发表于 2010-10-23 12:42:47
来自: 中国浙江温州
转破解方法原文 :
5 D, F, [" w" ] D4 _- pop-up window "Thank you for using SolidSQUAD's SolidWorks 2011 release!" at every SW2011 start is deleted1 R& C+ y5 L3 L. f! J/ D- B ?
9 g' d: g! D" Z% M/ u4 V- fixed problem with crack applying on some Win64 computers with warning
! \6 X( Y* f8 }9 y- N+ ]2 z8 T* z " Error: Can not initialize library (%d, %d, %d)") N2 @) B0 ?2 x/ b4 a: ]* Y7 y
or
7 t+ j/ o4 f& t " Error: Can not open handle (%d, %d, %d)"
8 A& y' T9 e5 \; e" _1 k1 @( N+ O9 f2 ?
* T E) Z2 F5 Q- K
Using: P8 c* i, @1 G3 F) Y
1) Install SW2011 using any of serials
6 K6 y8 a( J- h8 m2 X( B2 k; e# p 0001 0001 0736 0361 JK3Q HDJ3
' k- F8 D# I+ h4 N! ~: ^ 0101 0000 1289 1488 R4H5 Q533
5 o/ J' ]% O& ?- a- k: ]7 h. y& a 0000 0000 0000 3486 Q5HF FG98
, i5 O9 p Y' ]& F 0001 1234 5678 8012 5559 Q7KJ3 A2 z7 N. e. K" E. v7 X
you can use any other valid LOCAL (not NETWORK) SW Serial too!" R0 n, q, o& \6 P* v5 t* J% c
+ r) H: |. i: D4 @" QAt SW2011 SP0.0 Setup DO NOT INPUT serials for SW Motion, SW Simulation or SW Flow Simulation!
2 D9 |6 |. o, j2 N; v* F; s
* _ \8 b4 U m9 \2) Copy folder "setup" from crack to <SW2010 progdir> and overwrite original one! _! {* s$ W( N" j, ~. n) V
% Q' M" C T2 c8 v
3) Run <SW2010 progdir>\setup\i386\swlmwiz.exe+ o( \' Z" {, V6 y
4 u2 t) R# p, }' Q# P
you have to wait for free SSQ's windows and click OK in every window% d m" s: v, U
' x ]( o/ U0 X. Q+ O0 `( \6 {first window "Thank you for using SolidSQUAD's SolidWorks 2011 release!" > OK# z- }- o: _$ k: m" O2 _. B2 k
second window "Trial Reset Successfuly! Perfoming activation.." > OK. A8 I8 P2 [$ {" q
fird window "All done! Enjoy!" > OK6 g/ d( y1 _: G) y
0 Y% B) Q6 [4 }+ X1 f9 q4) If you've got a problem with crack on 64bit computer (after first SSQ's window you get a message " Error:
3 }$ V a) G9 I5 l+ {3 P. P1 C Can not initialize library (%d, %d, %d)" or " Error: Can not open handle (%d, %d, %d)")- z0 G: p% [( F4 j& e( n5 }7 D8 I
you need to run <<SW2010 progdir>\setup\i386\x64_fix\ServiceInst.exe and repeat steps described in 3)' { S0 O1 O7 E2 T& t
$ x; F: }' T) G; zThat's all
, F$ t v: w5 B+ x! { H/ F% k* X; J) o( L% ^; _
Team-SolidSQUAD |
