查看: 1987|回复: 0
[讨论] Family PPAP
发表于 2010-10-21 09:38:39 | 显示全部楼层 |阅读模式 来自: LAN
在我们公司提到有一种Family PPAP的概念,好象是说如果同类零件,在同一家供应商开发,生产流程相同,关键控制点相同,只是尺寸不同,可以采用此类PPAP。请看以下例子。7 [3 h; i9 R5 Y# N- z0 _
各位大侠有谁了解Family PPAP? 这个概念在PPAP标准中有没有?在哪位能提供相应参考资料,非常感谢!- R& _- R, m+ A0 E
如果这种概念可行,具体操作中需要注意什么?
! o6 @4 G" T) X6 [0 ]; A- j( d- r, {5 w" z0 k6 c( t1 _- F; m
Example 1. Tube Family
2 d) R5 q. {+ X* x+ y
( g7 ~& ?' l$ I" Y, }  q* Z/ a! i% p& a9 A6 Z, M% e: h7 W
4 process streams at supplier with several hundred PNs each. It makes 4 Family PPAPs.
3 m; W' n6 Q& M- D' W5 \' f- \9 D5 {1 m& _1 g; `; e, f4 M
2xCF (cold-formed both ends)
9 _% ~2 p- n8 V3 I" h/ x! a/ k' L
8 p3 Q# j8 c3 b+ I; i% _CB&W (complex brazed & welded)
1 v' `: g% j$ b& w) L* `( i8 h/ g4 l3 |' V5 l
RTB (round table brazed)
. m- ~7 X, n/ h/ B) n. o* \+ o( H
( u9 a1 D8 i% X- K% u
2 t# X# K; ]' ]! QEC (extra complex)
- d+ J% ^& N$ l% c; F6 o$ ]2 p
$ m; i& G  M& N! XGood family PPAP Parameters:
" }- H% E% X9 L0 W- R4 t0 {
2 X* l* Q1 ~' I5 ]Same processes (by VSM)
# u; G+ {" k1 h# c' M0 u. H
. Z/ Y. f9 N3 _% G* C
Same materials
8 s, h& A1 a+ X3 q
5 ]( C5 V# o' V. h% [+ w! |Same plating / painting
( T/ Q" R/ z6 x- D) _  c( x
. Q  h* Q; ]! V" kSame controls
7 l! E! n' K$ g/ A# H+ f  @4 ?
5 m$ z% T+ f- d, V
FMEAs done by process
7 q8 F6 e: a- _, X5 I2 U
+ D" R  i! ^' Q* WFamily PPAP simplification and benefits:
) ^! g, h) u* ^4 o, `$ e0 ]2 o
' L5 G& [$ C1 ?: {! ZAll processes common except specifics on tube sizes, tube bending and fittings
* C* p6 d1 W4 f9 H9 M7 I. K7 m1 n1 N4 I+ Q4 Y: g
Level 4 submissions on child with reporting for:
4 [" F( V- x: y/ B. t' Z7 C
6 g& v2 }% F+ a- S3 |) e. I# Q(2.2.9)5 j, \/ P  ~  E( i2 G) R2 v. y
Dimensional Results
' l. V& L3 M* o; M6 |
. U2 b6 X2 _8 t- F* x' n$ f% @Tube bend geometry
& A# G' ^0 `" M8 c  P" M
/ n3 @  Y8 K. E7 J2 w7 }& O
Fitting confirmation
. P3 v+ a6 c; p* i3 s5 e+ R
Tube size and wall confirmation- l7 y( ]! {3 G7 M5 T4 S
4 C: M" C. k7 z  k
0 @+ Y$ L' s3 d$ I
Standard Work for Family PPAPs.zip
21.33 KB, 下载次数: 5
