查看: 3769|回复: 8
[已解决] GG-15HC Cu Cr 是什么意思?
发表于 2010-11-9 12:27:09 | 显示全部楼层 |阅读模式 来自: 中国辽宁大连
大家帮助我看看,一款产品,是做汽车排气管子的,材质一栏里面有这么个东东,GG-15HC Cu Cr 大家帮我看看是什么意思!!!
发表于 2010-11-9 13:27:05 | 显示全部楼层 来自: 中国湖南株洲
GG-15HC  不明白 是什么东东 是国内的么?
 楼主| 发表于 2010-11-9 13:34:26 | 显示全部楼层 来自: 中国辽宁大连
好像是德国的东东
 楼主| 发表于 2010-11-9 13:55:08 | 显示全部楼层 来自: 中国辽宁大连
GG15HC
$ `! _1 L+ L! R汽车制动盘,材料到底是什么东东
发表于 2010-11-9 14:49:33 | 显示全部楼层 来自: 中国上海
按德国牌号标准,GG-15是灰铸铁,15表示抗拉强度150MPa。另外的符号啥意思不知。
发表于 2010-11-10 10:59:50 | 显示全部楼层 来自: 中国江苏南京
德国的合金灰铸铁,后面为合金元素
发表于 2010-11-10 14:56:48 | 显示全部楼层 来自: 中国江苏常州
/ }0 U3 e0 J8 x) Y( Q1 ^
' N6 F. y" ]4 e: T9 fHC:High Carbon Cast Iron; Cu,Cr is the mainly alloy element.8 B. w' W2 o$ R/ ~- e( Q& D$ _* x
The material in the German literature GG15HC sign, in English is GIHC (Gray Iron High Carbon).
6 M$ q4 A2 l& ^  \3 \GG-15HC: A wide range of cast iron is produced from the HC-type cast iron used in the manufacture of brake discs, because of its favorable effect of alloying on the texture and very good resistance to abrasion.
- U* `3 {1 R4 D4 ]# f. rThe cast-iron texture: Graphite (%) 12.5, Graphite shape IA3, Perlite (%) 99, Ferrite (%) <1;4 s1 t9 Z" ~) O0 A) j8 L6 S" t. O3 R  q
Chemical composition: C 3.73, Si 2.07, Mn 0.78, P 0.058, S 0.085, Ti 0.014, Cu 0.56, Cr 0.27, Sn 0.039.) i2 R; l8 q! d
Mechnical property:Hardness: 180 ± 5 HB, Tensile strength:240 MPa.
1 J8 w0 @: F0 n/ ?2 \The cast GG15HC marked characteristics:
& O- D* g4 d$ O" Z9 q- High thermal conductivity,
2 f2 i. N+ R, J' C0 e. ^0 }+ d. ?- Low thermal stresses,
: d$ V% N/ d* c1 b: m1 S- High resistance against cracking due to heat generated,
) V6 y5 d5 G" W0 c! s- Good shock absorption properties.
wwjxgz + 3 应助
 楼主| 发表于 2010-11-11 14:05:39 | 显示全部楼层 来自: 中国辽宁大连
7# wenjuanzhi2008 ( A& W0 t6 P! p, o% d" X
0 U% e( e$ D0 }6 P% _8 D* {" d' d) T
yes, you right, the iron was used in brake!9 ^! u  k! H2 s& w8 W
thank you very much for your help, and do you have some standards for this grey cast alloy, I want to know where does  the data comes from; 0 r2 X$ ^/ {+ p& u2 M2 \" s  I) `
thank you!
发表于 2010-11-11 14:20:54 | 显示全部楼层 来自: 中国江苏常州
Please refer to the attachement as belows, the thesis is witten by Hungarian, you can find google translation for help.
HC type cast.pdf
140.17 KB, 下载次数: 6
wwjxgz + 3 应助
