下面是录制样条曲线(三个点)的圆周阵列,不能运行
/ h" Q, v. V8 \, L7 C. RDim swApp As Object+ q! }( U* j% Q7 G0 F" k
( T; U2 g) e0 H
Dim Part As Object
: e @) g" N. ~Dim boolstatus As Boolean
! H9 h; H/ `& X! }( s O9 R" fDim longstatus As Long, longwarnings As Long
' d0 C' s: }* R. Z2 B4 {0 S# q% \3 f% q: o. m; T# M& A
Sub main()
0 f0 H y' _8 X2 {
) ]% j2 S5 d, O$ \: R+ J+ H3 ?3 ZSet swApp = Application.SldWorks
8 T, q5 n( Z' [$ Q- V6 g; ]& I
2 ?$ \. |9 ]. wSet Part = swApp.ActiveDoc0 ~" [, a$ J0 V4 i
boolstatus = Part.Extension.SelectByID2("前视基准面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
0 }* U3 k. Y5 r7 UPart.ClearSelection2 True
8 F/ A" a& C6 t" [* R6 oPart.SetPickMode
2 q' M+ x- U) s) ?% |% J! z6 I
, x9 h$ u% V: u" p5 X) r' Q& I! ^Dim pointArray As Variant
, |+ {+ \! b, U9 o$ p) b* nDim points() As Double' `# Z' k# ]0 D, Q$ `7 a+ M
ReDim points(0 To 8) As Double
5 _% u- y+ T0 p# k' m+ C( [1 v$ L9 mpoints(0) = 0.08526901595745% E9 ?9 | W% v
points(1) = 0.039581666666674 u- y. w1 B2 i) O* Z& Z
points(2) = 0
( m( l: i6 Y5 Q; b/ m5 ]- Ppoints(3) = 0.07726846631206& W0 ]; y! f' j- e2 c
points(4) = 0.02568597517739 n! M/ H# I/ e( \! Q/ C# B. N
points(5) = 0) M# ^6 b& a; j& F% R. S( N6 s
points(6) = 0.07011007978723
. F) ]0 x! z9 ~% rpoints(7) = 0.01979083333333
9 G' |' ]- s& qpoints(8) = 0
6 G8 D+ v( c0 K! I( zpointArray = points
; N6 T$ Y: P! s) U9 [Dim skSegment As Object
- {5 x6 y/ e( H1 b0 I1 n3 ZSet skSegment = Part.SketchManager.CreateSpline((pointArray))
: h7 |! j: A ]$ @4 V: b, `$ X0 nboolstatus = Part.SketchManager.CreateCircularSketchStepAndRepeat(0.08316813865701, 3.506585465785, 9, 0.6981317007977, True, "", False, False, False)
Q, o0 l% }* o& j; T- i0 F& EPart.ClearSelection2 True7 I- w, ? }4 K0 s: H. L
Part.SketchManager.InsertSketch True
9 h- W& g* l. n0 u2 H2 d. J# BEnd Sub* m+ _+ z1 ]$ b
下面是录制直线的圆周阵列,可以运行7 ~6 V( _- b2 |
Dim swApp As Object1 {' ?* g0 p& p( x( L2 ^
2 q' u) l& v) b
Dim Part As Object u* y8 \, J8 L0 g" F Z( b# V2 w
Dim boolstatus As Boolean6 i8 B* B: {# X, |
Dim longstatus As Long, longwarnings As Long5 U& }$ `' z( {) B
- `5 C/ B2 K5 P3 B. f$ sSub main()
- g& j$ v* i! ]* A: O: ~
3 y' n1 w5 A0 l1 [% q. xSet swApp = Application.SldWorks
9 m; S; k: Y/ P6 r- d" s, U
. \! T* \3 P |" z9 ~# }Set Part = swApp.ActiveDoc
1 n, N4 o& _* x/ j! k; _2 M! z- s- D N% Z9 W' Q9 O$ N$ J) W
) N2 o' U8 r) A8 L K, ]* m$ f& P, s' b* EPart.ClearSelection2 True- G i' e+ d+ q0 q& |( U1 K( D
' p% i) u" F# E5 S& G* a ~5 U, ^Set skSegment = Part.SketchManager.CreateLine(0.062531, 0.01, 0#, 0.062531, -0.01, 0#)/ p! y+ H& B% c( h" F& y
'Part.SetPickMode, C3 T6 b$ B+ x
: f& q) b) H$ S/ ]! ^( l$ v2 k6 x
boolstatus = Part.SketchManager.CreateCircularSketchStepAndRepeat(0.062531, 3.14159265359, 8,0.78539816340 , True, "", False, False, False)& P( U: g& `1 w! d2 C
8 f1 d" U( w0 L& M5 RPart.SketchManager.InsertSketch True
# k( @5 f% J2 q% {7 MEnd Sub
* W# x( v1 c- I* \4 G- L2 z* }
: i: h4 _# p' U$ f ^+ h
3 l4 ^& i: D5 ^! ^; A我想知道为什么样条曲线的那个不能运行,怎样修改,我明白圆周阵列中个参数的意思,我想知道的是应用圆周阵列函数时应该注意什么 |
