发表于 2010-10-17 09:56:36
来自: 中国广东佛山
'funkce pro nastaveni parametru modelu, pouziva MAP.INI ulozeny i modelu
. F; p+ q. C3 E; t* w$ b& I2 iPublic Function SetModelParams(oDoc As ModelDoc2, sDataFile As String, sMapFile As String, sSection As String, sPostFix As String) As Boolean
) Q* [2 b+ v+ q* H' k& E8 H SetModelParams = False
& j& ^% t/ W+ x) p* J Dim sDimName(1000) As String 'pole stringu promennych a jejich hodnot z textoveho souboru. J; x/ W |7 p+ d
Dim dDimValue(1000) As Double
6 `$ @, s' u5 L# f: l7 H$ N- F/ z Dim i As Integer, j As Integer) G$ \2 @! I; w8 v8 G
O8 ^& n% Z, T$ b4 C/ E8 ~ Dim sVarName As String
: V* N- s; b0 p7 T# {, B# Q Dim dValue As Double3 d; H6 s/ k! k3 a) ]
Dim oDim As Dimension
# ^( q$ o" t) R$ K" S- h S Dim iRet As Integer
# G% J* c: _2 y Dim lRet As Long! @) G" w5 p) s6 j- ] e, c) s3 `
Dim bRet As Boolean
5 ]3 W: U4 B+ z {, n" V$ w% w9 f : @( b6 a% t0 z9 H: O
Dim sXBOMX As String
( S8 z+ o# s* b" i/ }
7 u/ f1 ~3 L" M. ^& L) y 'nacteni promennych (nazev a hodnota) do pole
}9 @9 y" I. B/ H9 V* K7 [0 g Dim iHandle As Integer
# B6 H4 n+ Y/ G9 w. H5 ] Dim sFileRow As String
: a' i& z2 t' I- u s% x: q : m* g) w0 a& {& [' a
On Error Resume Next
1 R7 f# {7 u( H9 f " u) e4 [! T& l6 L+ f( P1 o
iHandle = FreeFile()
( d( v0 p! c' D6 E% v/ ] Open sDataFile For Input As #iHandle
. f/ b( S. j; Q0 G% A. W( a i = 1& k& w& g2 k" \" `9 ]* d6 \3 c1 W0 j& h
Do While Not EOF(iHandle)
* w0 C' ^2 K8 d/ S8 Y" { Line Input #iHandle, sFileRow
$ q, q" U: s; Q: h: z4 u sDimName(i) = GetNStr(sFileRow, 1) '取第一个参数
* M% z) v- }0 B9 J) h8 M$ L) Y If sDimName(i) = "XBOMX" Then sXBOMX = Mid(sFileRow, 7)
& q/ l+ b( d1 ? dDimValue(i) = GetN(sFileRow, 2) '取第二个参数
4 _6 ]2 J; C5 S1 f2 l i = i + 1
9 {+ d3 y. N v Loop; a) N& `3 ~3 p$ I, G
Close (iHandle); D& N* p, p. [" p$ A: l |
'zjisteni, jestli se jedna o sestavu a naplneni lokalniho postfixu (pridat ke jmenu parametru/koty v modelu)2 z/ T5 d% F% g0 a& Y. Z0 \
Dim lDocType As Long, sLocalPostFix As String, sFullName As String
/ H; O7 A" M1 ]0 P Dim pos1 As Long, pos2 As Long: y9 M1 ]2 ~. q6 ~' o& \2 n
lDocType = oDoc.GetType()( V/ A9 R/ Y5 }# s0 Z/ F6 U
If lDocType = 2 Then
/ k9 X2 j3 T. B3 ^5 j ] If sPostFix = "XXX" Then
) a5 k8 v! g/ P a3 q5 L 'musim dohledat ze jmena assembly pri obcerstveni podsestavy
" x# M0 l% x5 z- R( \ sFullName = oDoc.GetPathName()
! D/ e6 b, P* o% f pos1 = InStrRev(sFullName, ".")# y T+ |. | \" x0 e: J3 j; d
pos2 = InStrRev(sFullName, "_")# {& F: m& a, c
If pos1 > 0 And pos2 > 0 Then
0 j- k: n$ q. ^* h" W4 n1 z% O9 x2 Q sLocalPostFix = Mid(sFullName, pos2 - 3, pos1 - pos2 + 3) & ".Part"
7 t: J* V& \* p+ v* C End If2 m7 ~. b# O& {; H1 _. R; O
Else
4 O X$ B9 q# q F sLocalPostFix = "_" & ModelUnits & sPostFix & ".Part"
9 b" X" H% J( t End If# E" X2 O% p$ U+ C
Else3 U5 e% A. R1 w* P! O
sLocalPostFix = ""
$ e9 X& r; s$ w d e End If
2 M( ?! @- t: H) R6 H& z" n
2 @7 ~3 F2 Z7 N% k/ x Dim Check As Boolean, V; W- C: v3 V1 [9 M0 O
Dim sDimString As String, sValNameFromXLS As String, sModelDimName As String- [& v& `$ R/ m6 v5 h! ~' e+ y. k
Dim dModelDimValue As Double
. k7 [8 K# V0 E6 Z; n! Y 'naplneni parametru v modelu& s( c6 {& C; {& ]' x
i = 1' Q( ]7 ?2 \; D" E4 ^
Check = True '检查
" F3 t0 U4 p8 x+ b" E# q { Do
" M. L! ?6 Z& j sDimString = SpacesSZ(128) '建缓存器* Z1 C" W' {( U, D
sVarName = Str(i)
- w, b% S% q6 d* I" C, Y) } iRet = GetPrivateProfileString(sSection, sVarName, "", sDimString, 127, sMapFile)( v7 w9 p4 u# o; u o( M4 B/ B
sDimString = Left(sDimString, iRet)5 v6 W3 {( X) g7 s7 G
If sDimString <> "" Then
# T. P! b) @3 M9 H 'test na to jestli je string, kterej nuti prebuildit model$ m6 _) C I3 e: [4 |
If UCase(sDimString) = "REBUILD" Then
5 u- `1 `0 Y3 _+ ?3 m bRet = oDoc.EditRebuild3(): W; ] D- y" [' ]
GoTo 999
5 c/ q! z: S3 f2 e End If
$ h; t1 Y# P( @( B6 A* _, q$ n8 S: l 'prazdna smycka
, S1 g r! N$ h/ E; q If UCase(sDimString) = "NOP" Then GoTo 999
" z0 Q3 V" o* q: b. Z
1 \6 _& w: X( M5 i, {" H% v 'existuje prirazeni, naplnim hodnotou kotu v modelu
6 z! K. F$ k! e+ O& q sValNameFromXLS = GetNStr(sDimString, 1) '分割第一
# D b, x7 o) C0 a* p" R sModelDimName = GetNStr(sDimString, 2) '分割第二
8 V1 P2 l4 V* Y$ l) d" {1 X$ N 9 Y- m) R, |, \5 C
'dohledam hodnotu z pole hodnot nactenych z textoveho souboru6 `+ A- b* z; `/ K- G* O f3 _: R8 N- u1 A
j = 15 ~+ G- Q: n& g3 f# k/ S* R
Do
4 j! B* U2 C. A If UCase(sDimName(j)) = UCase(sValNameFromXLS) Then 'txt比较ini查找
9 c: v* W9 ?7 \) R dModelDimValue = dDimValue(j) '值, Z! Y) m$ W, @4 R2 E3 b4 F3 q
Exit Do( S8 @6 L: R( _$ @
End If; b, r; y; \) j3 A& K
j = j + 1
) y6 Q8 Z9 A3 x# r) C, ^; w% ? Loop Until j >= 1000
- n9 z4 L# F& N 'zjistim, jestli ji nemusim opravit
2 T( |0 R' c" `0 B5 Y: }) i sDimString = SpacesSZ(128)
- G+ k( Y0 @8 u5 @- p iRet = GetPrivateProfileString(sSection, sValNameFromXLS, "", sDimString, 127, sMapFile)3 U+ ?! |2 L! n% _6 q
sDimString = Left(sDimString, iRet)8 F" Z) V! e, R; E5 w" u
$ N# ]4 x$ h2 y. s; N' v" t 'nasel jsem a musim opravit hodnotu
# l. G$ T( s Y. N6 b3 F1 O If dModelDimValue = GetN(sDimString, 1) Then dModelDimValue = GetN(sDimString, 2)+ \# L' p- Q9 R6 \+ M( ]% }
If dModelDimValue = GetN(sDimString, 3) Then dModelDimValue = GetN(sDimString, 4)
& `: N x! h" l& C; w" c2 J If dModelDimValue = GetN(sDimString, 5) Then dModelDimValue = GetN(sDimString, 6)
( w E# w1 M/ G7 c* r- a0 z% Z( }; G End If) {! Z) H" z, `6 ~
sModelDimName = sModelDimName & sLocalPostFix5 c$ p1 A' n, H: v% [3 o9 B$ t
'zmena parametru v modelu" U. d$ t3 F3 U
Set oDim = oDoc.IParameter(sModelDimName)
: \, R* k6 I6 p+ R$ G If oDim <> vbEmpty Then 'vbEmpty 未初始化(默认)
/ q, x* W G. r2 {7 s6 D4 g- C lRet = oDim.SetValue2(dModelDimValue, 0) '在指定的配置中设定大小的数值。swSetValue_UseCurrentSetting=0
2 u- T3 w8 n- S, J+ }& f# i. e End If
- B9 M( f1 U$ T" o8 a9 w) l Else
* O H! k( T* K2 v+ R+ Z. O" V+ h- p0 { 'neexistuje jiz zadny parametr pro zmenu
! K' f1 `3 ` z* f/ Z Check = False
0 Y6 s- u4 h$ @7 Z$ m End If1 w/ D+ m9 p1 H1 S$ D6 R5 N
999:
- {: w: A. `0 @: ^ h i = i + 17 u8 I' g7 E0 X0 }) ^% W% x) n& T
Loop Until Check = False
% o4 o7 ~7 V! q9 L! B 'Call oDoc.Rebuild(&H1) 'swRebuildAll = &H00000001 F& |" z& j3 _! \
- Z/ P: O$ C; \! G1 D4 t* E
'nastaveni BOM info% K6 c8 [* U* e
If oDoc.GetType() = 1 Then
; h0 }$ J6 Z; Q3 _' N) o 'jedna se o part, muzu nastavit primo BOM atributy
& {# f. J4 I4 }% g- ~# g# }7 ^$ R bRet = FillBOM(oDoc, sXBOMX)! p$ |$ `# h! k. j# ?
Else- l/ p- q( A& Z' l3 a! S% ]: Q( C
'zkontroluji, jestli se jedna o sestavu (pro jistotu): [2 S0 q$ j' N* Y& o1 V
If oDoc.GetType() = 2 Then
# U y2 ~/ f+ ^ 'je to sestava, musim kazdej part zvlast
+ D9 |8 ^2 m# C2 F5 [" ], _6 y4 ] Dim oPartDoc As PartDoc- K1 n/ {+ H7 o: k- G
Dim oAsmDoc As AssemblyDoc
/ j! N+ z5 R5 M5 z% l+ k; V% y2 z Dim oSelMgr As SelectionMgr% ~" r0 i# n1 q n- W
Dim lCount As Long) b3 U9 e# T: `2 ?4 E- X- p
Set oAsmDoc = oDoc3 z5 L/ b7 g4 V+ ^8 W- B/ i
Dim oRootComp As Component2
& w. @7 W# d& [; P Dim oCfg As configuration
c$ d: N9 a/ ?$ U Set oCfg = oAsmDoc.GetActiveConfiguration()7 t' b8 f; j7 I' h
Set oRootComp = oCfg.GetRootComponent()
1 |' D( H6 Z% V! F" H+ h5 a& ]5 `# @& o5 p6 K L0 v6 h
Dim oChildren As Variant/ m4 N: [1 x* \6 D c/ x# q
oChildren = oRootComp.GetChildren()% D9 P9 T! R, d$ D
lCount = UBound(oChildren)
4 Z- ~& G' y% {. E: _5 I' n, `2 N& ^- q5 F; t$ g
Dim oCompx As Component20 S- k9 d+ Q2 L9 D U
Dim oCompDocx As ModelDoc2
: L v4 h4 f" f1 J. }
5 y1 d. o' X( `) q6 Y- k& N" e% ~5 G; N 'kopie jednotlivych souboru
1 C# I0 x! m, ` For i = 0 To lCount6 X/ w5 S% D9 e; N' e; h" J7 H
Set oCompx = oChildren(i)6 [" [* v" m1 r7 b) k
Set oCompDocx = oCompx.GetModelDoc()
0 Q9 V2 w* s1 V8 o 'vyplneni jednotlivych BOM atributu' z4 r M8 F2 Z2 ^+ Q
bRet = FillBOM(oCompDocx, sXBOMX)
; b3 t9 G+ C/ o8 n7 } Next i
2 O. D9 J0 m F0 w" n# x* O End If
' q% w B/ z; W End If' q% N9 ~4 q! {+ |& I
) |, s, }9 N* e6 r. L bRet = oDoc.EditRebuild3() '重建2 o0 \$ n u" b# {8 ]* D9 O% K
SetModelParams = True
' ~- n$ N: z$ i& K" d+ w. Q5 u" Q. YEnd Function |
