表面处理、热处理类英语
4 C9 f \0 G$ ^1 Y8 @5 a5 t8 @) F% P& `oil quenching 油淬化
' C0 X7 d- y W) V; E" T+ p( c8 toverageing 过老化3 l% o/ @) ~, a- e+ `
overheating 过热! `% D6 G4 W" Q1 p
pearlite 针尖组织; y7 e! \7 B; F' U1 X" M9 s
phosphating 磷酸盐皮膜处理; u* P: d V+ k5 G* I, g
physical vapor deposition 物理蒸镀
' B4 c- `7 X$ l' Dplasma nitriding 离子氮化
2 N4 ^4 }& k2 P' m' [! T8 wpre-annealing 预备退火
# A- [2 j8 z1 R* P1 z9 S2 Uprecipitation 析出( X3 k( B+ Z# |' L. N) m- L
precipitation hardening 析出硬化' c- X$ `! d0 L. g2 ]
press quenching 加压硬化
* B$ m3 P' ^, [$ a! B0 n' Wprocess annealing 制程退火
1 M/ L* p. Q5 ] `+ a3 K/ s6 uquench ageing 淬火老化5 {: W" z: M* G4 r0 P
quench hardening 淬火
, e6 y# z) Q% _7 i4 } E* wquenching crack 淬火裂痕
' ^4 e5 o7 N" N* h% Y9 |quenching distortion 淬火变形6 Z4 X- x$ d. \' @' Y' |
quenching stress 淬火应力
% r3 j+ f8 s+ |! Xreconditioning 再调质: _" X8 P+ k1 l
recrystallization 再结晶" c7 ]% D3 s3 O3 G$ u
red shortness 红热脆性
$ s7 ~6 q: ^1 C% Yresidual stress 残留应力4 n$ m7 S5 U* m" I0 N2 D2 g" i
retained austenite 残留奥1 d) ]' c) T" n
rust prevention 防蚀& i: R: u! L$ D/ {9 ~4 c9 h
salt bath quenching 盐浴淬火
0 B: C$ _/ ^) m5 n1 |sand blast 喷砂处理
- Q+ k V6 r5 M* v7 w% Tseasoning 时效处理
3 Q' X# ^, s' ~) d4 I8 e4 ^second stage annealing 第二段退火
+ @% M) \# {& `$ s5 j! Ysecular distortion 经年变形
8 M' Z9 S) a" [* D6 a E0 _segregation 偏析0 a' Y. ~& y7 \+ ^$ m
selective hardening 部分淬火8 o7 b8 W+ p$ b& J6 f$ f h$ S1 @
shot blast 喷丸处理7 K. H' Q9 a1 t6 v! [2 g
shot peening 珠击法3 F" n: |) e1 I# X" V1 [
single stage nitriding 等温渗氮; Q% K2 O# D: z, T z3 x
sintering 烧结处理
$ u% E, ^/ M7 _; M ]soaking 均热处理9 a x) }3 H; m" Q8 G
softening 软化退火
" S; r5 s f( `) w3 W0 `: n Z$ Bsolution treatment 固溶化热处理( R0 E# L' K9 E% ^2 C8 m F2 p# i
spheroidizing 球状化退火5 @0 }& m, Q6 A4 m0 o) ~5 v
stabilizing treatment 安定化处理
' P# `1 D5 g& {/ y/ v! R! C! ystraightening annealing 矫直退火
5 {+ w" O; W! P, @$ estrain ageing 应变老化# j* x9 ~( `: k% ?' ^- a
stress relieving annealing 应力消除退火
' V2 n( y. ^4 M: h1 Hsubzero treatment 生冷处理
O, G9 p9 _( v3 }7 lsupercooling 过冷$ n# Y; u6 u- `; E6 n9 N& G% j& n* A* O
surface hardening 表面硬化处理% x3 A$ _, L) o# l$ }/ M. q
temper brittleness 回火脆性9 x& q# |4 M3 b1 ^% P) Q. {
temper colour 回火颜色
3 W$ \( c( q# R2 atempering 回火, L8 }7 N$ [5 y4 M; ~
tempering crack 回火裂痕3 K2 W9 ?& q9 P5 V Z; m: i
texture 咬花% T7 r. n& Q3 I- n* _' X+ S9 n0 C
thermal refining 调质处理0 j" n3 u6 H4 }
thermoechanical treatment 加工热处理- l1 _ b8 k8 N1 v, w+ S/ Y# y
time quenching 时间淬火7 K+ C$ f8 W( M) t6 q3 |+ p
transformation 变态" |8 F6 \* t/ o4 H u: C0 w
tufftride process 软氮化处理9 n. U8 ^# P% Y8 G8 g+ C3 H1 E3 Z. D7 c
under annealing 不完全退火
- b# e, ] @+ v0 G3 dvacuum carbonitriding 真空渗碳氮化$ H$ j& s7 v) m( ^2 l! [5 w
vacuum carburizing 真空渗碳处理9 z' U. z0 T, Z% P* S
vacuum hardening 真空淬火; q" ?& \! v k4 i1 g& J# R' z
vacuum heat treatment 真空热处理& v' ], g" d" [; C4 A& f
vacuum nitriding 真空氮化- W& l N7 E+ ?3 f" l) z: c
water quenching 水淬火: }% g; j9 A9 \( t+ D! J- w
wetout 浸润处理 |
