0.5680789063
, q* o W: q4 c5 E- A - 0.6566464065
/ H t% @! z4 L, \ - 0.7603061474
7 w0 W/ ?9 n# @5 x' Y2 ? - 0.8607047648 7 [& g. B; K$ j
- 0.9498151130 / Z' G2 N0 h$ I4 h0 Z* x3 n
- 1.0231859785 8 p' Q; T. P$ G
- 1.0945783232 ! s# I/ a$ s* B- ^ h% l) ?) V
- 1.1533797502 . Y ^8 C9 M- P! b- Q
- 1.1941300848 - g5 s( f9 I/ m) n* l* }
- 1.1969346456
H. q+ T+ `1 j - 1.1699235014
8 a1 F- v# I- e' m& n! z - 1.1311518135
8 y$ O8 r! x( b$ i - 1.1086286240 # _5 X8 O% b0 L, y
- 1.1330743513 7 G$ O) D6 i, E. P
- 1.2159964046
/ c; ^( A! q; M# F+ v% v - 1.3697965144 # ?& l7 M3 S2 t6 w' I+ p8 Q8 Y& D" h
- 1.5648495403
4 F4 _7 B3 e, ^- k# W4 ] - 1.7586206696 / U+ t! s8 y! y
- 1.8734292445
* V2 B$ {, l$ L, F/ ] - 1.8646770334
- c/ t7 u* ]; ] - 1.7399865423
$ g" B* m/ \( G% N - 1.5677198524 ) [/ K* ^# v$ D" q; s
- 1.4305114197 . L5 P. O# [0 Z$ `9 U# E2 k2 P9 {
- 1.3652029140
7 m O9 {5 v$ c* a7 h x - 1.3976630564
1 L. K2 ]! ^$ I; d% T - 1.5222760992
+ O' ?- ~& N# c4 r" j' r* ~5 j3 ^7 w8 d - 1.7367039797 % A6 g* P/ n- m4 ~; r& c% y
- 2.0081290038
* [6 x L9 V7 p, s0 q - 2.3009967779
' J& u2 L; i6 M3 b: N - 2.5703639512
+ f9 [! Y, J1 i! {7 V. T' C4 @ - 2.7815010920 0 O$ V: h/ w, n7 q6 s
- 2.9399229339
1 R W* n+ @4 o6 n - 3.0492886853
k B% d- a( t+ q. o& ^$ ~4 A - 3.1620606594 $ D! k- n. N$ b2 U+ t6 ^2 E
- 3.2926085721
: K, e0 ?4 p. E0 u) S - 3.4617286107 + @* j3 ^, V) t8 k0 m7 M$ M
- 3.6524711404
3 R O! \/ R t, [ - 3.8536056813 ! u2 J+ e% ^% I$ U; O" o
- 4.0376698506
& s) [# r: ?% R# Z5 D - 4.1765864955
! J$ m$ {! d9 b I; A1 y - 4.2926543731 # w/ J. x; L/ M, X* @7 J7 }
- 4.4016889998 " r& J0 p. X! ^" C% x+ P; t9 \
- 4.5725416388
$ {7 v2 e6 l3 j }2 |8 V3 G - 4.8372970822
% o9 V0 r8 L3 z* f7 I - 5.2551538512 7 P4 s q7 ^7 w" |+ M0 Z/ p
- 5.8268851450 1 a( }8 F8 V& N* v! @
- 6.5219105301 - t; R- B4 \6 m9 t6 g1 ~& f: Q
- 7.2270313281 ( i# g" A5 O4 W9 E8 Z7 b3 X$ H
- 7.7372484744 & v, n$ c: k7 p! l7 B9 T
- 7.9220889115
: R0 h9 u4 x! `0 Y' O% R - 7.7275145396 , l% i7 a* Z8 H- {
- 7.3271048661
! I% l. D, M% e- R' Y \ - 6.8822972565 P# E" i" E, n; e# U3 \) d
- 6.5387086913 . F5 e! O! D+ J) m" C2 q
- 6.3180473346 ]" v( P7 S2 j, l! ?
- 6.1935381449 7 A- z! [) [& }- }
- 6.1128506299
* n- w h u; P {, @ - 5.9904236799
, G$ g- j% Y A% o7 g5 h7 b, c - 5.8283263426
7 C0 I, Z/ t/ `/ @ - 5.6437100172 . C; n2 O7 z: w1 F3 H
- 5.5253572482
8 X4 C, r/ B6 a8 d( J9 F. y6 y+ q) Z - 5.5287797621
5 T9 d7 p& `" K" j. [ - 5.7275306761
# M6 Y W& F4 a6 |5 Q3 H
复制代码 5 ^, t7 r+ T# K) P& k( o; u. H1 t
4 z# a3 m; a" @8 a) ~3 [* o5 c
* _5 }" j- f; K4 y1 t. d要求:1。制作成3D图形(如下图)
( n! H# S) j! L7 S& p; P, A" Q1 H$ ?$ D, J; o" D
2。我们提供任意一组上面的数据,或者几个特定距离的横截面积值,都能得到不同的3D图形。+ U2 q# W4 V* ~. D# E8 p; N
3.可以切开任意点的横截面,看到该横断面的情况。
0 q$ I# r' O% k! m
. ]; b( ^4 O+ W3 F W! u! r) b! b% H6 I
