查看: 5770|回复: 8
3Dvia Composer 2010 V6R2010x HF4 v6.5.4.1471
发表于 2010-11-2 20:10:03 | 显示全部楼层 |阅读模式 来自: 中国台湾
http://pixhost.info/avaxhome/77/f7/0017f777_medium.jpeg 8 H9 Q# n/ q7 M
3Dvia Composer 2010 V6R2010x HF4 v6.5.4.1471 for Windows 32/64 bit | 920 Mb
4 h2 x6 V3 }0 I: F0 r  s: J9 X5 x; P, v  a" {% R, ?0 u0 W0 `) O
3Dvia Composer - a convenient and functional system for the development of multimedia content, automating the process of creating instructions for assembly / disassembly, technical illustrations, interactive 3D animations, marketing materials, product catalogs, training materials, web-pages and much more.( u4 v9 I1 J9 f# E
Facilities: Easy, simple and intuitive user interface, and an open XML-architecture solutions 3DVia Composer enable a wide range of users without special skills in the development of technical documents, create associative 2D and 3D materials based on design CAD-models designed products.0 @. C" G9 f3 ~2 i: @3 l3 h
. _  w9 W; B* l. w
Advantages:" f$ Z& g) }$ R* {7 I
3DVia Composer can be used successfully in sales, marketing, maintenance and repair (MRO), training, engineering and production departments, as well as for monitoring and managing complex projects management company.* B2 I- S" s" W, J4 j; E4 @& V
9 i1 i' t# [" j& a
Effective use of information about the product:* e% a# ^% g2 K) H; Z. Q
3DVia Composer provides the creation of technical illustrations, video and interactive 3D material, which not only improve the perception of information through greater visibility, but also significantly increase the quality of the generated documentation. Using the interactive graphic elements can significantly reduce the amount of text items, which reduces time and cost to translate text documents in issuing it in several languages.( U! ^# E1 ]5 B( S
0 k8 M- D4 w' \$ v( v8 J! c% n
Application:! l/ Y5 ^- k) a4 m7 I* ^  A
Application 3DVia Composer allows you to reduce the time spent on rework and update the documentation when you make changes in product design. Updates are automatically downloaded through the associative connection with the design CAD-model. Cost and timeline of the documentation is also declining due to more effective use of the designed product. Development of documentation 3DVia Composer can begin at early stages of design when the design model are not fully developed, and at later stages, upon completion of the design process, you can easily update the graphics and multimedia content in a prepared template document.
* N( [2 O8 G6 ~: I3 w7 W* Q! n" r/ w1 `
Documents:0 c$ X" x+ `& q* b/ r9 d* C
Interactive documents created in 3DVia Composer, may be protected from unauthorized dissemination and use by assigning access rights to the functions of viewing, copying and printing, as well as full / partial display / hide individual items or operated by understating the quality / accuracy of the displayed 3D models, when the geometric parameters of the product is intellectual property.
" N' Z* x% J0 S6 {$ k! E: P0 [1 R6 H; o% U0 P% o
Composition of solutions 3DVia Composer:
+ B% f- u+ Y! }( ]$ B. C3DVia Composer - basic module, which provides an interactive development of technical documentation on the basis of engineering CAD-models of products. 3DVia Composer is designed specifically for developers of technical documentation and does not require special skills and knowledge in the field of CAD / CAM / CAE-systems. A graphic and intuitive user interface provides the convenience and high performance in graphics and text objects, their properties and performance. All these parameters can be stored in a library of styles for reuse in new projects. Interactive animation (to assemble / disassemble, MRO, a demonstration model of a product from various angles, annotations and explanatory graphics), high-quality vector images (SVG, CGM), and technical illustrations (callout types, specifications) can be created extremely quickly and easily.
 楼主| 发表于 2010-11-2 20:10:55 | 显示全部楼层 来自: 中国台湾
本帖最后由 chicago999 于 2010-11-2 20:14 编辑 ' u7 p7 Y  O3 n! X
% b+ F- h1 ^  N
Download Web site :
% \0 b# w5 l) \5 Y: B
( r0 L$ }- T; r. P8 d, x英语、简体中文…多国语言版!!
! \' L* n/ S; y0 n% S' w) f2 J
  e9 K& W- T$ t' T7 W. `- f! QFilserve.com Win 32 Bit; D" P- Y5 f6 ]5 O# Q2 J* o6 Q
http://www.fileserve.com/file/f4sUTdP/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471-Lz0.part1.rar6 A7 t( s, z. `* h$ ]5 n- I8 V# s0 k: D
http://www.fileserve.com/file/TcN9EBX/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471-Lz0.part2.rar
8 l; [0 B7 ^- F" X4 ~% Ghttp://www.fileserve.com/file/H7gnPBq/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471-Lz0.part3.rar) {9 B9 D- r! P# k
http://www.fileserve.com/file/9shKzDX/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471-Lz0.part4.rar
; ^; ]" h- c& e3 m) h# C5 ihttp://www.fileserve.com/file/DCnQ7jf/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471-Lz0.part5.rar
1 A, b9 Z7 x4 Q. g" E8 \) A/ lFilserve.com Win 64 Bit
* b. B2 x4 G3 ohttp://www.fileserve.com/file/pXKCyPk/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471.X64-Lz0.part1.rar
0 p7 g' x" P0 A$ k4 L. Khttp://www.fileserve.com/file/4Rx4DSz/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471.X64-Lz0.part2.rar
7 T1 N$ V! F2 n7 s! Ehttp://www.fileserve.com/file/knFVUKB/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471.X64-Lz0.part3.rar
( _& j' Z2 U$ J: c% U) ]) |http://www.fileserve.com/file/7JUJK9R/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471.X64-Lz0.part4.rar. o) x0 r7 d7 u, n  x' }/ V7 b6 F; K
http://www.fileserve.com/file/R5Z2SBr/Dassault.Systemes.3DVIA.Composer.V6R2010x.HF4.v6.5.4.1471.X64-Lz0.part5.rar
 楼主| 发表于 2010-11-2 20:15:28 | 显示全部楼层 来自: 中国台湾
 楼主| 发表于 2010-11-2 20:23:11 | 显示全部楼层 来自: 中国台湾
  a7 F* Z" X' Y0 C/ D; V- x  U: C( ~4 h7 h$ h# H
http://img251.imageshack.us/img251/7949/3dviab.png
发表于 2010-11-2 20:35:54 | 显示全部楼层 来自: 中国北京
图片挂啦& ~% d: j* f, ]. k; o4 g) w! r) d
好像2011都出了吧
发表于 2010-11-3 18:19:52 | 显示全部楼层 来自: 中国北京
我现在用的是3dvia2011,楼主怎么还发2010的呢
发表于 2010-11-3 18:43:49 | 显示全部楼层 来自: 中国浙江金华
楼主可以和大家分享就是好的,不管是什么版本,6楼的把2011分享一下也可以啊。
发表于 2010-11-3 22:59:55 | 显示全部楼层 来自: 中国湖北武汉
1 R2 p6 M8 L; m4 F; d. Dswsxz 发表于 2010-11-3 18:43 http://www.3dportal.cn/discuz/images/common/back.gif
- \7 P2 P' E, R! l# w# F( n
强烈支持楼上的朋友.................
发表于 2010-11-4 08:09:03 | 显示全部楼层 来自: 中国江苏扬州
《产品文档制作软件》(Dassault Systemes 3DVIA Composer)V6R2011 v6.6.0.1466 Win32/64 含中文[光盘镜像]8 B& b9 e) g$ x6 @' N. E
http://www.verycd.com/topics/2838495/; M  q, I( S. L
1 w5 z$ D5 ~7 G: }8 w( W
这个很早就出,我已经下载完成,现使用中,. ^( w3 x6 c5 t4 \" J4 a( t+ z
# A5 k" k5 R3 g8 N5 w$ r
下载速度可能不太快,但能下载完成
