查看: 1752|回复: 0
[求助] 替换特定字体之外的字体
发表于 2010-8-11 18:00:02 | 显示全部楼层 |阅读模式 来自: 中国北京
我想替换CAD文档中楷体_GB2312之外的所有字体为txt,bigfont,现有网上下载的代码一份,请问哪位知道怎么修改?! [5 D. [7 ^. _  M1 ]- }
(defun c:rep (/ elist nm en cn enl)
% X" p" r$ I& P& Q0 @  c    (setq elist (tblnext "STYLE" T))
! J6 `  @+ q, Y3 `& c6 A0 k: F    (while (/= elist nil)
5 u" T" i! i& c- q8 ]      (setq nm (cdr (assoc 2 elist))
$ [- c) ?/ Y; O            en (cdr (assoc 3 elist)) , w3 w8 I0 B9 q+ n: l! Z" F8 {
            cn (cdr (assoc 4 elist)) , f* j% C0 I% v0 z# h, k/ j
           enl (strlen en)
  q3 B0 t$ l$ L/ o1 s9 I+ z      ) " T8 _: F3 _* d) `. n
      (if (and 0 B) m& j3 I6 U9 v- B! {7 m
             (/= en nil)
7 ?/ A# [3 |, }' E6 B- t/ u             (= cn nil) % k: p4 \8 u+ [' o; g
             (= (findfile en) nil) 6 F# W, H$ m% Q; n# C0 c8 O. ^% A
             (= (strcase (substr en (- enl 2))) "SHX")
- \% S/ Z7 h+ i7 b  v4 p           )
( z% w+ p, c6 f5 g% Q         (command "_style" nm "romans.shx" "0.0" "0.8" "" "" "" "") //替换西文字体为romans字体,比例0.8( q9 `. s5 {- ^4 L
4 E6 S7 Y! J8 G$ A      (if (and ( p2 n6 N$ o- |* O
             (/= cn nil) 6 M' ^5 F) |5 L% Z2 I4 P$ i
, N, r+ P; O) _, O- X             (= (findfile cn) nil)
1 n+ b: e8 z. T) O# u           )   D2 b/ P) a& ~$ R' f
         (command "_style" nm "txt.shx,bigfont.shx" "0.0" "0.8" "" "" "" "") //替换中文字体为txt,bigfont,比例0.8' O' \; T) O, h* T( ]- L! A' j) W! f( K
, L( c% p2 v3 V9 N* B, r     (setq elist (tblnext "STYLE"))
0 J( f2 a* j8 S" S+ c# A' R   )
7 K7 p8 M; w" m7 q)
