查看: 2179|回复: 2
[分享] G82 P10000 後處理更改
发表于 2010-12-10 05:08:54 | 显示全部楼层 |阅读模式 来自: 中国台湾
本帖最后由 yit02yit02 于 2010-12-10 05:15 编辑 - V( m/ q! t4 F+ Q2 O
8 |( U& @. J1 w1 Y到台灣三重湯城欣昊((充電))上課五天  U& \' M1 Y5 l3 T
這次幫我們上課的是陳漢傑老師
1 l1 x* {* t4 v4 d- D4 `我也問了關於G82 P10000 萬分位的問題(一般是千分位)
* N- c1 R- l; H9 n- k
陳老師也幫我解決了這方面的困擾7 k9 E* V  F5 H; B# J1 r: j' ]
首先開啟POST
  b3 }% x1 V+ q+ W' U找到  E* B0 x- O# F2 Y; L0 }, n
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
8 p$ o9 V8 r/ M% j% y# --------------------------------------------------------------------------8 I. H9 G" L5 n
#Default english/metric position format statements1 n3 r) f5 w+ B: N+ F" a
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (
* s7 i4 |  x2 f6 K; nfs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
3 d/ w/ ]3 C+ Y4 a0 C8 jfs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
3 S3 }- {5 S3 x0 |$ u, [, j#Common format statements* v+ t" ]( N; @. p3 C
fs2 4   1 0 1 0     #Integer, not leading: G. R# m+ ?# L. S! x1 W. K% f
fs2 5   2 0 2 0l    #Integer, force two leading
/ G4 c) A) B: R4 c* Pfs2 6   3 0 3 0l    #Integer, force three leading
8 O5 q0 f& e2 ~$ Dfs2 7   4 0 4 0l    #Integer, force four leading
$ K& Z% d( v1 |2 J: Ffs2 8   5 0 5 0l    #Integer, force five leading2 r5 L9 t% K7 q0 d) [! B  Q0 u  ?
fs2 9   0.1 0.1     #Decimal, absolute, 1 place* O# ]1 ]- U2 d' O
fs2 10  0.2 0.2     #Decimal, absolute, 2 place, r* g( x- f3 ^- h) _
fs2 11  0.3 0.3      #Decimal, absolute, 3 place
) _$ h# t( j6 ^. N2 K( L1 w" w# kfs2 12  0.4 0.4     #Decimal, absolute, 4 place
% {' ^4 k2 g' a$ Ofs2 13  0.5 0.5     #Decimal, absolute, 5 place
! @. b6 ^) K2 p' e9 X, Dfs2 14  0.3 0.3d    #Decimal, delta, 3 place
8 S* P0 ~! R" M% z$ R8 hfs2 15  0.2 0.1     #Decimal, absolute, 2/1 place (feedrate)
- n' n7 f2 G1 Q* I2 r& a5 X! ~* G6 K0 b2 ]fs2 16  1 0 1 0n    #Integer, forced output
  O3 Z" c  P4 gfs2 17  1.4 1.3lt   #Decimal, absolute, 4/3 trailing/ q& R6 [5 E9 r6 T
fs2 18  0 4 0 4t  (增加這一行)
. d6 p2 A/ r9 t% }' h4 j
$ o$ ^( C2 m  E, H- Y再找到2 t) i+ a. R  Y6 r$ L5 D& p
6 f2 j4 g. m( y: nfmt  N  4   n$          #Sequence number
9 n& Q/ d5 L+ B) k6 ]6 O: Sfmt  X  2   xabs        #X position output
. j' ?: ^: v/ ^fmt  Y  2   yabs        #Y position output
# i1 u1 o6 W& K' E2 l2 afmt  Z  2   zabs        #Z position output
4 J. \* `6 [8 }. `8 _- T. Kfmt  X  3   xinc        #X position output5 o+ Q3 Q: P2 a& @% t. Q- X* x
fmt  Y  3   yinc        #Y position output
5 D6 E% B) x4 O4 pfmt  Z  3   zinc        #Z position output
' ]8 E* @5 D  Y0 dfmt  A  11  cabs        #C axis position' Z7 @, z* E! X* k( q  P) a
fmt  A  14  cinc        #C axis position
: w+ A" U) Z  G3 K5 Z6 w) ofmt  A  14  cout_i      #C axis position. q. w- p" z8 M8 G; O0 K! |9 o
fmt  A  4   indx_out    #Index position
7 M2 c. j5 [. z  ^6 Jfmt  R  14  rt_cinc     #C axis position, G68
2 F8 o5 c6 X3 q' {- k. Pfmt  I  3   iout        #Arc center description in X
2 H+ p  a# K: `2 n' n: t. U1 rfmt  J  3   jout        #Arc center description in Y
  L# a! U, H) X& A6 Efmt  K  3   kout        #Arc center description in Z- F( l+ Y5 Q1 k( K$ Q4 e
fmt  K  2   lead        #Helical lead! Y4 S) `& K# k8 ?7 @
fmt  R  2   arcrad$     #Arc Radius
0 D& T% [) ?$ }fmt  F  15  feed        #Feedrate8 p* Y$ L+ A# t4 l( x8 _" i; s
fmt  P  11  dwell$      #Dwell (把P11改P18)
8 M' ]; B! p# H8 e; q
fmt  M  5   cantext$    #Canned text6 w& p7 R* K# V
fmt     4   mr2$        #HSM3 Y, D% ]4 Q4 e5 z, \0 g
程式選G82時暫停時間打1.0
# m# b5 g* x. [轉出來就會是G82 P10000
1 C; Z; F% N0 m8 F- B4 X真是謝謝)))陳老師)))))
参与人数 1三维币 +10 收起 理由
pengxiangxu + 10 好资料,感谢您对论坛的支持!
发表于 2010-12-10 20:17:47 | 显示全部楼层 来自: 中国台湾
yit02yit02  Thanks for sharing
 楼主| 发表于 2010-12-10 20:41:16 | 显示全部楼层 来自: 中国台湾
2# andy124203158
% ~( N/ ~  f% G
  Q! K. D' S8 R& y. p之前轉出G82 R3.Z-20. P1.0 F100.
9 V3 f8 @3 T9 V" \FAUNC 會發出錯誤訊息!+ K6 S* S( }* L3 n  q. `
老師就是專業!
