2022-03-11
系统
2021-07-01
查看: 5170|回复: 28
[已解决] Blankworks / Logopress
发表于 2009-12-27 02:49:29 | 显示全部楼层 |阅读模式
Hello guyz, I have just started to use tooling design software. I have to make a progressive die for this A-3003 aluminum part:$ s0 |% p$ D! Y3 K" z
Part.jpg 0 G8 Z; |7 ~' t; S' B
Unfortunately I made a part unfold using Logopress and Balnkworks but they were really diferent:
& B9 F# g' p# s/ N( z& @ Part_1.jpg
/ [& W6 p5 E; {& E8 ?Any ideas??
& d5 t$ U+ Y: R: R+ ]This is the file:
+ A  @( U9 ]9 W[local]4[/local]
 楼主| 发表于 2009-12-27 02:53:46 | 显示全部楼层
Hello guyz , I have just started to use tooling design software . I have to make a progressive die for this A-3003 aluminum part: 3 S5 }- j1 Q4 n
Part.jpg 3 O1 f! f; @6 m( D' `6 g
Unfortunately I made a part unfold using Logopress and Balnkworks but they were really diferent :, z. ]  p$ c$ P
/ m* ^# E( S* I  |Any ideas??This is the file:
+ D$ A7 b* v( q0 X9 `2 E" j7 Z Part.rar (450.84 KB, 下载次数: 11)
 楼主| 发表于 2009-12-27 03:04:54 | 显示全部楼层
File
This one is the file:
Part.rar
450.84 KB, 下载次数: 8
发表于 2009-12-30 12:44:22 | 显示全部楼层
什么东西。。看不明白
发表于 2009-12-30 14:02:13 | 显示全部楼层
模具结构不一样,顶料方式不一样,料片也不一样! M9 _4 f& C9 E0 c. i( H7 G
可能logo默认有顶料,blankworks顶料需要手动设置
 楼主| 发表于 2010-1-1 06:27:06 | 显示全部楼层
I chosed aluminum A3003 T5 in both analysis, I would like you to try to unfold using another software. I want to know why they are so different.
发表于 2010-1-1 16:43:34 | 显示全部楼层
什么玩意  看不懂、
发表于 2010-1-2 13:12:23 | 显示全部楼层
kan bu  dong ?zhe shi  shen  me ?
发表于 2010-1-7 17:11:04 | 显示全部楼层
我试试做下,我也是初学的
发表于 2010-1-7 18:27:40 | 显示全部楼层
是什么东东还是英文的了
发表于 2010-1-7 20:58:32 | 显示全部楼层
英文不是太好,从你展开图看,两种软件展开后毛坯尺寸不一样,可能是有些项目设置不一样。对于有些零件用log软件进行冲压展开时,选好压料面后,X、Y方向设置与否,展开的结果不一样。
hxg168 + 2 应助
发表于 2010-1-7 21:13:22 | 显示全部楼层
上传的文件版本太高打不开,上传igs格式的文件,我用logopress和Dynaform或3Dquickform试试
发表于 2010-1-7 21:28:55 | 显示全部楼层
2 i4 k$ r' [1 b2 N用log时有没有勾选(单独或全部)图中X向锁定(locked on Xs direction)、Y向锁定(locked on Ys direction)
 楼主| 发表于 2010-1-8 08:34:17 | 显示全部楼层
This is how I did it using Logopress:
9 L5 @! q0 z6 L, d" {, i: y5 Q Analysis.jpg
 楼主| 发表于 2010-1-8 08:40:21 | 显示全部楼层
I tried to unmark the Locked on Ys and Locked on Xs direction but the result was almost the same. I think a thrid unfolding on a different software would define wich one more accurate.This is the IGS file:
# I1 D9 J( a% c0 [. q6 ~# v2 y: O  c partIGS.rar (260.74 KB, 下载次数: 4)
发表于 2010-1-8 22:10:34 | 显示全部楼层
我认为你用blankworks软件展开的比较正确。附件是我用logo展开的,你参考一下。
发表于 2010-1-8 22:15:01 | 显示全部楼层
附件里是我用LOGO展开的文件,供你参考
part.part1.rar
1.39 MB, 下载次数: 2
part.part2.rar
909.53 KB, 下载次数: 2
hxg168 + 5 感谢
发表于 2010-1-9 12:33:10 | 显示全部楼层
展开后的实体.jpg 展开图.jpg " A4 S( u2 w* A( |( K1 U% |: a
重新用logopress和dynaform软件进行展开,结果一样.
展开图.rar
781.58 KB, 下载次数: 3
hxg168 + 5
 楼主| 发表于 2010-1-9 12:41:01 | 显示全部楼层
I will compare my result against yours wan_zhon. 8 y0 k9 L4 s$ B9 z: Y: V4 d
Regards!
发表于 2010-1-9 13:52:33 | 显示全部楼层
: C* ]0 W0 c( Q. m: ]3 p! W! `Regards!
9 J" \2 {6 m! U* t3 ~4 g1 Eroberto123 发表于 2010-1-9 12:41 http://www.3dportal.cn/discuz/images/common/back.gif
; {8 r& r6 i0 }& n+ n1 M, |2 _: @
请将你的比对结果上传,与大家分享。
发表于 2010-1-9 21:17:02 | 显示全部楼层
下面贴图为用dynaform展开后导入solidwork的曲面展开图。在导入dyna进行分析前,用logo先将折弯部分展开然后导出曲面到dyna进行分析。上次附件里的压缩文件可用solidwork2008 5.0打开。打开dyna.SLDPRT时可能会提示错误,但不影响打开。里面的曲面为dyna展开的。
 楼主| 发表于 2010-1-11 16:07:25 | 显示全部楼层
wan_zhon我想知道你的设置用于执行分析。一切都OK了我打破的一部分,它看起来像你的成果。 非常感谢你!。
发表于 2010-1-11 16:18:18 | 显示全部楼层
确实是很不错的展开软件!
发表于 2010-1-11 20:50:18 | 显示全部楼层
. v5 O+ k9 ?. a6 u) x) R
0 g' r! q+ Q/ z$ Zroberto123 发表于 2010-1-11 16:07 http://www.3dportal.cn/discuz/images/common/back.gif
能帮助别人是一种乐趣。与人交流的同时也在提高自己。
hxg168 + 5 你说的狠好,欢迎常来
发表于 2010-1-16 10:26:56 | 显示全部楼层
其实关于成形展开,我们都误导了,收敛和压边是可选边线的,这样展开的效果比效好和是按实际定向的
hxg168 + 5 你也是高人,欢迎常来
