请教各位行业内专家,以下句子如何翻译?“a sheet”何意? d$ R. V2 Z2 o2 o$ U& YThe gasket material here means a sheet which will be cut to a required form and, directly thereafter or through additional working, be used as gaskets.
The gasket material here means a sheet which will be cut to a required form and, directly thereafter or through additional working, be used as gaskets8 X) F% M5 A m" D [
The gasket material here means a sheet which will be cut to a required form and, directly thereafter or through additional working, be used as gaskets" V9 P, D% x' A# r
这里的密封材料指的是一张板材,可以切割成需要的形状。直接使用或修整后用作密封垫。
