查看: 1976|回复: 1
[已答复] ST3 pathfinder to display problem
发表于 2010-11-9 01:58:40 | 显示全部楼层 |阅读模式 来自: 匈牙利
hello!
& G7 ?# e* n6 e' Lwhy do not active this setting?
4 r9 e% A0 a/ f# B9 ?Windows XP SP3 is ST3 version! $ r; \! p$ C; ~. E4 @
..............................................................+ T5 V) W3 [  q8 e( H% Y- O1 ?) S2 o
為什麼不積極此設置?
- ?% Y0 T* n: n9 X: nWindows XP的SP3是St3級版本!
 楼主| 发表于 2010-11-10 06:57:16 | 显示全部楼层 来自: 匈牙利
who do not sign up using ST3 is the problem?
