调整CIM模拟速度的方法:打开×:\E\Program\IT\bin 里的 machtime.dat 文件把里面的10000,改成你需要的速度,就可以了!% l5 V( _5 J7 u. u$ T; Q/ g
, t, ~$ M/ M0 c; i+ {8 h
Control over Simulator Rapid Feed Values/ I' H* i+ i3 x" \: Y% B
􀂃 A Bug was caused by an incorrect value of the rapid motions feed used by the I: u+ j* n7 v
Simulator and Verifier.- F" ~% C# Z* o
􀂃 A fix was done allowing the input of the correct values through an additional file" ?; I& R% C3 J! B' R7 o
called machtime.dat and placed in the folder
* r! k- D1 Q; M2 n; H$ Y5 H. cC\:Cimatron\CimatronE\Program\IT\bin. This text file enables the user to set the
1 n f& r0 a5 H& t9 C7 D5 Dmachine parameters:
2 W$ M+ M+ C( b9 J, so MaxXFeed 10000( y- w# x; Q3 N9 y2 f& \6 M
o MaxYFeed 10000
+ [9 P4 T# ^/ t7 { i4 S/ z( Co MaxZFeed 10000
* ^) G! {- I! c h! V- U' S$ D/ X(10000 is the default when no other values are specified).
) j& [$ W) k3 e$ U9 ^. JThese values are used both by the Simulator and the Verifier |
