发表于 2010-9-14 11:38:58
来自: 中国辽宁铁岭
- Dim E As AcadEntity, T As AcadText, S As String
3 `) |9 D+ T6 I G6 M+ {8 P7 ~ - S = "XXX"
6 R- D" I0 x0 R* D - For Each E In ThisDrawing.ModelSpace* |6 z4 l% ~; a7 O, R% Q8 l: b
- If E.ObjectName = "AcDbText" Then1 Z6 C8 A0 j$ c* o4 Y
- Set T = E
$ y8 u, M9 \: u( ^- m - If T.TextString = S Then
3 }8 N9 X7 w, n! e0 ]4 H! U+ Z3 f" c - MsgBox "单行文字" & S & "的位置:" & vbCrLf & _
. v2 B! F3 d3 H - "(" & T.InsertionPoint(0) & "," & T.InsertionPoint(1) & "," & _. ~, v) J0 F- m
- T.InsertionPoint(2) & ")" & vbCrLf & "字高:" & T.Height
`+ E3 F! n2 f - Exit For
" e6 H, Y( O* s5 A! o - End If
0 L5 X, f) k8 x, i- G - End If
9 k) m Z. Z: j( P" {+ O - Next
复制代码 |
