The hardware requirements for installing CimatronE are as follows:
& v& l3 e8 v+ f2 g) U( n! M• Processor:: G/ w3 Z! a1 V3 d# M5 W {( W$ n
• Minimum: Processor Pentium 4 or AMD64 (2.4 GHz or higher)./ r7 z: u' n: v/ N) ?5 }- }
• Recommended: Quad core processors (Intel core i7)
: g# _' o( y4 W2 f$ E- g8 A0 ^Note: Pentium III and old AMD computers are not supported. For these computers use a special version: CimatronE 9.0 OC (Old Computer). A message is displayed while installing a standard version on an old computer: "Your hardware (CPU) doesn’t support this installation set of CimatronE. Please use the OC installation set instead. If you do not have it, please contact your local Cimatron Provider."$ ^# c6 i" }$ ~6 M1 C$ }- k2 w! n
$ o3 j8 F4 V4 x. D7 [2 u$ q
• Memory (RAM):
7 Z( D; j6 E% i2 {) ]! B8 J• Minimum: 1 Gb8 I" P8 R4 h# y* v1 q. h m3 _
• Recommended: 4 Gb
" B9 |6 }, D o/ P4 B• Graphic card: must support OpenGL 3D:6 ~. k! Q# z: S6 \5 k% p
• Minimum: 64 Mb of memory! O+ K! X3 c q4 U8 C, j
• Recommended: 256 Mb of memory' z) @0 A1 A* O0 i
• Free Hard disk space: 2 Gb
9 k' ]$ ^: d; {( E2 i• 3 button mouse |
