下载了本论坛的软件 , v' Y) l( R [1 g8 X* q* X
) E, F8 Y7 \# s) ?
但是安装说明为英文,本人实在无法看懂,请已经安装或者能看懂的的朋友指导。
# A; [5 S W* S" m* {6 A7 x% _
1. SolidCAM 2010 HF1 SP2 Setup: _8 \0 l' Q0 [4 P2 @6 I* M; c8 n k
1.1. To install SolidCAM 2010 HF1 SP2 run ..\Setup.exe: i* _' ]6 t3 u9 Z( \/ A! O$ c
2. USB-HASP-Emulator Setup
- a( z* F0 g* g$ W5 t2.1. If you already have got installed and working previous versions of SolidCAM2009-2010 with USB-HASP-Emulator you need to install SolidCAM2010 HF1 SP2 only.
4 E8 q6 M) U7 v1 S* B. D5 s2.2. If you have no got SolidCAM2009-2010 installed and working but you've got USB-HASP-Emulator installed (USB-HASP-Emulator with service vusbbus.sys, mcamvusb.sys or any other service using for dumps Window Registry [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NewHasp\Services\Emulator\HASP\Dump\] ) you do not need to install Emulator. Just register the dump (run "solidcam2010.reg") and restart or reinstall your Emulator
3 _! d8 B1 _- g: v: a' v8 W7 L% O9 D9 m2.3. If you have no got USB-HASP-Emulator installed you need to install it
+ S1 l& ?1 C; F8 F' u5 I* YATTENTION!! L3 G! s* K7 |1 S
To install emulator you need Administrator rights!( k" D, {1 K! g* R Q! Z8 {
To install emulator for Win Vista or Win7 you need to boot computer in mofe F8 > Enable Enforcement Unsigned drivers!
9 R, e7 B( o- U8 T* Y3 c3 DMoreover you need to use boot mode F8 > Enable Enforcement Unsigned drivers at every reboot of computer!
8 }) Z S) {2 O8 E( I: J2.3.1. Copy folder USB-Emul_Win64 to C:1 W( M- z. {7 z5 K
2.3.2. Register dump (run ..\USB-Emul_Win64\solidcam2010.reg" and confirm to add info in Windows Registry)) Y+ U) ]# S' n# _$ F( a# C
2.3.3. Run Start -> Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..9 l2 r, u, [6 I# H4 g; B+ |
If setup is succesfull you have to see new devices:
3 J8 w+ d+ }) {& Y# J" ~8 L) \Device Manager -> System devices -> Virtual Usb Bus Enumerator
, M) V8 ]/ t B7 j# ADevice Manager -> Universal Serial Bus controllers ->SafNet inc. HASP key! F0 D8 a, x: t2 M7 A# d' O b
Device Manager -> Universal Serial Bus controllers ->SafNet inc. USB key
, f) p1 `8 e3 D/ s* ]& G+ d; lThat is all$ B" ]7 b1 P9 L T. R, n4 U( |
That's all |
