楼主 |
发表于 2010-3-17 18:56:42
来自: 中国湖北武汉
按照本身说明:“1. Install relevant sw2010 update and other updates as needed.$ h# ?. Z. e/ Y) C: m0 n
NOTE: If you installed our SP1 release, the patcher 1.0-2.1 may fail - restore SP1 original sldappu (bundled) and try patcher again.' N1 A7 {& o# P1 F3 q
SP2.1 original sldappu also included for future updates.
$ i% a6 c3 W4 l; {2. Copy ibfs32.dll to windows\system32\
$ J: c, j+ h2 y" o! C1 p3. Import lz0-sw2010.reg to registry.# n$ [2 N6 q# b- `
4. Copy sw2010.lic and sldappu.dll to C:\Program Files\Solidworks\
6 ^4 C3 N: z6 V8 W) ]7 S* i5. If installed, copy any addon patched files to appropriate dirs (eDrawings common files\edrawings2010, photoview, swexplorer)9 u- Q1 r* V' V# T/ P: @5 r: f8 z2 N
6. Enjoy!
2 T: ~. _8 q" i! ~
+ @, J& U$ Y) l5 e7 q7 Tnote: when installing COSMOSM, skip license setup - it will work with the reg/lic above
; |% h: x! C* d
9 I; X6 c) F% ~5 V5 ~+ z1 {* Install serial: 9916 5719 6888 1432 57K7 Q892.
* g. y- f4 |) B' b* h3 z1 g/ U v
" z! L3 u" A- ?( E7 n0 @需先安装sp0,然后升级到sp2.1,最后进行crack |
