查看: 4475|回复: 18
[求助] AMESim仿真出现异常,有没有用得熟一些的高手指点一下?
发表于 2008-1-16 16:53:02 | 显示全部楼层 |阅读模式 来自: 中国上海
运行仿真时出现以下提示,不能出结果。, _5 u! u- k9 r3 `2 c
不知道是模型建得有问题呢,还是软件本身有问题?
" r- k0 {/ w2 m9 A; T! i7 Y0 J8 S! m
lc_checkout failed with -5 - retrying after a short sleep try no:0   ]% e- n4 d+ n
lc_checkout failed with -5 - retrying after a short sleep try no:1
2 p" f6 z8 J/ ~. ?lc_checkout failed with -5 - retrying after a short sleep try no:2
* m% J  p! s/ L: A" B: @3 ilc_checkout failed with -5 - retrying after a short sleep try no:3 ' `: q! S& e8 M( ]
lc_checkout failed with -5 - retrying after a short sleep try no:4
7 Q* O  b. `4 x' |. Ylc_checkout failed with -5 - retrying after a short sleep try no:5 : E' Q0 W- q1 T; u$ q" r% `/ s# O
lc_checkout failed with -5 - retrying after a short sleep try no:6
4 M' D) _/ a8 j/ b7 blc_checkout failed with -5 - retrying after a short sleep try no:7
  x- d! I) S, `! Rlc_checkout failed with -5 - retrying after a short sleep try no:8
$ H1 y6 [, |3 P& G+ _2 K7 {/ xlc_checkout failed with -5 - retrying after a short sleep try no:9
% r" `" C# y  n1 c) \: g/ Tlc_checkout failed with -5 - retrying after a short sleep try no:10
+ r& c) |/ r6 K, YCheckout failed: No such feature exists. ) T6 D  |+ k, H6 o  x! K
Feature: hydraulic
- W% {# x2 ?3 p  @" h9 rLicense path: D:\AMESim\/licensing/license.dat
- T2 [7 O2 Z+ T5 r$ |1 `# fFLEXnet Licensing error:-5,357
- O& U  J4 D# Y& o+ `8 CFor further information, refer to the FLEXnet Licensing End User Guide,
9 x( `& i' @; ~  @available at "www.macrovision.com".
0 L2 t$ U0 Z6 R/ ]0 _4 YAMESim model E:/cylinder_ did an abnormal exit!
/ A$ K  t5 `6 p
+ A- q; c4 e0 L非常感谢!!!
发表于 2008-1-17 09:21:30 | 显示全部楼层 来自: 中国四川成都
可能是license的问题,你弄个帮助文件里面的模型运行看有没有问题
发表于 2008-1-17 15:26:40 | 显示全部楼层 来自: 中国天津
请问楼上这种软件有中文版的吗
发表于 2008-1-17 15:48:50 | 显示全部楼层 来自: 中国四川成都
没有,而且基本上没有中文教材,不过可以看英文帮助文档
发表于 2008-11-25 22:22:28 | 显示全部楼层 来自: 中国内蒙古呼和浩特
的却是lisence的问题,你没有Crack对,可以查查amesim的安装方法,论坛里面就有,crack也有。
发表于 2008-12-13 15:18:48 | 显示全部楼层 来自: 中国湖南长沙
哪个好心人能给我一个amesim 7.0的license
249359104@qq.com; f/ m, o4 p8 [( v* ?6 Z( R0 Z5 y5 I. U
1 h, p" G) G3 F
非常感谢!!!
发表于 2008-12-14 09:57:32 | 显示全部楼层 来自: 中国四川成都
你是amesim 哪个版本,我有8.0的crack
发表于 2008-12-14 14:19:04 | 显示全部楼层 来自: 中国陕西西安
应该是license的问题,我有7的crack,需要给我留言
发表于 2009-2-12 15:51:00 | 显示全部楼层 来自: 中国浙江宁波
chdiulong1 M8 a  H" q# Z2 u1 e7 T: C0 {
请发我一个,谢谢!
4 v& q: C. ^: g295992877@qq.com
发表于 2009-3-4 09:26:34 | 显示全部楼层 来自: 中国吉林长春
我的也是只能建模不能仿真,上网查了一下是因为licesene缺少东西% ~! H4 v" C, B* z
谁能帮忙解决一下,非常感激!
发表于 2009-4-9 12:41:14 | 显示全部楼层 来自: 中国四川成都
8 Z7 W5 t& B9 [/ u/ P非常感谢wff198037@163.com
发表于 2009-5-5 10:23:29 | 显示全部楼层 来自: 中国江苏镇江
回复 7# 龙门起重机 的帖子
我要8.0的,谢谢了) I; i* X" i3 v, G
xunqunde1@163.com
发表于 2009-12-1 09:46:19 | 显示全部楼层 来自: 中国重庆
哪个好心人能给我一个amesim 8.0的license,非常感谢,
8 y  R7 C5 R6 }& ]zzxjbs@163.com
发表于 2009-12-7 21:01:22 | 显示全部楼层 来自: 中国河北保定
发表于 2009-12-7 22:25:15 | 显示全部楼层 来自: 中国内蒙古呼和浩特
发表于 2009-12-8 11:01:38 | 显示全部楼层 来自: 中国辽宁鞍山
论坛里面有搜一下就行了
发表于 2010-1-8 21:29:36 | 显示全部楼层 来自: 中国河北保定
发表于 2010-3-26 09:09:40 | 显示全部楼层 来自: 中国陕西西安
我也出现了跟楼主同样的问题,请问楼主是怎么解决的?
发表于 2010-10-22 11:20:12 | 显示全部楼层 来自: 中国广东深圳
RE: AMESim仿真出现异常,仿真液压库中没有二位二通阀(常开)怎么办
18# joopl2007
