1. 建立一个打印机配置文件。例如需要添加惠普的Designjet 430,则建立一个打印机配置文件Designjet 430.pcf。 用记事本进行如下编辑:
0 t4 `; }3 s1 @! l( Xallow_file_naming yes Y; W5 n* I" u9 {) U/ P
button_name Designjet 4303 A6 D7 u$ B8 Y9 W8 n0 G
button_help Designjet 430(ALL size)- c- G0 q: T! A" Z7 u) y4 ?
delete_after_plotting no2 H" F% `- C( H* O) ^4 R
interface_quality 3
6 |0 }) x% l2 h3 N$ {8 L* H: apaper_size variable8 b) G& {, T/ Q3 L' ]% Y# q7 g5 q" d( p
pen_slew 15- r+ Z! U+ E. m8 F* n
pen_table_file e:\custom\user\table.pnt7 Z: `9 K- P- z" b0 s/ H
plot_access create4 K" ~( u5 e. B! P( J; W0 E
plot_clip no* m" n0 n0 m6 X2 {
plot_drawing_format yes8 h8 L. H# I$ R
plot_label no
4 z x( L& w5 v0 C3 f; X) Tplot_layer current( w* t+ s8 }" n S# ~ W/ |9 O
plot_linestyle_scale .25
) e0 B- s7 D& z0 N% D, N6 tplot_names no; t4 ^) l0 a# D f- p
plot_segmented no
9 Y0 j7 A8 ?3 h8 m: Rplot_sheets current+ h1 D5 n. X; @& G E
plotter_command windows_print_manager1 t2 M! |* V2 V
plotter designjet650c
6 H/ u5 l- a* k# S. H其中pen_table_file是笔宽配置文件table.pnt的保存路径。编辑后保存为Designjet 430.txt,后更改其扩展名为Designjet 430.pcf
/ {9 n4 V0 j2 K; }; A7 [8 M2. 编写笔文件table.pnt如下:pen 1 color 0.0 0.0 0.0; thickness 0.045/0.01 cm;pen1可见几何,剖面切线和箭头,基准面等drawing_color
: d3 N3 A- q! r5 L- ]pen 2 color 0.0 0.0 0.0; thickness 0.015/0.03 cm;pen2尺寸线,导引线,中心线,文本,注释等letter_color3 K+ D6 |' J B6 }
pen 3 color 0.0 0.0 0.0; thickness 0.015 cm pen3隐藏线,阴影文本half_tone_color
7 B; h* }7 l. I2 k8 mpen 4 color 0.0 0.0 0.0; thickness 0.015 cm pen4样条曲线网格highlite_color
( G, V) ]2 _1 n1 Bpen 5 color 0.0 0.0 0.0; thickness 0.015 cm pen5钣金件颜色图元attention_color5 s0 _" n/ ?$ @) p, }
pen 6 color 0.0 0.0 0.0; thickness 0.015 cm pen6草绘截面图元section_color
- W) H0 J2 ^8 ]) e3 Apen 7 color 0.0 0.0 0.0; thickness 0.015 cm pen7灰色草绘尺寸,切换了的截面dimmed_color
2 \, u4 z! Z# \0 J% Gpen 8 color 0.0 0.0 0.0; thickness 0.015 cm pen8样条曲面网格edge_highlite_color pen x color x.x x.x x.x; thickness x cm
- \) d `5 G! T tcolor x.x x.x x.x代表 pen x 所打印出的颜色,thickness x cm代表 pen x 所打印的线宽。
: N+ N5 R: y6 U3 Q3. 在Config.pro中增加 pro_plot_config_dir e:\custom\user。启动Pro/E,然后把Config配置文件载入,如果你想做永久设置,可以把这行写入安装目录下的TEXT 文件夹下的config.sup文件里,你就可以使用自己定制打印机进行打印 8 s4 z8 o7 H3 e+ R4 r
前面是我在网上找的设置方法,可我却怎么也找不到config.sup文件,启动Pro/E,又是如何载入Config配置文件的,请各位指点一下。 |
