发表于 2010-9-14 19:25:49
来自: 中国江苏无锡
% H, u B% S" _' P7 Y+ q: l2 ~$ P# Q& F( U
4# SunVei
# h( l8 \7 k. }& M# ~6 s: N: b' R6 f
: z8 H% y6 B+ O$ @1 l- (if (setq a (getpoint "点取斜线长度和方向 <回车确定>"))0 w f# F5 z6 a* A! D
- (while (= (car (setq gr (grread nil 5 0))) 5)
- ?/ M5 |4 ]& b* b- e* }% J, d - (redraw). U! `" k7 ] X1 ]
- (setq b (cadr gr))- b- s( L* X& _7 }& E, q
- (grdraw b a 1 1)
+ X; T7 X% G7 G; }9 {: T - (setq ax (car a) ay (cadr a))
( s3 {3 A/ k4 @) J& T0 _& I - (setq bx (car b) by (cadr b))+ @/ `" ~' ]4 v
- (setq pnx (- bx ax) pny (- by ay))
3 l; Q' z) C5 y, [ - ;;(if (< (abs pnx) 5) (setq pnx 25 pny 25))
6 L8 t9 M5 J- I - (posmove2 ss (/ pnx 3) (/ pny 3))( W; f* t1 o: ?1 z% \9 d( ~
- );;while* N7 e& f) d. B! }' o4 e
- );;if
复制代码 |
