| Item No | Describation of goods | Quan. | Unit | | 01 | 13 3/8''OD seamless steel,Grade L-80,68 IB/Ft,BTC Threaded and coupled. Length Range III | 48000 | meter | | 02 | 13 3/8''Casing Nipple,Grade L-80,68 IB/Ft,BTC pin X pin,3 M long | 28 | No | | 03 | 13 3/8''Casing Pup joint,Grade L-80,68 IB/Ft,BTC theaded and coupled, 6M long | 8 | No | | 04 | 13 3/8''Casing Pup joint,Grade L-80,68 IB/Ft,BTC theaded and coupled, 3M long | 8 | No | | 05 | Casing coupling for 13 3/8''Casing/ U9 H0 Y% u0 e; Y( _( X
| 10 | No | | 06 | API casing drift for 13 3/8''Casing ,compelete with draw eyes at both ends | 4 | No |
# F/ {# Q/ A% {4 D
3 o" v% l0 s3 z" _/ L请问一般石油套管都是怎么理论计算重量? 还是采用 =(外径-壁厚)*壁厚*0.02466 " w7 e1 [& R% g+ ^$ I- D% A4 v* b
另外我看到 L80钢级 有三种类型 1,9Cr,13Cr,, |6 H. Q& q) A- C2 L; X x3 [# G
一般什么情况下才采用9Cr,13Cr? |
