查看: 4782|回复: 3
关于SolidWorks普通显卡开启realview的方法
发表于 2010-12-15 09:53:19 | 显示全部楼层 |阅读模式 来自: 中国湖南衡阳
如果装的是2009或者2010,注册表项中2011就是2009或者2010。
4 D0 C' k5 `; T& @; i8 Q5 a3 h4 U5 S" J( M
& ?% Y5 N, H1 D$ u( V, \
I've found in a russian forum post a guide to activate the fullscene anti aliasing + realview for the consumer video cards
( y, B3 U$ x) c( u( Z+ ]% Pgoto: HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Current9 G1 g6 z. d! _4 W8 K3 x8 h$ n
and copy the string 'Renderer' in my case is:
! u# C/ l2 p* P  w! T+ J"ATI Radeon HD 5800 Series " (i've also a space at the end)* o) r6 @1 r( q) H
now if you have an ati go to:
8 [2 k. j- x2 v# H# e"HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\R420"
0 L! r+ D% a6 M" }/ Dmake a new key and as name paste that copied above, so now we have:3 P7 `  z% @3 d! ^, {, S* x4 u& U
"HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\R420\ATI Radeon HD 5800 Series "
9 f. U  q4 ?, i: ^now add a new dword called "Workarounds" and set it to 400005 \+ ?- ]7 A( ^# B5 @
Start solidworks and see the reflection shadows effects etc.
6 o7 S' g- i7 U4 oif you want the full scene anti-aliasing now is disponible in system options dispaly/selection frame.
$ v, ?  A2 {) bWindows Registry Editor Version 5.00+ y  F) L4 _# h& `, M
[HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\R420\ATI Radeon HD 5800 Series ]
! w2 }5 X/ P" P1 L% B! m  T. }/ }9 {3 _" ^"Workarounds"=dword:00040000
1 g0 N" m: h2 u  `+ JFor the nvidia is the same thing but the new key should be inserted in:+ Z+ g2 q' `* u
"HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\NV40"
. S- W* O3 k: g: m8 ]/ x" Aand the new value workarounds could be 80008& J9 h* |% @. k" a. Z6 h  R' `
an example but i've not tested it(the name of the vidocard is invented 8 A; ^3 Q" D/ J/ y+ {3 F
8 U# Q% M; f  f+ L' L7 z[HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2011\Performance\Graphics\Hardware\Gl2Shaders\NV40\GeForce GTX 480]
( ?! p4 u& X) q, L0 Y" o"Workarounds"=dword:00080008
4 J% M1 _7 h# L1 |( B; [Good Luck
发表于 2010-12-15 10:02:49 | 显示全部楼层 来自: 中国广东惠州
我找到了一个俄罗斯论坛发布指南,启动反走样fullscene为消费类视频卡+的RealView
8 {# \) @2 Z$ M1 M3 n5 e- R#v2的y%的一/氮; | 8 V的三维|计算机辅助设计|机械|汽车|技术| CATIA的| Pro / E的|微克|发明家| cad |机械| caxagoto中:HKEY_CURRENT_USER \软件\ SolidWorks的\ SolidWorks的2011 \性能\显卡\硬件\电流' I' v" k! n0 q9 j/ y- U
+ T K1的| *} /平方米量Q *我三维网技术论坛,并复制字符串'渲染'在我的情况是:三维网技术论坛%记者:@ 5 [/曲(三&T公司;瓦特" ?: M% D# B& a9 R# Z
“ATI的Radeon HD 5800系列”(我也曾经在最后一个空格)
* r8 o# m3 h" G1 g* L0 c1 S7 h* N0 F' ?,电子邮件:一)臭氧_. \。 W4号我(Ynow如果你有一个ATI转到:三维网技术论坛+ R“的D4的\ 2 r! X2的鸟嘌呤| 9天
3 j6 o7 l5 I3 L6 |+ O1 m“HKEY_CURRENT_USER \软件\ SolidWorks的\ SolidWorks的2011 \性能\显卡\五金\ Gl2Shaders \ R420”
2 y+ a& e8 p+ p5 X) Q' ?。为X0 Y'的河T1的商业/住宅,我,邻%ü! Z5的Tmake一个新的密钥和粘贴复制的姓名以上,所以现在我们有:
7 W9 ]9 t4 X8 I3 ?;六对称Ĵ Ĵ +男* [(一+ {&C“的HKEY_CURRENT_USER \软件\ SolidWorks的\ SolidWorks的2011 \性能\显卡\五金\ Gl2Shaders \ R420 \的ATI Radeon HD 5800系列”三维网技术论坛0我)的W - ü,下;}:N9号W&7我! T1 D: L. {+ O. K" d; E4 f, e
现在添加一个新的DWORD所谓“变通办法”并将它设置为40000
4 M. w5 x# {* T2 C& b* D/ p/ C)V2的]#`4} 0 X8的R! \; P和A三维网技术论坛启动SolidWorks,看到了反射的阴影效应等三维网技术论坛+ y的] - :|! U0的〜#y%的Ğ8 O# X, Q5 @5 F+ H
如果你想全场景反锯齿现在是在系统选项琅/选择框disponible。, f* J! X% Y! C0 }/ D4 H1 d
5专* V *的c0的母语Ÿ T1的_#B的P8的四q三维|计算机辅助设计|机械|汽车|技术| CATIA的| Pro / E的|微克|发明家| cad |机械| caxaWindows注册表编辑器5.00版7 `9 ^  t! S/ U8 E$ c! N( U
$克+ L键+磷;八国少年\ www.3dportal.cn [HKEY_CURRENT_USER \软件\ SolidWorks的\ SolidWorks的2011 \性能\显卡\五金\ Gl2Shaders \ R420 \的ATI Radeon HD 5800系列] www.3dportal.cn9为E(G - H7型伏; Z“的G6的^
; Y0 j' q+ K3 [“变通办法”=的DWORD:00040000我; R1的克*秒(金(X“的ç
1 \9 h; T6 K# w对于NVIDIA是相同的事情,但是新的关键应插入:三维网技术论坛,五%的O&_ A型(C#的权证; @' n5 g" T5 D: O& w
“HKEY_CURRENT_USER \软件\ SolidWorks的\ SolidWorks的2011 \性能\显卡\五金\ Gl2Shaders \ NV40”三维网技术论坛9个N数k |,{0 K表, s7 a, C% Q0 B% b: k
解决方法和新的价值可能是80008三维,计算机辅助设计,机械,技术,汽车,CATIA的,Pro / E等微克,发明家,SolidEdge的时,SolidWorks,CAXA的,时空,镇江! z'的E5公司} 4 U4的十H8座新元的z; ž +米3 e- t5 r) d2 n; R% x/ v8 B: i% {
一个例子,但我还没有测试它(该vidocard名称是发明三维,计算机辅助设计,机械,技术,汽车,CATIA的,Pro / E等微克,发明家,SolidEdge的时,SolidWorks,CAXA的,时空,镇江%ř%H6的升'高级S9的Ÿ% W' T: R+ I% A, J  m
Windows注册表编辑器5.00版
, i( V  Y# F& z( f'_ $ R)的第四季度高*钾,九方的S / Bwww.3dportal.cn [HKEY_CURRENT_USER \软件\ SolidWorks的\ SolidWorks的2011 \性能\显卡\五金\ Gl2Shaders \ NV40 \的GeForce GTX 480]
# o+ R+ y# F) {- G7 f! K8平台ñ#环Z(s'的值K0 M三维| cad的|机械|汽车|技术| CATIA的| Pro / E的|微克|发明家| cad |机械| CAXA的“变通办法”=的DWORD:00080008- E$ D' D9 Z& e6 }
2 N9号x)的J6的C及K2的\; fGood福
发表于 2010-12-15 10:20:21 | 显示全部楼层 来自: 中国江苏泰州
; |, g- Y* J6 u- {) ]
7 u; G+ l/ |8 c7 k& B2 o楼上的,这什么乱七八糟的!!!谁能看的懂??
发表于 2010-12-15 10:25:55 | 显示全部楼层 来自: 中国山东青岛
怎么是乱码?看不懂!!1
