查看: 3805|回复: 5
SolidCAM 2010 SP2.0 HF1 English for SolidWorks 2007-2011
发表于 2010-10-15 07:54:35 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
SolidCAM 2010 SP2.0 HF1 English for SolidWorks 2007-2011, B2 \0 g; O1 L4 n
3 x* X! ~% w. N, [; b, \: R4 o" y SolidCAM 2010.rar (12.2 KB, 下载次数: 243)
发表于 2010-10-15 08:41:54 | 显示全部楼层 来自: 中国江苏苏州
HF1? 请问这个是SolidCAM的什么文件?后处理?
发表于 2010-10-15 09:01:13 | 显示全部楼层 来自: 中国天津
看来还要继续等待简体中文版  谢谢楼主的分享
发表于 2010-10-16 00:16:55 | 显示全部楼层 来自: 中国北京
惊奇的发现居然还能支持SW2011。。。
( U, T9 c( F2 g$ P" N4 V感谢LZ分享
发表于 2010-11-5 23:02:54 | 显示全部楼层 来自: 中国四川成都
我下载了,但是64位的安装说明看不懂,请朋友翻译一下
7 h$ X5 j0 e9 ]! Y2 q4 @, B1. SolidCAM 2010 HF1 SP2 Setup9 }: l9 F) _4 z. A
4 S: m! J; M: ~4 V% Z: N  i1.1. To install SolidCAM 2010 HF1 SP2 run ..\Setup.exe& @& n3 @8 Z( ^* e$ ^
; ?: v% d  d8 ^( T2. USB-HASP-Emulator Setup
, k$ z3 Z8 x8 i! Q' W
* ], [8 c* H! s6 c9 a1 a2.1.  If you already have got installed and working previous versions of SolidCAM2009-2010 with USB-HASP-Emulator you need to install SolidCAM2010 HF1 SP2 only.
, J5 a& z  s: P6 g7 k" c* D7 ]- x; d0 j0 k) [$ J; S
2.2.  If you have no got SolidCAM2009-2010 installed and working but you've got USB-HASP-Emulator installed (USB-HASP-Emulator with service vusbbus.sys, mcamvusb.sys or any other service using for dumps Window Registry [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NewHasp\Services\Emulator\HASP\Dump\] ) you do not need to install Emulator. Just register the dump (run "solidcam2010.reg") and restart or reinstall your Emulator
$ F$ `- i# g2 X( w0 K; U. l5 O7 X) ]9 K* g6 @
2.3.  If you have no got USB-HASP-Emulator installed you need to install it
+ h* M0 w: q, w: p* a2 N$ z$ D" ~7 ]  E
ATTENTION!, r: [, z! Y: x7 a) m$ R" c4 @
To install emulator you need Administrator rights!3 D% l$ G" B) |0 }  z5 |" `* A
To install emulator for Win Vista or Win7 you need to boot computer in mofe F8 > Enable Enforcement Unsigned drivers!
/ U# ?* l& W+ ~( C9 o0 ~& ?Moreover you need to use boot mode F8 > Enable Enforcement Unsigned drivers at every reboot of computer!
# q/ b5 ~1 R7 s) v! E! ?8 i: i( m8 _# n' w4 D$ a4 M0 X/ ]
2.3.1. Copy folder USB-Emul_Win64 to C:
( R3 u: ~& Z' ~( M2 Z& i$ D0 b. B; P4 `. F- h6 C2 J
2.3.2. Register dump (run ..\USB-Emul_Win64\solidcam2010.reg" and confirm to add info in Windows Registry)! |4 ^- G2 u- |: C1 c  v
; b9 W: q+ E/ X: o5 u2.3.3. Run Start ->  Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..
0 ]$ H, d2 ~8 E, B0 [/ V        If setup is succesfull you have to see new devices:
6 R& o$ w* f3 [( _* u9 ADevice Manager -> System devices -> Virtual Usb Bus Enumerator/ o- M$ i' u. X  X3 `. T% x
Device Manager -> Universal Serial Bus controllers ->SafNet inc. HASP key
, U4 e! J! \5 Q1 x! C+ K* ^Device Manager -> Universal Serial Bus controllers ->SafNet inc. USB key* W2 `# c3 f9 [5 d
- |! P% H! p  ]) s: D6 u6 `$ P& h9 R" _
That is all6 q. p( f* w& s2 u
That's all
发表于 2010-11-9 20:38:24 | 显示全部楼层 来自: 中国四川成都
一直在找支持2010的,都没找到。
